Houstons Engine Service H.E.S.
#5146
Hey Houston.....I have about 3/4 gallon of time on my +4c. Can I race it? It has t on of pinch, and is a bit slow still. Going to go to the 7.5 insert....that could also be adding to the power issue I hope. Thanks!
#5147
Not too sure about your fuel situation either stuart
you know what I recommended
#5148
Still tryin to find a local source for the koolaide with extra sugar....Thanks!
#5151
#5154
#5155
Monty,
I decided to breaking in my new 21-4C team edition today, however, it did not wanted to start. I pre heated the engine with the competition heat. I used Byron 30% (11% oil) fuel. What was wierd was that the flywheel will get stock and I had to free it every time. It happened all the the time. This is my second time breaking in an engine. Therefore, I do not have a lot of experience. But I did not have much problem with my first engine. Let me know if you need more information or if would be best for me to send it to you so you can take a look at it.
Thank you
Fernando
Thank you
Fernando
#5156
Monty.. first time racing my FMS special ed
... and man if i tell you that thing is extremely fast... i could not believe it .. way faster and stronger than the stock....
much thanks man... keep up the good work... can't wait to get my X7 HLX
... and man if i tell you that thing is extremely fast... i could not believe it .. way faster and stronger than the stock....much thanks man... keep up the good work... can't wait to get my X7 HLX
#5157
and ya i am pretty sure you will be VERY excited when you drive the X7 for the first time after break in . Matt Wilcox was the first one to run the engines in competition this weekend at a race in Kansas City at Steve "hillbilly" Hale's track , needless to say he was impressed
coming from a plus 21-4c team (buggy) and a H.E.S. P5XLT S.E. (truck)
#5158
Monty,
Thank you
Fernando
Thank you
Fernando
is your competition heat warmer getting to at least 160° at the head? , if so then loosen the plug (i dont recommend you should have to loosen the plug normally but sometimes)
is your starter box lined up well and strong enough ?
are you priming the fuel system ?
give it another go and if you cant get it , call me , pm me and i will send you my number
#5159
what did you notice over stock?
#5160
well i had that in buggy first and the plus 4C (RB mod) in the truggy... in the buggy that thing was crazy i had power all through the rpm... but surprisingly smooth enough for the buggy.. no problems controlling it at all... so teh real test with stock vs H.E.S. was to put in the truggy.. so with same pipe, clutch and truck... it's stronger all through the RPM range.. which is even more insane top end... and also i was the only truggy to clear the big double on the back straight consistently lap after lap... and i pulled every one or caught everyone on the straight.. and im talking about all engines stock and modded..
sorry i couldnt resist , this does not reflect my true thoughts or opinions but fun can always be had guys
22Likes
