Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 03-07-2016 | 10:45 PM
  #8746
Default X3 little help
Engine runs great, broke in as per montys method with help from chuck janke, engine is hard to start, always preheat to 180 - 200, almost a gallon on it, thing runs incredible once fired, but it's hard to get started after its cooled awhile and pre heated, never a flame out, changed plugs a few times.
jp_hotwheels is offline
Old 03-08-2016 | 10:11 PM
  #8747
houston's Avatar
Check pressure line and nipple in pipe to make sure its clear
Check tank pressure by filling tank half way with fuel , unhook fuel line from carb ,blow through pressure line
Should be fairly ez to get fuel to come out without blowing too hard
All that's good.....get back to me
houston is offline
Old 03-13-2016 | 12:43 AM
  #8748
houston's Avatar
Cant wait man
More rc car racing at the silver state !!!
Engine guy who races ,brrraaaap rc cars
houston is offline
Old 03-14-2016 | 06:55 PM
  #8749
jeromerc's Avatar
Good luck at Silver State Monty!
jeromerc is offline
Old 03-15-2016 | 07:42 PM
  #8750
hookem34's Avatar
R/C Tech Elite Member
Monty,
You going back down to Austin for the NATS this year?
hookem34 is offline
Old 03-16-2016 | 08:04 AM
  #8751
houston's Avatar
Originally Posted by hookem34
Monty,
Not 100% but its possible
houston is offline
Old 03-24-2016 | 04:25 PM
  #8752
houston's Avatar
Even after a certain manufacturers product had let me down at silver state this year i still had an awesome time !!
Hanging with racers i dont get to see often enough and racing my rc cars on a badass track ...priceless
Btw , the manufacturer product that failed ......they have compensated me well for ruining every amain run and 1 qualifier
I am going to give the manufacturer one more shot as they are such great people i am going to put my trust in the people of the company. There could be great things to come from this manufacturer
houston is offline
Old 03-24-2016 | 05:59 PM
  #8753
jeromerc's Avatar
That did seem odd, as the reviews I read were better than your results. Hope next time it is a better outing for you bro. Can't wait to meet up in July, I just wish it would get her sooner. Gonna need a new engine for my new kit Loved the x5r filled last time, gonna get another one and maybe two, get rid of the orion on the wifes buggy
jeromerc is offline
Old 03-29-2016 | 04:29 PM
  #8754
PaulNZ's Avatar
Hey there,
Can anyone point me in the direction of an "engine maintenance bible"? Everyone at my track does it differently, including doing nothing and this seems to be the only forum where everyone generally agrees!
Some key questions I have are;
How often should I pull down my engine to clean/inspect it?
What should I be looking for when I do e.g what should/shouldn't my piston look like, do I need to be able to read my glow plug?
What should I use to clean the internals and how clean does it need to be.
How often should I replace the bearings, conrod, piston, sleeve.
What don't I know that I should consider?
Cheers.
PaulNZ is offline
Old 03-29-2016 | 05:40 PM
  #8755
jeromerc's Avatar
Originally Posted by PaulNZ
Hey there,
Cheers.
That's a good question, hopefully Monty can shed some light on it. I know an on road racer in Singapore that pulls apart his engine after every run to inspect it, and I mean all the way apart. I personally feel this is too much. I usually pull mine apart after a couple of races, usually once a month depending on how many times I run. If I haven't ran an engine in a while I will pull it apart and give it a spin to make sure everything looks good before running it.
jeromerc is offline
Old 03-29-2016 | 07:47 PM
  #8756
Palebushman's Avatar
Hey there,
Excellent question PaulNZ
BUT......... Those that have all the best knowledge and necessary experience for 'Servicing' RC engines, also run very successful businesses in this specialised field.
Not too sure about their willingness to give away all that for nothing in an Internet forum.
We may get lucky, who knows?
Usually though, regularly replacing your 'oiled' air filters, cleaning your fuel filters, use of 'After-Run Oil', regularly checking your glow plug and using fresh fuel, will usually keep your well tuned engine in good running order, long before you will need the experts to 'Tear-Down' your engine for a thorough 'Overhauling/Servicing' or refurbishment.
Palebushman is offline
Old 03-30-2016 | 01:18 AM
  #8757
PaulNZ's Avatar
Yeah totally get what you are saying Palebushman, I guess i would be hesitant sharing all my knowledge in a my area of expertise too!!
Doesn't hurt to ask though
PaulNZ is offline
Old 03-31-2016 | 04:35 PM
  #8758
houston's Avatar
No way guys
Its like this ,if you feel comfy working on your own engine without f'ing it up ......gitrdun
There are some delicate parts in there though
Honestly ....i run byrons ...i never run my engine out of fuel/oil ....i leave my cars pointed nose down after a race so rear bearing doesnt get messed up .... be gentle on it when refiring
I replace rods every 4.5 gallons ... bearings as necessary ... no real measure of fuel imo ... glow plugs yes you need to leafn how to read for your tune ...just because it glows doesnt mean its good ...make sure coils arent pushed/pulled.. make sure filaments not pitted or dull ,if it is replace it ...its not a contest to see who can make a glow plug last the longest ...imo if you tell me "this glow plug lasted 2 gallons" youre an idiot , replace at most every half gallon .
I hope this helps
houston is offline
Old 03-31-2016 | 08:34 PM
  #8759
PaulNZ's Avatar
[QUOTE=houston;14472031]No way guys
I hope this helps[
Thanks Houston, kinda confirms what some of the guys at my track have said and what I have pick up going through the forums.
Cheers.
PaulNZ is offline
Old 06-14-2016 | 11:17 PM
  #8760
jeromerc's Avatar
Hey Monty, I know you are back from California now, do you have any of those awesome kyosho pit bags left???
jeromerc is offline
