Houstons Engine Service H.E.S.
#8462
What we have found is that when you use a rubber band it can cause issues with the binding of the carb slide in the body. At least on the nova rossi carb tried it on did. I am just concerned about putting a load on the carb slide that prevents it from pulling straight could cause problems down the road. Maybe I am wrong but that is how feel and see it.We are using hair bands on our engines.
Monty what are your findings and thought's?
I will not even install an engine without them
I can see where racers might be having issues , if not installed so the bands are putting very lil to no side pull on carb ball they will probably cause some binding
All in all im for goodys silicone hair bands ,rubber bands are not throttle return springs ,lol
#8464
My wife has long hair and I always nip a few from her stash of hair bands for my engines
#8466
Most excellent times at the byrons heartland challenge race at the hobbyplex in omaha,ne
This place is a great facility with great people
Thanks to all who help support
#8467
Houston.. I was preparing my car for the race tomorrow, and I discovered the engine was wet with fuel and crud from the bottom of the crankcase up to half way up the carburetor body. Basicly from the front bearing and back an inch, and from the front bearing and up half an inch.
Am I correct in assuming the front bearing is done for?
#8468
And yes more than likely Eivind
#8471
#8472
That wasn't my post. I emailed you from your website asking for your phone number but found it elsewhere. Gave it to my buddy and he called you yesterday about getting us a couple engines, pipes, and clutches.
I appreciate you taking the time yesterday to help us get everything figured out and headed the right direction. Can't wait to get the engines in!!
#8473
#8474
22Likes
