Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 08-11-2009 | 11:25 PM
  #1276
houston's Avatar
Originally Posted by air8
Hi Monty, quick question. When you do the R2R break-in, are the engines run until "the nuts drop"? Or should I expect "the nuts too drop" some time soon? I should have asked you over the phone when I ordered the engine.
thanx
chris
i would have to charge alot more to run each engine 1.5 gallons which is usually around the area where this happens but the r2r is 3/4 to 1 gallon of fuel of a proper run in . i dont rev the engine out really hard during this time but usually tune the engine in good enough to run races
houston is offline
Old 08-12-2009 | 11:12 AM
  #1277
air8's Avatar
Ok sweet. I just didnt' know if I should expect it or not. Thanx man.
air8 is offline
Old 08-12-2009 | 05:24 PM
  #1278
2fst2c's Avatar
Hey Monty, on the P5X head buttons there are dimples. On my standard button there are 3 in a row and on the turbo's there is 2 on one side and 3 or 4 across from it. Do the 3 go over the exhaust port? Also, what is the reasoning for this? I was thinking it was for indexing the plug in the chamber but I'm not really sure. Thanks!
2fst2c is offline
Old 08-12-2009 | 06:44 PM
  #1279
houston's Avatar
no reason really , it is a cylinder which doesn't really need any indexing but novarossi installs the most dots towards the exhaust
houston is offline
Old 08-13-2009 | 05:34 AM
  #1280
2fst2c's Avatar
Ok thanks!
2fst2c is offline
Old 08-14-2009 | 06:34 PM
  #1281
rockfordccinc's Avatar
Default plus 4
im getting a plus for and exhaust set ready to race!!!! Cant wait to get this engine and pretty much be ready to go to the track!!!!
rockfordccinc is offline
Old 08-14-2009 | 06:53 PM
  #1282
air8's Avatar
Monty are you still finding the Nova 41005 ] header to work pretty good with a Dyn053 pipe?
air8 is offline
Old 08-14-2009 | 07:57 PM
  #1283
houston's Avatar
houston is offline
Old 08-14-2009 | 07:58 PM
  #1284
houston's Avatar
ya , or just use the ofna one
houston is offline
Old 08-14-2009 | 08:03 PM
  #1285
slaytanic's Avatar
Monty my mill showed up today and is in my 808 and ready to rock. Gonna run it bit tommorow to make sure it's good for the weather here. Thanks a bunch for the KILLER service! I'll be leaving a nice note on your site.
slaytanic is offline
Old 08-14-2009 | 08:27 PM
  #1286
houston's Avatar
thanks matt
enjoy , call if you need anything
houston is offline
Old 08-15-2009 | 11:06 AM
  #1287
houston's Avatar
Originally Posted by houston
j
try 3.5 turns out on low speed with barrel pulled out and 3.75 turns out on high speed on the older carbs
drake is gonna be doing a tutorial on how to tune the new carbs sometime soon
houston is offline
Old 08-15-2009 | 08:22 PM
  #1288
slaytanic's Avatar
Got a tank through the 21-5 this evening finally. After 10 minutes it temped 235-240. Wound out real nice without really pushing it too much. I felt "electric" smooth!
It's supposed to be 90's and hmuid as heck tomorrow. Any suggestions Monty?
Old 08-15-2009 | 09:24 PM
  #1289
houston's Avatar
little rich on the bottom and dont drop your idle too low
what did you think of the engine
houston is offline
  #1290
houston's Avatar
plus 21-5 is still my favorite buggy engine
houston is offline
