Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 12-03-2012 | 08:47 PM
  #7306
kgombe's Avatar
you guys are cool
kgombe is offline
Old 12-04-2012 | 05:01 AM
  #7307
jonw's Avatar
It's funny you mention that Monty, we experienced that bog this weekend and it was really getting to me. Our tune was was really good but we kept having that little low end bog. Maybe aluminum shoes are the way to go on a high bite clay surface in truggy? Thanks for the tip! FYI, we are kicking the idea around about going to the Nitro Challenge.
Originally Posted by houston
Oh the dreaded "poor tire choice" whoas :
Glad your engine ran like a champ though , better luck next time bro
Yes , in buggy the buku is no joke , if there is too much traction it can be hard for the komposite material to stay cool and keep a positive engagement without a bog in the truck.but otherwise it's spot on
jonw is offline
Old 12-04-2012 | 06:30 AM
  #7308
houston's Avatar
I will switch to a werks clutch in the truck if there is too much traction , buku 100% in the buggy
houston is offline
Old 12-04-2012 | 06:55 AM
  #7309
jonw's Avatar
Don't have that option haha.
jonw is offline
Old 12-04-2012 | 07:42 AM
  #7310
THE PHILLY JYNX's Avatar
If you have high traction and a bog in the truggy there are a couple ways to correct this. You need to put slippage in the clutch because there is a lack of tire spin do to excess traction. The motor is being over loaded. and cant pull the extra load of the truggy compared to buggy. Now when i say slippage this does not mean go and increase the spring rate on all 3 shoes. Because that's going to give you the same initial result and then the clutch is going to over heat and start slipping .What you want to do is soften the spring rate on shoe #1 (engage sooner) then increase the spring rate on shoe #2. Shoe #3 you want to also increase the spring rate but make sure its increase so there is more tension(larger ratio) between the 2nd and 3rd shoes than what you started with your base setup. In other words make the clutch more progressive by making a larger spring ratio's between all 3 shoes. You need to build some ground speed before having the torque of all 3 shoes engaging. On a side note...This is also the EXACT same thing you would want to do if you found yourself on a track that was super loose, dusty or slippery and your buggy or truggy was lacking traction and difficult to drive .
SECOND thing you can to is run lighter Komposite shoes. Less weight equals less torque delivery from the clutch.
SHORT STROKE MOTORS...I have seen cases were SS motors in truggy pull the komposite shoes fine for 4-8 minutes once the motor is fully up to race temp and chassis saturated a bog will start to develop and progressively get worse.The bottom end falls of like you are lean on button. With that case you would want to run aluminum shoes. SS design just doesnt have the bottom grunt of a LS motor and depending on the exhaust port timing/pipe header combo it just cant handle the load with Komposite shoes. Hope this helps
THE PHILLY JYNX is offline
Old 12-04-2012 | 07:57 AM
  #7311
jonw's Avatar
Thanks for the info! This clutch has been a very good addition to our race program and a very great tuning option. Top notch support too.
jonw is offline
Old 12-06-2012 | 07:05 AM
  #7312
jeromerc's Avatar
Monty, I am going to run the buku on my mugen for now, but I do have a question about the novarossi engines. What is the deal again with the glow plugs?, can I ron nova, and odonell? what about rd and orion? is there a difference in the 1/10 glow plugs? starting my break in of my bonitto, hopefully I will get it done by Sunday, have about a 1/2 gallon through so far.
jeromerc is offline
Old 12-06-2012 | 09:22 AM
  #7313
stavman's Avatar
you didnt miss anything KC , i am just bein silly
we need to get the CRE "MASTER" to a "REAL" race though to shed some light on his thoughts and opinions
he is reading all this and hopefully shows up to the nitro challenge
heck i even got some Australia boys coming
Originally Posted by Carwreck
Hey Horn Tooter you never called!!!! Check FB in about an hour details are coming about Team PIB/One Hobbies Tent City at The Nitro Challenge!!!!
Even the Historic and always Self Proclaimed Professional Driver "Stav" should be attanding The Nitro Challenge... and Team PIB/One Hobbies Tent City
Should be a HOOT......
Hey Houston bring a Flashlight Car down.. we are gunna have a race the weekend Before.... and tell all yer friends..
oh and Pimp us out For Parts and Tires... looking to bring SUPPLIES to the Track....... Just Like Old Times
I hear yer driving again this year... be careful... The Stavros Hilton only has room for 1 Houston..... Just saying
Miss ya bro......
Stav
stavman is offline
Old 12-06-2012 | 09:58 AM
  #7314
houston's Avatar
Hotel'n it boss
Bringing my old man
And I am not wrenchin your cars!
houston is offline
Old 12-07-2012 | 12:21 PM
  #7315
Monty, which way does the fuel flow thru a inline filter? I know you posted it before but can't seem to find it. Thx
redliner140 is offline
Old 12-07-2012 | 04:33 PM
  #7316
nitroexpress's Avatar
Do you have a screen mesh or a sintered bronze element inside the housing?
nitroexpress is offline
Old 12-07-2012 | 04:47 PM
  #7317
Sintered bronze element.
Old 12-07-2012 | 06:30 PM
  #7318
GREGORY!'s Avatar
guys?when you put a small venturi on the carb how i set the end point at the throttle?full,or a little more from the hole's end?i think that in second way i will have a very lean middle area.
GREGORY! is offline
Old 12-07-2012 | 07:07 PM
  #7319
PERROTTO's Avatar
GREGORY!!!!!!!, once you get the throttle to open up the exact same as Venturi, go 1 or 2 more clicks on EPA.
PERROTTO is offline
Old 12-07-2012 | 07:40 PM
  #7320
BigNasty's Avatar
tent city is coming, Monty. Be afraid!
BigNasty is offline
