Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 06-24-2015 | 07:15 AM
  #8626
Gonna jump in on this thread...
Anyone recommend a header/pipe combo for the P5XLT?
Looking for Low/Mid range
MikeTinCT is offline
Old 06-24-2015 | 07:18 AM
  #8627
kgombe's Avatar
021 with 9853
kgombe is offline
Old 06-24-2015 | 07:21 AM
  #8628
Suspended
http://www.rctech.net/forum/offroad-...mbo-p5xlt.html
Socket is offline
Old 06-25-2015 | 01:39 PM
  #8629
houston's Avatar
Originally Posted by bash bros
Monty, what are the stock settings for the x5 race?
Looking at it, the ls and hs look to be both a little bit out from flush.
Or are they similar to my p5? 4 out on the hsn and 5 out on the lsn?
i send engines out with 5.5 turns lsn and 4 turns hsn . great starting point
houston is offline
Old 06-25-2015 | 01:41 PM
  #8630
houston's Avatar
i think we found the "keyboard warrior" socket649 Eivind
9853ss 41005 is awesome on 5 ports in truck , 2013 and 2058 work very well but you will not see full potential of runtime and torque imo
houston is offline
Old 06-25-2015 | 04:54 PM
  #8631
revo61's Avatar
Has anyone run any of the Reds motors? How do they compare to Novarossi (durability, tuning, fuel mileage)?
revo61 is offline
Old 06-25-2015 | 05:27 PM
  #8632
jeromerc's Avatar
I have not personally ran them, but in Vietnam they are pretty popular. At first not so much but compared to my Fusion engines they suck in run time and durability. They get about 8 minutes run time here while I get closer to 10. I had 6 plus gallons when I sent in my psr for pinch I think they average about 5 gallons per engine. In Malaysia they really like them though but... they haven't ran fusion either
jeromerc is offline
Old 07-06-2015 | 03:34 AM
  #8633
beidle99's Avatar
Hey Monty - how busy is your bench right now? I want to send my X5 in for a check up.
beidle99 is offline
Old 07-07-2015 | 01:04 PM
  #8634
houston's Avatar
Well , work clogs up engine time but i can get yours done pretty quick Nick
Send it in bro
houston is offline
Old 07-07-2015 | 02:25 PM
  #8635
Frank L's Avatar
Dr. Monty...
Do you wear a white coat at checkups???
Frank L is offline
Old 07-07-2015 | 08:54 PM
  #8636
houston's Avatar
Originally Posted by Frank L
Dr. Monty...
How did u guess?
houston is offline
Old 07-10-2015 | 09:05 AM
  #8637
bash bros's Avatar
Kind of a noobie question, but is it possible to get a stock p5xlt to drop right down to idle at a race tune? I had it running great last night at the track, nice and crisp with a nice steady idle and a trail of smoke at wot. But after a straight it would surge up for a few seconds, then drop down to idle. It seemed like if I richened the ls back out it would get to boggy in the slower sections.
I've seen a few other p5s that seem to do this as well so I'm just curious if that's the nature of a long needle carb or what. On the other hand I've heard people say that a properly tuned engine should drop straight back to idle.
I'm running a 2096/41021, Byron 30/11, c6 plug
Settings were pretty close to 3.75 hs, 5.25 ls and a .5mm gap
bash bros is offline
Old 07-10-2015 | 05:43 PM
  #8638
houston's Avatar
If its not loading up , it stays running ,not excessively hot and making enough power to keep u happy i say its good , fuel pressures from tanks do some funny stuff. The novarossi carburetor definitely needs a good consistent fuel pressure from the tank , ive seen tanks cause inconsistencies, pipes cause inconsistencies, holes in pressure line ,etc. Etc.
houston is offline
Old 07-11-2015 | 09:07 AM
  #8639
bash bros's Avatar
Originally Posted by houston
If its not loading up , it stays running ,not excessively and making enough power to keep u happy i say its good , fuel pressures from tanks do some funny stuff. The novarossi carburetor definitely needs a good consistent fuel pressure from the tank , ive seen tanks cause inconsistencies, pipes cause inconsistencies, holes in pressure line ,etc. Etc.
Thanks Monty, I'll have to give it a good once over and check for any leaks.
Old 07-14-2015 | 04:28 AM
  #8640
This "surge" after a full throttle run, can be caused by several things in my opinion.
It would either be:
1. Slightly lean top end
2. Somewhat excessive idle screw
3. Fat'ish bottom end
Now my money will be on your bottom end being about 10 minutes fat, since you describe it getting boggy if you richen the bottom end.
It's difficult to explain why this happens, but it does.
Eivind E is offline
