Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 04-25-2015 | 07:50 AM
  #8596
Originally Posted by tlyons68
monty can you explain what needs to be done to modify hudy to install the front bearing?
I think Monty machines the center down some so it doesn't touch the inner race. What I do is take a old bearing and pull it apart and use the outer race to push against the new bearing. Just take your time and make sure the two bearings are lined up good before you take it all the way into the block. I just don't have a way to machine my Hudy tool down and this has worked for me for a couple of years now.
ArronRC is offline
Old 04-25-2015 | 09:18 AM
  #8597
kgombe's Avatar
i just use a piece of Lexan, ream out a hole big enough to not touch the center race.. and yo are good to go... any old scrap of body that thick enough will work
kgombe is offline
Old 04-25-2015 | 12:55 PM
  #8598
tlyons68's Avatar
Thanks aaron i might know someone to do this for us will let you know
tlyons68 is offline
Old 04-25-2015 | 04:31 PM
  #8599
houston's Avatar
Its not hard guys , your hands if trained Can be very accurate
The piece that pushes on front bearing doesnt really have to have the material removed with extreme precision anyway
Just as long as it does not touch inner bearing race
houston is offline
Old 05-03-2015 | 06:17 AM
  #8600
dmartin's Avatar
Monty,
What needs to be done to finish breaking in one of your FM engines?
dmartin is offline
Old 05-03-2015 | 06:23 AM
  #8601
dmartin's Avatar
Nevermind. Found it on your site.
dmartin is offline
Old 05-14-2015 | 12:02 AM
  #8602
Maxximize's Avatar
Random question time! I figured this would be a good place for this. Is there a throttle return spring for big block slide carbs that has good tension to it? I'm looking to get a better set up on both my Mad Force and T Maxx. The one on the Mad Force is too weak, and the set up on the T Maxx is jury rigged onto the throttle linkage by the tranny, which works but bends the linkage. I want one that mounts on the carb if anyone makes a decent one. What's everyone run for this??
Maxximize is offline
Old 05-14-2015 | 04:55 AM
  #8603
rcmania74's Avatar
Dynamite makes them...used to be on old losi lst trucks and sportwerks buggies
rcmania74 is offline
Old 05-15-2015 | 07:55 PM
  #8604
houston's Avatar
use goodys silicone hairbands
houston is offline
Old 05-19-2015 | 03:02 AM
  #8605
beidle99's Avatar
+1
beidle99 is offline
Old 05-20-2015 | 02:56 PM
  #8606
houston's Avatar
Originally Posted by beidle99
+1
They work awesome for throttle return
houston is offline
Old 06-14-2015 | 08:49 AM
  #8607
houston's Avatar
Lightbulb
ROAR 8th off road fuel nationals
Are we there yet? Lol
Today is get stuff ready day , good times
houston is offline
Old 06-14-2015 | 09:21 PM
  #8608
JsK's Avatar
JsK
R/C Tech Elite Member
braap...
JsK is offline
Old 06-16-2015 | 07:36 PM
  #8609
1evo RRR Driver's Avatar
Houston at the nats if my fusion needs tuning could you help me? I kno it won't. But just asking...........
1evo RRR Driver is offline
Old 06-17-2015 | 03:25 AM
  #8610
Houston gives personal service to everyone who runs his product, so I wouldn't worry if I was you he'll sort you out with the meanest tune.
Eivind E is offline
