Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 04-06-2011 | 05:22 PM
  #5101
houston's Avatar
Originally Posted by nick64merc
Monty, I have a question about the shims in a Stock FMS. I looked at my motor last night and it has two aluminium shims and one brass one. I remember reading somewhere on hear that you suggested to remove one of the shims. The motor runs good right now, but I was wondering if I should go ahead and take one of the shims out?
Nick
Brass? Did u get it from me Nick?
If you did I shimmed it at .75mm, brass is .15mm
That should be just fine, you can replace the .15 for a .10mm after 4 or 5 gallons and it will help you out, do not go any lower than .60mm which is two aluminum
houston is offline
Old 04-06-2011 | 07:51 PM
  #5102
any GREAT deals on those 2084's?
RockStar_199 is offline
Old 04-06-2011 | 08:43 PM
  #5103
houston's Avatar
What is considered a great deal? For some reason pipes went up
houston is offline
Old 04-06-2011 | 09:18 PM
  #5104
Lille-bror's Avatar
Hi.
Perhaps I can help a little with the shim question:
One of my engines (not Novarossi) I use 20% nitro from the very first tank of fuel and stock shimms (shimmed for 25% nitro). Last year I had 1½ gallon through it. It ran really great without any issues. Here in March, I couldn't get the throttle respons perfect. Then I removed a 0,2 mm shim, and that made all the difference.
Perhaps you guys can feel the same thing, when your engines starts to have a flaccid acceleration
...Or Monty can correct me
Lille-bror is offline
Old 04-07-2011 | 10:10 AM
  #5105
I did not buy the FMS from you it is bone stock and right now it has 3 shims in it. 2 aluminium and on Brass one. The motor is fairly new maybe 2-21/2 gallons on it. SO I should leave it alone for a little while and then remove the brass one down the road to give it a little more pep? Thanks for the info Monty.
Nick
nick64merc is offline
Old 04-07-2011 | 10:51 AM
  #5106
houston's Avatar
Cool
Nick
That's a little odd , I have never got a production fms nib with a brass .15mm shim
Sure it's not a .10mm copper shim?
houston is offline
Old 04-08-2011 | 11:40 AM
  #5107
I am not sure if it is .10 or .15. I dont have a Micrometer to measure them. The motor was bought from Amain and it has an aluminum shim and then a brass shim and then another Aluminium shim. Should the motor have 3 shims in it?
Old 04-08-2011 | 12:11 PM
  #5108
Integra's Avatar
Caliper's are Critical when playing with Shims, They can be had SUPER cheap and dont need to be Fancy Pansy 100$ units.
Integra is offline
Old 04-08-2011 | 12:12 PM
  #5109
kgombe's Avatar
plus 2...
kgombe is offline
Old 04-08-2011 | 12:17 PM
  #5110
kgombe's Avatar
ok i just look at my stock FMS.. and it has 2 aluminum with 2 brass shim in between them.. totaling .80"... the brass shims are .1" each...
kgombe is offline
Old 04-08-2011 | 12:24 PM
  #5111
houston's Avatar
Silly , those are copper and I built that engine probably
I usually make sure the shimming is a little tall for break in
houston is offline
Old 04-08-2011 | 12:37 PM
  #5112
kgombe's Avatar
LOL.. yeah copper... i bought it from Rui
kgombe is offline
Old 04-08-2011 | 04:04 PM
  #5113
Sorry for the mix up on the metals. So what is the verdict? Should I leave the Copper shim in it or take it out?
Old 04-08-2011 | 06:02 PM
  #5114
houston's Avatar
i wouldnt recommend removing the copper shim completely , if it is just a .10mm i would leave it until you feel that the engine has lost a fair amount of torque compared to what it has had in the past .
if you have .80mm now got down to .70mm , if you have .70mm now i would readjust shim stack to .65mm which will require a .15mm BRASS () shim and one .20mm copper shim along with one .30mm aluminum
hope this helps
houston is offline
Old 04-08-2011 | 06:42 PM
  #5115
Default Another happy customer
I thought I would share my recent experience with Monty. I sent him a 21-5 to see what he could do. Once he tore it down he called me up and we talked things over and he did his stuff. I got it back and ran it today for the 1st time and about says it all. It goes like a rocket my mbx6t likes it allot.
If any body is thinking of buying or having work done with a novarossi engine look up Monty 1st
jet flyer is offline
