Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 04-24-2009 | 06:19 PM
  #331
houston's Avatar
3 plus 4's ready to ship guys
houston is offline
Old 04-25-2009 | 02:18 PM
  #332
houston's Avatar
3 plus 4's nib ready to go
houston is offline
Old 04-25-2009 | 03:33 PM
  #333
mrramirez's Avatar
you have a pm.
mrramirez is offline
Old 04-25-2009 | 03:51 PM
  #334
houston's Avatar
back at ya Sal
houston is offline
Old 04-25-2009 | 05:49 PM
  #335
I have a new bf21 limited and started the brake in useing odonnell 99 and used a heat gun that went fine. My problem is keeping the temps above 200 , don't want to lean it out too much without even 2 tanks through it. Any answers would be great.
thanks
phoenix357 is offline
Old 04-25-2009 | 07:04 PM
  #336
houston's Avatar
thanks
wrap the head in a towel or a beer cooler or tire foam or anything that will stop the heat from dissipating from heatsink. 210-220 is optimal heat range for run-in period but 200 is pretty close hopefully you got a bf limited ? the bf limited is an awesome engine with all the qualities of the expensive mill without the quality pricing
happy motorin',
monty
houston is offline
Old 04-25-2009 | 07:20 PM
  #337
Joe_Racer's Avatar
Hey Monty,
What are the stock settings for the high and low speed needles on a plus 21-5k. I just put a new P/S/R in mine and need the settings for break in. I will be sending you the P/S/R that I PM'd you about in a few days.
Joe_Racer is offline
Old 04-25-2009 | 07:24 PM
  #338
houston's Avatar
Originally Posted by Joe_Racer
Hey Monty,
stock settings are super rich 1.5mm idle gap , 3.5 turns out on lsn, 4.5 turns out on hsn . race tune is close to .75-1mm idle gap , 1.75-2 turns out on lsn and 3-3.75 turns out on hsn '
houston is offline
Old 04-25-2009 | 07:34 PM
  #339
Joe_Racer's Avatar
Thanks Monty, You the MAN.
Old 04-25-2009 | 07:46 PM
  #340
Ya monty it's a limited but man stock setting is supper rich couldn't hardly get it to run ! I'll try wrapping it up, but it was 84 out side and I heated the block up to 190. I am running 25% with the 99 plug and an ofna 086 pipe just gotta get them temps up.
Thanks man
Old 04-26-2009 | 07:34 AM
  #341
Trevor Williams's Avatar
R/C Tech Elite Member
hi bud...hey man, if you so kindly would........please explain the use of carburetor restrictrors.......when, why and where to use what sizes would be awesome. I am aware of what they are intended to do, Im just not sure on correct applications.
Trevor Williams is offline
Old 04-26-2009 | 09:07 PM
  #342
houston's Avatar
they are basically air/fuel ratio mixers , think of it as running anywhere from lets say a 325cfm carb (6mm) on your 454 big block (power loss for sure) , but it will run efficient with excellent fuel mileage . if you want more power and more fuel consumption use a 1000 cfm carb (9mm). granted there are a few more variables on these big block nitro engines we love so much but that should put it in perspective i hope
houston is offline
Old 04-26-2009 | 09:15 PM
  #343
cool man, thanks. I used a 6.5 today, going to take it out and put 8mm back in and retune accordingly. I think it will help on backstretch. I want all the power I can use in the right places
Old 04-27-2009 | 08:31 AM
  #344
Eccentric's Avatar
Default Got another Q for you Monty...
What changes were made between the original P5, the P5X, and the P5XS? How did they affect permance and powerband? As usual, I'm interested in truggy power. Don't fret, I'm still saving $$$ for one of your rebuilt/tuned engines...
Eccentric is offline
Old 04-27-2009 | 03:55 PM
  #345
cweb's Avatar
Monty, I am sooooo glad I got that pipe from you. Gett'n crazy fuel ecconomy on my V-spec, Thanks again.
Got a question about a Picco 26 if you can help. I need a pipe combo that will help me tame that bottom end. runn'n a JP-1 now and the thing has way to much bottom end, and the fuel mileage stinks. Thanks in advance man.
cweb is offline
