Houstons Engine Service H.E.S.
#6571
#6572
What's everybody's take on exhaust gas coolers? And if you do run them do you just cut your 8" pressure line and install or do you trim the pressure line to say 6" and install the 2" cooler for a total length of 8"? Or are they a waste of money?
#6574
Pretty much a waste a money if you ask me... Sure it will make your gas cooler but the effect on your run time will be very slime to none. One thing you can do if you really want to cool your gas is to put some insulating tape on your gas tank facing your pipe. I would probably try the tape first before spending 40ish $ on a exhaust gas cooler...
#6575
#6576
#6577
If I may suggest. the plus-4 has a slightly touchy low speed needle, it does not take much to change the tune, very small adjustments compared to the top end. Take it slow and run it a little between adjustments.
#6578
#6579
#6581
I just installed the Super Blue Silicone medium sized fuel tubing, It's part number 222 on the top right of the card. Fits nice and tight over the nipples.
Just measured some with the calipers and it is confirmed at 3/32"
#6582
My plus 4 lsn changes the idle almost instantly when adjusting it. Only takes 1/24th of a turn either way to get it in its sweet spot when its close to optimum. HSN too!
#6583
Almost every nova offroad engine has the same carb now , lsn tuning video by bernard durand is a must see
Novarossi diesnt necessarily go with the "set the idle gap to ?" Method
22Likes
