Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 12-09-2012 | 12:40 AM
  #7321
houston's Avatar
Originally Posted by BigNasty
tent city is coming, Monty. Be afraid!
Me afraid? Come on now , I think you know me better than that Chris
I might pit there we shall see
houston is offline
Old 12-09-2012 | 04:10 AM
  #7322
jeromerc's Avatar
Monty, I know you are not a losi guy but my damn truggy kills rear diffs. I know they are shimmed correctly because i do the same on my losi buggy and havent lost one yet and i used to run it onroad with monster grip. Today i got lucky and finished third but blew both pinion bearings in the last 3 minutes. I think at 1/2 the price i will run my buggy diffs in the truggy, but if you have any suggestions on how to check the shimming i would greatly appreciate it
jeromerc is offline
Old 12-09-2012 | 07:52 AM
  #7323
revo61's Avatar
A friend of mine has had the same problem with his losi truggy. 3 dnf's in a row. He is ditching the losi for next season.
revo61 is offline
Old 12-09-2012 | 08:45 AM
  #7324
Default Fuel Filter Flow
Originally Posted by redliner140
Monty, which way does the fuel flow thru a inline filter? I know you posted it before but can't seem to find it. Thx
Monty, can you help? My filter has a bronze sintered piece. Thanks
redliner140 is offline
Old 12-09-2012 | 10:28 AM
  #7325
houston's Avatar
The inlet would be the side with the bronze/brass filter that sits in the cavity
I have seen people use em both ways with no ill effects though
houston is offline
Old 12-09-2012 | 10:35 AM
  #7326
PERROTTO's Avatar
Some of the guys around here were having that problem as well and found out it was aggressive braking causing issues with the rear diff
PERROTTO is offline
Old 12-09-2012 | 04:48 PM
  #7327
jeromerc's Avatar
Thanks, I have never heard of that before It does make sense though because I am sure that with all the problems people have with the Losi truggy, it is always in the rear diff, if it was only the gears you would think there would have been enough r&d for an update to fix the problem. As for the shimming, but I have heard to shim so tight it feels notchy. I might be a bit hard on the brakes so I will definitely look into that, but I never have my brake bias set tight, I guess I will loosen the rear breaks up a bit and watch my braking style.
jeromerc is offline
Old 12-10-2012 | 10:45 AM
  #7328
GREGORY!'s Avatar
hello!one question.how much increase in the rpm that max torque is delivering can i expecting with 10mm-11mm shorter manifold and the same pipe?4-5krpm?
GREGORY! is offline
Old 12-10-2012 | 04:05 PM
  #7329
houston's Avatar
Probably that much rpm in the upper ranges gregory but at the sacrifice of some torque
But every engine has its sweet spot of course which is known by trial and error
houston is offline
Old 12-10-2012 | 05:11 PM
  #7330
Here are some tips:
-Replace ring and pinion at the same time.
-When the r&p are brand new, shim the ring gear so that there is a one notchy spot when the gearbox is assembled.
-Run a tank gently, check mesh, and re-shim as necessary. You may have to move a thin shim from one side to another.
-Rear brakes should barely lock up. The losi truggy has a ton of steering, so if you need a ton of rear brakes to rotate the truggy, then something may be wrong with your setup.
The aluminum gearbox inserts are not really necessary, but some swear by them. Keep in mind that the gearbox plastics does fatigue over time, so occasionally replacing them is good insurance as well.
071crazy is offline
Old 12-13-2012 | 09:35 AM
  #7331
houston's Avatar
Lightbulb
I never spent any major time with the losi trucks Jerome but I do know many guys who run them and the ones who don't have ring and pinion problems all have the aluminum inserts
houston is offline
Old 12-13-2012 | 10:14 PM
  #7332
jeromerc's Avatar
Thanks guys, Drake sent me an email, I am shimming them correctly, at least what he saw and he is going to try and help get the issue fixed. I guess notchy is the best, it was how I had the best results, and with this last set it wasn't the ring and pinion but brand new bearing failures
jeromerc is offline
Old 12-14-2012 | 09:16 AM
  #7333
You should really consider replacing the gearbox plastics, even if you are using the aluminum inserts.
071crazy is offline
Old 12-14-2012 | 11:04 AM
  #7334
Pm'ed ya Monty!
MFigueroa is offline
Old 12-15-2012 | 07:05 AM
  #7335
From: Lake View Terrace, CA. ~ Where Rodney King got his Asswoopin!
Default Help
Please help me raise awareness. Please watch the video & read the story! Even if you only watch the video. I Thank You ~Keith
https://www.youtube.com/watch?featur...&v=p6-u6hWzGw4
https://www.facebook.com/BillFoundationDogRescue
chiefin on 420 is offline
