Houstons Engine Service H.E.S.
#6601
Breaking in check,
Just thought I'd post up a little something for ya. I know you like seeing people post up.
I'll give you a shout later. Got a funny and not so funny story from yesterday.
As a set up for the story,
Say you got a Plus 4 in a truggy and it boggs off the bottom end. Which would be a possible cause of that, tune being off, clutch shoes and/or springs too light/heavy, or both?
#6602
Breaking in check,
i would start by checking compression seal,glow plug, listening to the engine once warmed up , if those check out good then go drive it around a bit , put a load on the fuel system and clutch and determine what the prob may be
just a few thing to reiterate from the tuning bible
How to “READ” your glow plug:
OS and Turbo glow plugs go gray sooner [easier] than McCoy plugs; this is not necessarily bad. Actually when A new plug wire just goes slightly gray after
a 5 or 10 minute hard run it means your very close to an optimal horsepower tune, but be careful the next step is TOO LEAN!
My rule of thumb.
1} Wire and surrounding bottom of plug wet, with like new shiny wire = rich side of optimum power 85%
2} Wire and surrounding bottom of plug starting to dry and wire starting to gray = Very close to optimum power 95%
3} Wire and surrounding bottom of plug dry, wire totally gray but not distorted optimum power 100%
4} Wire and surrounding bottom of plug dry, wire distorted = slightly lean DANGER!
5} Wire and surrounding bottom of plug dry, wire broken and distorted or burnt up = extremely lean possible engine damage!
Note: You can only “Read” your plug in a nearly new state [Wire like new and shiny] A gray plug can still operate well. After it has totally gone gray,
performance can start to fall off. To test just put in a new plug and if there is no difference in performance save the gray one or put it back in. If your engine does not feel or run right try a new plug before making major tune changes
What is the best Fuel?
. Castor oil is simply the best lube available for model engines [Alberto Picco and Mario Rossi agree] but not all castors are the same! We use the finest ultra Pure Triple A refined castor. Then we add a synthetic supplement package,
which includes anti foaming and rust properties. There is also a wetting agent to aid in Lubricity and reduce storage dry out. The fuel is manufactured with
the latest high tech computer controlled mixing equipment; using the freshest lab tested and certified USA made nitro and methanol by the largest manufacture of model fuel in the world.
#6603
Monty- I ended up with a cracked fuel tank this last weekend and I think I have my idle air gap a little off now. What do you suggest as a good starting point on the gap on my +4 Team Nova that you did? I've read between .5mm and .7?
EDIT: Well duh. If I would just read what came in the box I wouldn't have to ask. Looks like .6mm it is!
#6604
der dad derrrr
best thing to do on nova is warm it up , clear it out a few times , listen to the idle , if it revs high then comes down without being "tingy" its still rich (richen hsn before doing this) , lean lsn until comes down and stays consistent , then adjust idle gap until you get the desired idle , it usually ends up very close to .6mm but there are alot of determining factors
hope no damage to the engine
#6607
Your current pipeset will work of course but it will not be the best for pretty much any novarossi but will work
If you are on a budget i would say get plus 21-4 buggy with 9901ss pipe and 41021 header
That setup is around 325$-330$ish , it comes as standard but if you want turbo add part #28002 to your order
Lmk if you need anything
#6608
der dad derrrr
I'm pretty sure the engine didn't suffer any damage, it never got hot. Just had a couple of ghost flameouts that started me looking for a problem. Ended up being a very tiny crack in the seam of the 8.2 tank.
#6609
hey what are you guy getting on your .25 roma for runtimes. I could not find much looking for it yet. Im really not sure if i want a 21 in truggy i like power so this 25 might fit better for me. I also want to know how much claimed hp is in this one too i cant find the specs cause next week im gonna order one of these from you. just dont know which yet.
#6610
verdict is not completely decided yep but upon early reviews , looks good
#6611
A main I was pitting at 8 minutes but due to corner marshal putting his hand on exhaust, left me pitting at 9 minutes the last 2 fuel stops, First stop at 8:45 pit man yelled up and said nothing left in tank, ended up taking it a little easy on the last 2 laps and finished 2nd. Checked fuel after race and there was hardly any thing left in the tank after 9 minutes. Temped at 203 degrees, I was only on 9th tank of fuel on engine after HES break-in. Running mbx6t,41029 header and 9853SS pipe. Hope this helps, will be leaning her out in 2 weeks and will update mileage.
#6612
and still breaking in i am speculating fairly decent runtimes from this engine , colbys is bone stock
my personal one should be here soon , gonna be reeeeeeeeaaaaaal hard for me to replace my X7 though , that engine is the awesomest truck engine i have ever ran , no joke
#6614
So you really dont have it made for power run time yet so i should wait on that a little bit and just buy a stock one. Or should i buy a moded from you really dont know what way to go yet but i do want some run time. I got 9 minutes out of my 28 i run. The os guy get like 11 i think
#6615
Monty- while I was resetting the air gap I decided to go ahead and reset the needles to the factory settings as well. What I found when doing that was that I was over a quarter turn richer on the HSN and a 1/8 turn richer on the LSN than what the factory spec's are, does that sound right?
Keep in mind that the engine ran well, minus the ghost flame-outs that prodded me to find that crack in the tank. I replaced that and re-tuned for my last qualifier and the main in which I had no more issues. A temp check at the end of the last qualifier showed a temp in the mid 240's, but since the nova still is pretty tight that didn't seem out of place. But now that I see where my needles were, I'm a little concerned as I thought the factory spec's were almost always on the rich side?
22Likes
