Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 05-01-2009 | 08:42 AM
  #376
losi94's Avatar
Whats the best pipe and header for a 21-7.small track and in a 8ight buggy,thanks kenny
losi94 is offline
Old 05-01-2009 | 01:26 PM
  #377
houston's Avatar
i would try a 9853 w/ 41021 or ofna 053 pipeset with 8mm restrictor , runtimes on indoor tracks are usually better anyway .
if you want it to scream then use a 86 based pipe
houston is offline
Old 05-01-2009 | 01:36 PM
  #378
losi94's Avatar
Thanks alot
losi94 is offline
Old 05-01-2009 | 01:38 PM
  #379
losi94's Avatar
want the 86 hurt the bottom to much.
losi94 is offline
Old 05-01-2009 | 02:05 PM
  #380
houston's Avatar
use the 86 based pipes on your larger tracks , doesn't really hurt the bottom so much as it shifts the powerband a little further into the engines upper rpm . be careful , it will have one hellacious powerband effect with that engine fun though
houston is offline
Old 05-01-2009 | 08:34 PM
  #381
houston's Avatar
do 3 heat cycles within the first tank up to 210 degrees (2 min. intervals),at idle on stand? yes run it around gently at 210-230 (monitoring temps frequently ) careful not to let the engine get into its powerband about 1 full tank at a time , let it cool , do this for 3 tanks (cooling in between tanks), quarter throttle or so with short blips..not high?slow pulls on the throttle in 30-40ft bursts richen the needles a bit and run it about 180 on the track for 3 straight tanks monitoring temps frequently leaning it out until you can start to feel the powerband (check the plug at this point and let it cool down),what am I looking for exactly on the plugmake sure the plug still glows and looks new, if it looks all distorted pull it out as you dont want a plug filament to go through the engine go back out on the track,(lean out slowly) when you get it tuned in to where its not totally screaming but you have enough power to make the jumps with a slight bog at full throttle and runs at about 230 , let it cool . go out and run the rest of the gallon til the power comes up and the temp drops instantly (i call it "dropping its nuts"). this process sometimes takes more than a full gallon . use a heat gun to heat to 200 before you start at each step
hope this helps ya , pretty detailed
monty
do it just like i said and you will have great success[/quote]
houston is offline
Old 05-01-2009 | 08:48 PM
  #382
SPEED37's Avatar
Perfect timing on that last post Monty
SPEED37 is offline
Old 05-01-2009 | 10:47 PM
  #383
SNIDE's Avatar
Originally Posted by houston
thanks jay
you gonna race again now ?
Yessir.....cant wait man!!!!
SNIDE is offline
Old 05-01-2009 | 10:54 PM
  #384
Joe_Racer's Avatar
Hi Monty,
I was wondering, you said if you over tighten the head bolts you can warp the case. Just how tight should they be? I got that Hudy screwdriver for the Novarossi head bolts you were showing me, very sweet.
Thanks for the info.
Joe_Racer is offline
Old 05-01-2009 | 11:52 PM
  #385
houston's Avatar
Originally Posted by Joe_Racer
Hi Monty,
kind of hard to describe without some kind of in./lb. spec. over the internet . just dont reef the holy begeezez out of them and tighten them in a cross pattern evenly .
houston is offline
Old 05-02-2009 | 05:47 PM
  #386
houston's Avatar
i will get the orings and all the goodies gathered up as quick as i can Jack .
houston is offline
Old 05-02-2009 | 07:18 PM
  #387
losi94's Avatar
how about factory crab settings for a 21-7 and whats the best glow plug
losi94 is offline
Old 05-02-2009 | 08:53 PM
  #388
houston's Avatar
i hope your engine doesnt have crabs
4 turns out hsn , 3.5 turns out on lsn w/ 1.5mm idle gap
standard glow plug odo77 or 99
mccoy mc8
houston is offline
Old 05-02-2009 | 11:33 PM
  #389
Following your advice to usp45 in the plus 4 thread here I am.Flush the lapping compound before breakin of not? I usually remove back plate, fill with fuel,swoosh & dump a few times before breakin.More dissasembly needed or no? I also went back & found casey's idle screw spec but Dont know if I'm comfortable with that outside measurement whats the slide gap at,inside the carb? Thanks for the help.
butch man is offline
Old 05-02-2009 | 11:42 PM
  #390
slumlord's Avatar
Monty, was running the 528 tonight and noticed fuel coming from where the button is bolted to the crank case. What do I need to do to fix that?
slumlord is offline
