Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 07-23-2009 | 08:56 AM
  #1126
iglu25's Avatar
Originally Posted by houston
pre production 14x25.4x6mm , '09 production versions 25.8mm
Don't take this the wrong way... but why did they go with the bigger bearing again when the old school P5's rear bearing were perfect! They lasted a lot longer than the newer ones do..
iglu25 is offline
Old 07-23-2009 | 12:39 PM
  #1127
houston's Avatar
Originally Posted by 2fst2c
How much shipped to 49007 in Michigan? Looking for 2 of them.
website or pm's for sales
houston is offline
Old 07-23-2009 | 12:41 PM
  #1128
houston's Avatar
you tell me and we'll both know
the 25.8mm bearing lasts every bit as long as the 25.4mm , its the 14.5x26mm that was silly
houston is offline
Old 07-23-2009 | 01:39 PM
  #1129
elkman's Avatar
Default Sent you a pm
Hey Monty I sent a PM to ya!
elkman is offline
Old 07-23-2009 | 02:15 PM
  #1130
2fst2c's Avatar
PM Sent
2fst2c is offline
Old 07-23-2009 | 06:22 PM
  #1131
slakr's Avatar
Hey Monty, sent you a PM with another question...
slakr is offline
Old 07-23-2009 | 06:47 PM
  #1132
rpm1968's Avatar
Share The Fun With Friends
rpm1968 is offline
Old 07-23-2009 | 06:50 PM
  #1133
stavman's Avatar
Must be nice ta have those stickers
stavman is offline
Old 07-23-2009 | 07:31 PM
  #1134
rpm1968's Avatar
The Houston Engine Service sticker makes my Ninja's run 20 degrees cooler! "Houstonova" is the man.
rpm1968 is offline
Old 07-23-2009 | 07:51 PM
  #1135
iglu25's Avatar
Come to think of it, my P5X was the one that had early bearing issues. At about the 5 gallon mark! You guys might think I'm crazy, but for a Nova 5 gallons is early to be having bearing problems.... Thanks for the info Monty...
iglu25 is offline
Old 07-23-2009 | 08:09 PM
  #1136
jonw's Avatar
Monty,
Received the motor today! Cade and I are going to break it in this weekend. The stickers are sweet too!
Thanks,
Jon
jonw is offline
Old 07-23-2009 | 09:53 PM
  #1137
houston's Avatar
i usually replace them at about 2-4 gallons just for a safety
houston is offline
Old 07-23-2009 | 09:54 PM
  #1138
houston's Avatar
Originally Posted by jonw
Monty,
Thanks,
Jon
did i include the break in instructions ? i think i might have slipped on that one , sorry
houston is offline
Old 07-23-2009 | 09:55 PM
  #1139
houston's Avatar
ENGINE RUN IN
You will have to play with the needles a little bit and cover the head of your engine with a pit towel but do 3 heat cycles within the first tank at 210 degrees (2-3 min. intervals),
at idle on stand? yes.
then run it around on the ground gently only slightly rich keeping the temp between 210-230 (monitoring temps frequently ) careful not to let the engine get into its powerband , do this for about 1 full tank at a time but do not let it run out of fuel .do this for 3 tanks (cooling in between tanks), quarter throttle or so with short blips of more (full) throttle ..not high?slow pulls on the throttle in 30-40ft bursts .
then richen the needles a bit and run it about 180-200 on the track for 3 straight tanks monitoring temps frequently(every 2 laps) leaning it out until you can start to feel the powerband (check the plug at this point and let it cool down),
what am I looking for exactly on the plug ?make sure the plug still glows and looks new, if it looks all distorted pull it out as you dont want a plug filament to go through the engine
go back out on the track,(lean out slowly) when you get it tuned in to where its not totally screaming but you have enough power to make the jumps with a slight bog at full throttle and runs at about 230 , let it cool . go out and run the rest of the gallon til the power comes up and the temp drops instantly (i call it "dropping its nuts"). this process sometimes takes more than a full gallon . use a heat gun to heat to at least 180 before you start at each step hope this helps ya , pretty detailed
I have had great success with this method and longevity , monty
houstonsengineservice.com
houston is offline
Old 07-24-2009 | 08:56 PM
  #1140
jonw's Avatar
Monty,
They were in there. After next week's ROAR race I am going to send our other +4 for bearing service and have you give it the once over before our next race. Ship out a few more stickers, hint hint.
Thanks,
Jon
jonw is offline
