Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 07-20-2009 | 09:11 PM
  #1096
houston's Avatar
definitely looks like that is an issue . possibly a plug filament maybe a wrist pin clip ?
if it is still running good then it is what it is and leave it alone .
looks like you are replacing with a new rod ?
houston is offline
Old 07-20-2009 | 09:13 PM
  #1097
what_stanger?'s Avatar
looks like some dirt may have gotten by the goalie to me
or what monty said
what_stanger? is offline
Old 07-20-2009 | 09:48 PM
  #1098
captain america's Avatar
The engine was bought second-hand, so I'm just going over the mill to see how bad I got shafted. It actually still gets great compression, and yes, it's getting a new rod & rear bearing, but I've learned my lesson as to buying second-hand engines.
captain america is offline
Old 07-20-2009 | 11:03 PM
  #1099
houston's Avatar
i wouldn't really buy a used engine unless it is from a reputable source
houston is offline
Old 07-21-2009 | 07:37 AM
  #1100
what brand front bearings do you recommend. i have tried a couple diffrent; bearing co off ebay and a 4c hobby and both failed after 2 weekends. the 4c leaked and seemed to let some dirt in this weekend and lost a new p/s this weekend. i do use a ofna bearing puller to remove and install.
rcjunke is offline
Old 07-21-2009 | 10:14 AM
  #1101
houston's Avatar
the best (and most expensive) front bearing on the market is the new double shield on the outside of the bearing novarossi . it is the on that comes in almost all the new nova engines . i use tko ceramic front engine bearings for replacements . i take one side of the shield off to allow the bearing to get lubricated during running . i take bothe seals off and determine which of the seals has more rubber on the inside of the seal as to make a better seal and install that seal on the side with the open balls and install in the engine .
houston is offline
Old 07-21-2009 | 03:53 PM
  #1102
hllo i am trying to find out a good plug to run in my rb ws-7111.the only turbo plugs i can get is os at my hobby shop.i am currenly running a p-7 medium os and everyone tells me it is to cold and tell me to run a p-3 can you please help me with this.thanks in advance
jmudbug is offline
Old 07-21-2009 | 04:02 PM
  #1103
houston's Avatar
if you insist on running an os plug in a novarossi style engine then i guess i would use a p4 if i was you. since you have already used os plugs in the engine , continue with using them . otherwise i would recommend odonnell 97t or 77t
houston is offline
Old 07-21-2009 | 04:18 PM
  #1104
thanks houston
jmudbug is offline
Old 07-21-2009 | 09:30 PM
  #1105
I have a question for you Monty, I currently run a +4 with the standard head, 077 plug, Nitro Juice 30%, and a DYN 053. I have only run indoor tracks so far but will be running some outdoor tracks soon. The DYN 053 has great low end (bordering on too much) and a decent top end, but for the outdoor tracks I would like a bit more up top and I would not mind giving up some bottom as I have tire shreding tq down low right now.
Would I be better off going with a turbo plug or changing to a DYN 086 pipe? I know that there are all sorts of other pipes and to be honest I really do not know the difference in most of the numbers. What would you recommend? If it is another pipe/header combo then let me know (something available would be best ).
Thanks Monty
USP45 is offline
Old 07-21-2009 | 10:32 PM
  #1106
houston's Avatar
Thanks Monty
i have about 6 dyn 086hs pipes in my box that is my pipe of choice and i haven't been disappointed on any nova engine to date
houston is offline
Old 07-22-2009 | 04:20 AM
  #1107
On a 09 +4 what is the best pipe for fuel mileage? An 053 or 086. I'm also running a 6mm restrictor.
clebo3 is offline
Old 07-22-2009 | 05:02 AM
  #1108
elkman's Avatar
Default Purple Odonnell
Hey Monty, Did you get a chance to run that Purple Odonnell plug you snagged from me last week? if so, what's the verdict?
elkman is offline
Old 07-22-2009 | 08:11 AM
  #1109
houston's Avatar
more mileage from the low end to mid pipes like an 053 . throttle finger is where the most runtime comes from though
houston is offline
Old 07-22-2009 | 08:12 AM
  #1110
houston's Avatar
this weekend at the oregon pro series race in sutherlin,OR
houston is offline
