Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 04-12-2011 | 06:07 AM
  #5131
houston's Avatar
I do what I can do Troy, I have a full time so I can't take everything instantly as far as the engine biz ,just do what I can
Thanks for the order man and let me know if you need anything
houston is offline
Old 04-13-2011 | 06:16 PM
  #5132
houston's Avatar
Originally Posted by Show871
Thanks, I wont sweat it then....I will just lean my LSN to the "high idle", and then lower my idle screw. Is that what I should shoot for?
Oh yea, which insert is best for all around use? and what conditions would call for an insert change from the "all around choice"
DYN 086 pipe
Thanks again LOL
871
at your altitude i would run a 7.5mm in buggy and 8mm or bigger in truck
houston is offline
Old 04-13-2011 | 06:51 PM
  #5133
Ultraspeed84's Avatar
MONTY MONTY P5xlt was a beast but for some reason it does not like to run above 205 which isnt a bad thing because its halls the mail! sounds like a indy car on the revS! sweeeeetttt.. finally got it tune in wow is all i got to say! But one question for you and your engine tuning! Just quick ref should the top needle be in from flush just a tad bit? and the bottom right around flush? Also when i run the motor and come off the top end the motor revs up just a split second and hit low idle what do you think that would be? Im guessin air leak..
Ultraspeed84 is offline
Old 04-13-2011 | 07:16 PM
  #5134
houston's Avatar
sweeet , thanks for the update !!!
if it doesnt want to run above those temps then that means it is a very efficient engine ,( runtimes? ) is it still pretty fresh? (under a gallon?)
does the engine sound like it is starving for fuel if you lean it out anymore ?
your low speed needle and idle setting is out of whack , usually too lean low speed
around flush and flush are close but more precise counting the needles
there is no magic needle settings but use the referenced needle settings in the threads if you are really struggling , many variables in carb adjustments , pipes , plugs , fuels , different cars have different tank pressures and so on so keep all this in mind
houston is offline
Old 04-13-2011 | 07:25 PM
  #5135
yeah right at 3/4 gallon.. Hmm i moved the idle adjustment in half turn on brake in. But ive since moved it back and the low speed is about 1 turn maybe little more from out of the box. I richen it up and motor still did same thing. I did a pinch test and it was 3 second before rev up seem to run really really good there. but still just had that coming off high load to low rev and back down.
Old 04-13-2011 | 07:34 PM
  #5136
houston's Avatar
come on over and we will get it dialed in
imo the engine is still in break in stages or at least should be at only 3/4 of a gallon i wouldnt expect any miracles out of the engine for a while , wait until it drops its nuts
note: all my smileys actually have meanings
houston is offline
Old 04-13-2011 | 07:58 PM
  #5137
you be the man idle gap got it fixed! she is at a low idle purin like a kitty! o i know i figure gallon half and this will be bad to the bone! i can still hear the motor changing sounds little at a time with the pinch starting to come out of it should be a really good motor. Like i said before this motor broke in really well and idle like a top and no trouble last time i had a motor do this it was ballistic and great motor... nova motors got to love these bad boys. I think i actually like the p5xlt better then plus4 and run time are right at 10mins and only 3/4 gallon yeah its going to be the bomb. i might call you tomorrow about 6 go over some tuning stuff.. thanks monty
Old 04-13-2011 | 08:01 PM
  #5138
houston's Avatar
sounds good bro , my guys tell me i do good work , i hope they havent been ly'in to me
i like my p5xlt's , i really like my X7 engines now
houston is offline
Old 04-13-2011 | 08:16 PM
  #5139
is the x7 better? more top end but same bottom?
Old 04-13-2011 | 09:47 PM
  #5140
houston's Avatar
give it a week or so , feedback will be coming soon
houston is offline
Old 04-14-2011 | 09:12 PM
  #5141
houston's Avatar
Originally Posted by ridein04
Now that is some awesome customer service folks!
Thanks again!
Troy
Did you get your pipe today Troy?
houston is offline
Old 04-14-2011 | 09:17 PM
  #5142
Trevor Williams's Avatar
R/C Tech Elite Member
Monty.....HONESTLY.....how long did it take you to tear that 7port BT apart? like MAYBE a minute after the head was off? I was like uhhhhhh
Oh.....we caught three nice fish today....haha!
Trevor Williams is offline
Old 04-14-2011 | 09:24 PM
  #5143
houston's Avatar
Maybe a minute, that's how it goes when you have taken apart a few thousands of them
Why no pics focker!
houston is offline
Old 04-14-2011 | 09:31 PM
  #5144
I forgot somehow I guess
lmao!
Old 04-14-2011 | 09:46 PM
  #5145
houston's Avatar
lmao!
LOL
houston is offline
