NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 05-22-2012, 06:04 AM
  #9046
Originally Posted by kermit
Does anyone know if once you upgrade the LCD program box to the V3 software if it can be downgraded back to V2.1 on the odd occasion that you need to program a V2.1 speedy? I assume the old program box software could be loaded via your PC if needed?
Yes it works, but you can have a bug that make it failed, and if it's the case, don't touch anything on the computer, unplug the USB cable, then plug it again 30s later, the update will start again by itself and will go through this time.
FFred is offline
Old 05-22-2012, 08:37 PM
  #9047
TryHard's Avatar
The other option is too leave the box with the V3 software on it, and just keep a copy of the V2.1 software on the computer.. you can then program a 2.1 by using the box simply as a connection to the ESC. You just can't program the ESC by box alone.
HiH
Ed
TryHard is offline
Old 05-23-2012, 09:35 AM
  #9048
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
I picked up the Xerun 120A with the built in booster. It came preinstalled with the low profile heatsink. It also came with a larger heatsink and fan.
Do I need to install the larger heatsink/fan combo if I want to run modified TC?
Do I have to open up the ESC in order to put this larger heatsink on? It looks like it came with thermal tape, although I don't know how effective that will be.
tr1kstanc3 is offline
Old 05-23-2012, 09:52 AM
  #9049
Darrin70's Avatar
I asked this question awhile back with no reply, can the 1/8 HW motor leads be cut..?
Darrin70 is offline
Old 05-23-2012, 11:20 AM
  #9050
Trader Rating: 27 (100%+)
Yes you can just attach the larger heatsink via thermal tape. It'll do just fine. Now I know that Hobbywing recommends the heatsink fan if you're running 2s lipos. I dunno what the motor limit is for 2s lipos on that esc.
hyujmn is offline
Old 05-23-2012, 11:47 AM
  #9051
ByteStream's Avatar
XERUN-120A-1S
With 1S Lipo or 3-4 cells NiMH, 1/12 on-road >=2.5T
With 2S Lipo or 5-6 cells NiMH, 1/10 on-road >=3.5T, 1/10 off-road >=5.5T
ByteStream is offline
Old 05-23-2012, 11:58 AM
  #9052
Oh cool thanks for that info. Btw the fan on the heatsink is LOUD. It sounds like a turbine. Moves lots of air though. My esc is usually only 92-95f after 6 minutes. That's with about 85 degrees ambient temperatures.
hyujmn is offline
Old 05-24-2012, 03:48 PM
  #9053
lip
Do I need to install the caps that come with my V3 or only if I have a glitching problem?
Thanks.
lip is offline
Old 05-24-2012, 04:27 PM
  #9054
slow_jun's Avatar
Trader Rating: 14 (94%+)
Thanks.
Its required to install the caps its not for glitching but its for preventing high surges of voltage and the risk of damaging your esc.
slow_jun is offline
Old 05-24-2012, 05:37 PM
  #9055
yokemad's Avatar
Originally Posted by mattst
so to confirm can you use v3 software on a extreme stock esc ? if so which one or version ?
I dont want to mess up my esc or others as I sort out a few esc's at my club with the upto date firmware.
Please hobbywing please confirm this for us all.
+1
yokemad is offline
Old 05-25-2012, 09:27 AM
  #9056
Default Hobbywing v3
Right people Ive just got my V3, but after running a Tekin for 3 years Im totaly stumpted. Ive read the instructions but ive no idea what I need to do.
Could some one post some step by step guides on how to up date the V3. I do have the LCD card as well.
I race 13.5 boosted touring car, what software does the speedo come pre loaded with ??
Sorry to be so dumb lol
FLAT OUT is offline
Old 05-25-2012, 12:29 PM
  #9057
Barry_Hughes's Avatar
Originally Posted by yokemad
+1
I am sure it has been posted on here.
V3 software is only for the V3 ESC's - nothing else
Barry_Hughes is offline
Old 05-26-2012, 02:36 PM
  #9058
I just got a new xerun 120a 1s esc and just finished soldering it all up. I connected a battery and got my radio ready to calibrate. I turned on the esc and nothing happened. No beeps, no LED, no fan. I tried a different battery, same thing. then I hooked it up to the PC, and it showed up, so I tried re-updating the firmware. After it successfully updated everything started working like normal again.
Could this be indicative of a deeper problem with the esc? Or did the firmware just fail to write correctly to the esc at the factory?
Thanks!
Stregone is offline
Old 05-26-2012, 02:48 PM
  #9059
Fast410's Avatar
Trader Rating: 47 (100%+)
Default hobbywing esc 150a xerun issues HELP!
i just bought a hobby wing xerun 150a esc and it wont run on a two cell lipo, it runs perfect on a three cell but once its on 2 cell it has delayed throttle and steers on its own and yes i set two cell program on esc when i ran it. i have sent customer support emails and no awnser. its hooked up with a castle 1410 4 pole motor in a losi ten-scte
Fast410 is offline
Old 05-26-2012, 02:55 PM
  #9060
Add a cap bank to the battery leads. Worked for me.
Stregone is offline
