Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 06-17-2015 | 05:37 AM
  #8611
houston's Avatar
Originally Posted by 1evo RRR Driver
Houston at the nats if my fusion needs tuning could you help me? I kno it won't. But just asking...........
Of course ,find me
houston is offline
Old 06-17-2015 | 10:38 AM
  #8612
1evo RRR Driver's Avatar
Originally Posted by houston
Of course ,find me
thanks
1evo RRR Driver is offline
Old 06-17-2015 | 06:30 PM
  #8613
Can he just just look for the Green Mountain Grill with meat smoking on it? Follow your nose
Chris Reilly is offline
Old 06-18-2015 | 10:03 PM
  #8614
houston's Avatar
I shoulda brought it but didnt
Tryin to qualify for worlds
Im doin too much wrecking though ,ugggh
Getting better each run , getting used to pro line rubber , sooooo
houston is offline
Old 06-18-2015 | 10:37 PM
  #8615
aznitronut's Avatar
When did you go with Proline?
aznitronut is offline
Old 06-18-2015 | 10:52 PM
  #8616
the wrench's Avatar
heres a total out of the blue question, anyone using O'Donnell v2 turbo plugs? are the tapers different? i have a reds te2 and a werks b6 pro, wanted to try them
hope my question isnt out of place, i just cant find any info on these plugs and what they fit, or even worth trying, they have an interesting heat range
the wrench is offline
Old 06-19-2015 | 12:30 AM
  #8617
dakilo's Avatar
I have been running OD97t's for years and now the V2 OD plugs with zero issues, I have not checked the taper but I assume they are the same.
dakilo is offline
Old 06-19-2015 | 02:53 AM
  #8618
beidle99's Avatar
IMHO nothing wrong with pro-line, I have a lot of their new sets of tires. Just wondering when you switched.
beidle99 is offline
Old 06-19-2015 | 05:41 PM
  #8619
you're doing good 33 second laps inbetween the bad ones, you just need to string a number of good ones together, stay clean and out of trouble. Try to get out of the pits in clear space, not in a pack.
Eivind E is offline
Old 06-21-2015 | 12:00 PM
  #8620
bash bros's Avatar
Monty, what are the stock settings for the x5 race?
Looking at it, the ls and hs look to be both a little bit out from flush.
Or are they similar to my p5? 4 out on the hsn and 5 out on the lsn?
bash bros is offline
Old 06-22-2015 | 03:14 AM
  #8621
beidle99's Avatar
My X5 Race with a 2096 pipe is a little in from Flush on the HSN and about a turn in from flush on the LSN with idle gap around a .6
If you lost your tune going to flush and starting over will get you started at least.
beidle99 is offline
Old 06-22-2015 | 06:05 AM
  #8622
bash bros's Avatar
Thanks, sorta what I was thinking but just wanted to confirm.
Old 06-22-2015 | 05:23 PM
  #8623
jeromerc's Avatar
stupid question but what is the different between the O'Donnel 1/10 hot plugs and the 1/8 hot plugs? #77 1/10 hot and 277t V2 ultra competition hot plug
jeromerc is offline
Old 06-23-2015 | 02:43 PM
  #8624
bash bros's Avatar
From what I understand the 277t is a newer version of the 77t with a different updated "2.0 wire technology" It looks the the 288t would be comparable to the 97t.
Hopefully someone that's used them can shed some more light on the differences. I'd be interested to see how well they'd work in a p5xlt.
https://odonnellglowplugs.com/home/comparison-chart/
Old 06-23-2015 | 05:15 PM
  #8625
jeromerc's Avatar
I haven't ran the 277t but I do run odonnell plugs in my fusion engines as the Nova plugs in Vietnam are about twice as expensive and hard to find
jeromerc is offline
