Old 06-17-2008, 09:54 AM   #9061
Hey guys,
To convert the front shafts to universals on my MTX4, do i just order part number T0245? This is the same one on the mtx3 i believe. I have my front track width set a 199 mm and the shaft sometimes pops out.
josh_c is offline   Reply With Quote
Old 06-17-2008, 10:14 AM   #9062
asw7576's Avatar
Originally Posted by josh_c View Post
Hey guys,
MTX4's front universal is longer than MTX3's front universal. So you have to order the exact part number for MTX4's front universal.
However, If you want to try MTX3's front universal to be use in MTX4, well...... I guess it could be done as long as you keep the front track width very narrow and most importantly, you must use o-ring or little piece of foam foam ( I use tamiya damper red foam --> red foam that you put behind shock membrane to keep the membrane from collapsing ). This foam / o-ring should keep outdrive cup remain intact to front one way unit. Without the foam, the outdrive cup can slide out from one way unit, and broke the one way bearings.
If you want to use regular dogbones, please put o-rings on each side : one in wheel axle's outdrive cup and one in oneway's outdrive cup.
Old 06-17-2008, 11:55 AM   #9063
lil-bump's Avatar
Trader Rating: 83 (100%+)
However the MTX3 front CVD's can be used in the rear of the MTX4/r
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 06-17-2008, 06:52 PM   #9064
for the front shafts i thought you were just meant to put the o-ring on the diff cup only. The diff cup has come out twice on me now so i hope the bearing is ok, any way to tell?
Does anyone know what the part number for front universals on a mtx4? Will this stop the shafts popping out?
Old 06-17-2008, 07:08 PM   #9065
Chickentrader's Avatar
The part number is TO245 and that's what I'm using running my cars 199mm wide. My shafts have never popped out, are you sure that you have the right universals?
Kindest regards,
Lars.
Chickentrader is offline   Reply With Quote
Old 06-17-2008, 07:34 PM   #9066
Thanks for clarifying the part number. I haven't got the universals yet. So if i order T0245 it will come with all the parts needed? Also, i'm putting the mtx4r front uprights on, but will i need to do anything else to make them fit correctly? I hear they are much better. i'm a rookie at onroad so just trying to get my car sorted, bit different to 1/8 buggies.
Old 06-17-2008, 08:36 PM   #9067
NiTrO BoOsTeR's Avatar
mate have a look on ebay and buy the hole lot, just make sure they are for a mtx4, i made the mistake of buy front/rear for a MTX2 i think it was and the hub part is to short and to narrow but i had some old rear universals so i took the hub off that and put it on the shafts its all good now never lost a dog bone since (especially because there are no dog bones hehe)
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 06-17-2008, 10:58 PM   #9068
Mugenville's Avatar
Trader Rating: 25 (100%+)
You will need the MTX4R's lower front arm's as well (TO151-B)
Mugenville is offline   Reply With Quote
Old 06-17-2008, 11:13 PM   #9069
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by nitro ho View Post
NT1 RULES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
wrong thread mate?
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 06-18-2008, 03:03 AM   #9070
itchy b's Avatar
Originally Posted by Arahawak View Post
wrong thread mate?
He feels at home in the Mugen thread because after all its just a rebadged MTX4r isn't it?
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 06-18-2008, 09:45 PM   #9071
Arahawak's Avatar
Dun start.. both are good cars
Old 06-19-2008, 05:27 AM   #9072
itchy b's Avatar
And so they should be!
EX1.5-SC10 4x4
Old 06-19-2008, 09:25 AM   #9073
Seisick's Avatar
Hey guys,
mtx3 and 4 front unis are the same, is on the rears that changes, being the mtx3 the shortest compared to the mtx4 which are long, son in conclusion
you have 3 sizes to choose,
dont know about you but on front of my mtx4, i use the mtx3 rears unis with no problems, but i added a 5x10x0.5mm thick shim between the plastic hexe and the bearing, 2 years and no problems and never have popped a front uni.
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 06-22-2008, 09:37 AM   #9074
asw7576's Avatar
I think seisick is right about Front universal for mtx3 and mtx4 are the same length.
For Rear universals, then they get different : mtx4 is the longest and mtx3 is the shortest ( compare to front universals ).
Sorry, I was mistaken before.
Old 03-30-2009, 12:38 PM   #9075
asw7576's Avatar
Got something to share after some research on belts.
Various RC belts and number of teeth for cross use / reference. I hope my work can be use for all of us.
BELT(T)........NT1........MTX4.......MTX3.......V1 RRR.......MRX4.......M3........G4S
FRONT..........62T........63T..........67T........ .63T............67T..........69T.......70T
MIDDLE. ......132T......129T.......125T........128T....... ...144T........140T......126T
REAR............59T........59T.........64T........ ..60T............67T..........67T........64T
Most RC belts are 3mm pitch belt.
The length of RC belts = total # teeth X 3mm
Examples : Evolva M3 middle belt is coded S3M420, S3M means 3mm pitch, 420 means 420 / 3 = 140 teeth.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
