Mugen MTX-4
#1561
Hi Guys !
I've noticed that when i try to mount my Protoform Mazda 6 body into the MTX4, the rear bodypost seems to go through the the "recess" of the bodyshell where it holds the wing.
Is this the correct way to make the holes and mount it ?
The MTX4 bodypost seems to be slightly further apart than the 3. And i don't think it make sense to push the body backwards to avoid that "recess area", then i've got to cut the bumper.
Appreciate your sharing ! Thanks !
#1564
So, you mean if I place a huge boulder on my car it will be stronger?
I dont see where you are going with that but its all in materials or lack of them on the car...Sometimes lighter is stronger too. I have to get my hands on a scale someday....IMO, if you were right than a stock r40 ranging from about 1780-1900 grams willl ripe right through both the 710, RRR, and the mtx 4? Also cars can run better with a little weight it keeps it planted on the ground.
#1565
Originally Posted by Chris West
I cut my servo wires down not to save weight but to get rid of all the execess wire that i dont like hanging around but when soldering you have to make sure its done properly or else the joint will break and then you car does what it wants to do. But I have never had a runaway car before.
#1566
I've done as much as I can with the car to get weight off it. Iv done all Ti pivots, screws, shafts, 2 speed, I can't find anyplace to get more out of it. I'm at 1770 race ready without fuel. Any thing else?
You already replace the middle shaft?
whats the parts no. ??
#1569
Originally Posted by Bad Mika
Hi Guys !
#1570
PHP Code:
Engine will run at higher RPM with taller gearing? How come?
Riketsu is right, let say your first gear final is 7 and second gear is 4, the engine has to spin 7 times to rotate the tire once in the first gear and so on.
#1571
This isn't much of a test, but I had the car out last night on the street, just setting the 2 speed shift point. The car has A LOT of stearing! It comes off the line very quick too. Easy to recover from a spin (just had to try), and it the rear is planted, I took it to the end of the road, where its sandy and turned around, the car tracked very well.
From the build, I had to back the shift point adjustment screws out 3 1/2 turns.
I only ran 1/2 tank, but I can't wait to get this on the track!
#1575
I have 4mm rear shock towers for MTX-4 for sale.
I have recessed the mounting point surface by 1.5 mm so you don't need spacers for the lower shock mount.
Nice and beefy.
$20.00 includes Priority Mail Shipping.
[email protected]
I'll post some pix later in the week.
Nice and beefy.
[email protected]
lets try...
