Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 04-02-2011 | 07:27 PM
  #5071
houston's Avatar
Originally Posted by NitroFreak2
Hey Montey,
Is nova discontinuing the Toro Nero? Replacing it with the bonito?
yes they already have , the engines are so close to identical besides the aesthetics that you wouldn't be able to tell them apart
i have one bonito and one toro team left
houston is offline
Old 04-02-2011 | 08:08 PM
  #5072
kgombe's Avatar
Originally Posted by houston
you cant have an engine ready in 2 1/2 weeks ?
you have quite a few engines Kijana , toughest part for you is deciding which one to run
i would have to say i would prefer the X7 over the fms Bill
man for to break my engine in i have to go to a parking lot and its not certain that i will get it done.. and yes i have quite a few.. im selling all my OS stuff... if anyone is interested
kgombe is offline
Old 04-02-2011 | 09:10 PM
  #5073
dakilo's Avatar
houston
you got PM
dakilo is offline
Old 04-02-2011 | 11:15 PM
  #5074
Teufel Racing's Avatar
OK Monty,
Part two of my brain teaser series. LOL. Saw on another thread you were going to provide info on the filled cranks. Looking to hear what you have to say on that. The main reason for the post is headers. As to which one to use and why? What will changing from one type to another do and not do to or for the powerband. Hopefully this won't require the huge ammount of typing for you.
Oh and the new Blue heads, what would one of those run should I want one to be different.
Teufel Racing is offline
Old 04-03-2011 | 08:38 AM
  #5075
PERROTTO's Avatar
Default HELP! anyone and everyone
OK i have a novarossi plus 4c and a novarossi fms "team". when i come in for a pit stop and fuel it up with a bottle and throw it back out it will run fine until the first corner and then flame out. i know it is richening up drmatically because when i start it up again i have to clear it out. i am running the fms in my truggy and the plus 4 in my buggy. both mugens with a clunk modification and the tank is 100% sealed...im sure of that. i was told that the low end may be too rich but if i lean the low it will not run the way i expect it to. both of these motors will idle through a whoile tank if i let them so i know the tune is very close. seems to me if the low speed needle is the cause then it must be off tune quite a bit......Please anyone and everyone give your input. btw both of these motors are in immaculate condition as far as the internals. boths have been reworked by mr houston himself with the help of raya racing resizing about a gallon ago.
PERROTTO is offline
Old 04-03-2011 | 08:44 AM
  #5076
houston's Avatar
Lightbulb
Originally Posted by Teufel Racing
OK Monty,
On this one I will say read back on the bazillion posts that this has been explained already lazy focker!
You should get the whole X7
performance difference wise,filled vs. unfilled is not a huge difference, there is a minor advantage to the filled crank in low end throttle response but in my experience the filled crank also brings the engines idle down to a smoother idle quicker and more consistently, you won't get as much of the two/three stage idle sh!t.
be careful who you have fill your cranks and resize your sleeves these days, everybody and their brother thinks they are experts at it
houston is offline
Old 04-03-2011 | 08:47 AM
  #5077
kgombe's Avatar
if its happening on both your engines i would try a newer plug.. or maybe try some other fuel...
just a suggestion if its happening on both your engines
kgombe is offline
Old 04-03-2011 | 09:23 AM
  #5078
PERROTTO's Avatar
Using byrons 30% with 11% oil. C6tgc in plus4c and c6tgH in Fms. Both new at beginning of day. I will try some 97 t plugs and go from there.
PERROTTO is offline
Old 04-03-2011 | 09:53 AM
  #5079
kgombe's Avatar
ok try the 97t.. when i say other fuel. i meant like form a fresh bottle... just a test... to see if it makes a difference
kgombe is offline
Old 04-03-2011 | 12:05 PM
  #5080
Huh, thought I mentioned something about a 97T yesterday at the track And I still think your rich on the bottom but you can't tell because you have it masked with to large of a idle gap...
WideOpenThrottle RC is offline
Old 04-03-2011 | 12:39 PM
  #5081
kgombe's Avatar
well to large an idle gap will definitely cause that to happen
kgombe is offline
Old 04-03-2011 | 12:41 PM
  #5082
houston's Avatar
Figure it out for yourself froto and you will learn for yourself what makes that happen
That's the way you personally learn bro
houston is offline
Old 04-03-2011 | 08:15 PM
  #5083
PERROTTO's Avatar
I always check and set idle gap.. .7mm. And actually the motor blew up today. Brass bushing on bottom of conrod disintegrated inside of motor. Was wondering y I went through 3 plugs the past half gallon. Conrod cracked slightly by bushing. Not too bad after about 12 gallons.
PERROTTO is offline
Old 04-03-2011 | 08:17 PM
  #5084
kgombe's Avatar
12 gallons.... hey time for a new motor....
kgombe is offline
Old 04-03-2011 | 08:27 PM
  #5085
PERROTTO's Avatar
This motor was hard to let go of. So much power and reliability until recently.
PERROTTO is offline
