Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 04-28-2009 | 08:05 PM
  #361
houston's Avatar
Originally Posted by Alan D.
I thought the Dynamite 086 was badass.
dynamite 086hs is always awesome on any engine
houston is offline
Old 04-28-2009 | 10:58 PM
  #362
houston's Avatar
Originally Posted by PIMP_9000
Monty thanks for the help in getting me going in the right direction. I will be in touch again soon.the engines we talked about were them turbo plug? I would prefer turbo let me know what you think. Pudding pops all around
no prob puddin pop
i could make any engine anyway you want it ,
custom built engines .
houston is offline
Old 04-28-2009 | 11:13 PM
  #363
SNIDE's Avatar
Houston is the Burger.....I mean Engine King!
Have it your way...
SNIDE is offline
Old 04-28-2009 | 11:43 PM
  #364
houston's Avatar
Have it your way...
thanks jay
you gonna race again now ?
houston is offline
Old 04-29-2009 | 12:45 AM
  #365
air8's Avatar
Hey Monty,
do you happen to remember how much head clearance should be used on the Plus 21-5(non-K version) using 30% fuel? Seems I've mis-placed my original shim stack so I need to order some more.
thank you sir
chris
air8 is offline
Old 04-29-2009 | 04:13 AM
  #366
losi_racer's Avatar
hey monty, can you pm me a price to buy a +4 and break it in for me? its going to be a while but just wondering
losi_racer is offline
Old 04-29-2009 | 05:21 AM
  #367
Nitro$junkie's Avatar
Originally Posted by houston
sho' 'nuff is
WTF ENGLISH PLEASE
Nitro$junkie is offline
Old 04-29-2009 | 06:49 AM
  #368
Trevor Williams's Avatar
R/C Tech Elite Member
Originally Posted by Nitro$junkie
WTF ENGLISH PLEASE
easy' hoss
Trevor Williams is offline
Old 04-29-2009 | 04:40 PM
  #369
Hey houston, Please could you explain what/how pipe and header setup affect fuel mileage, 'e,g Low end pipe long header = more fuel mileage?',
Thanks.
mark-rc is offline
Old 04-29-2009 | 05:24 PM
  #370
houston's Avatar
Originally Posted by air8
Hey Monty,
thank you sir
chris
same as almost all nova engines - .70mm total , i recommend .80mm . two alu. .30mm shims and two .10mm copper shims or one .20mm copper shim . copper shims come in all different sizes so you must measure with calipers
houston is offline
Old 04-29-2009 | 05:26 PM
  #371
houston's Avatar
http://www.rctech.net/forum/5397376-post1.html
here are prices
houston is offline
Old 04-29-2009 | 05:29 PM
  #372
houston's Avatar
Thanks.
sounds like you got it already , the upper end pipes release the upper rpm's of an engine and expell more fuel by doing so . the low end pipes restrict the high rpm range of the engine and make it run more efficiently creating better fuel mileage . port designs and throttle finger have alot to do with it also
houston is offline
Old 04-29-2009 | 05:31 PM
  #373
houston's Avatar
WTF ENGLISH PLEASE
i am sorry junkie , sure enough is is what i said . chillax yizo
houston is offline
Old 04-29-2009 | 07:16 PM
  #374
yeah man no probs just wanted some info thats all, would the header from a O.S. 2060 be the same? (a medium manifold)
Old 04-29-2009 | 07:34 PM
  #375
houston's Avatar
it looks close anyway , I dont use too many os products
houston is offline
