Mugen MTX-4
#1411
Originally Posted by rcfoolz
I just finnished building the car. Only have servo's to go. Just noticed that the car has a loose side belt. This could be the way its designed. Also, even though the Kit I got came from a stateside hobby shop, it didn't have the tires. I called mugen and talked to them. If the kit you are going to buy does not have a bar-code sticker on the side of the box with a serial number, its an overseas kit.
I'm waiting on another one now from another hobby shop, this kit will be coming from HRP. I built the car with a lot of hop-ups that I had to fabricate, and I am still working on a few more. Just putting the finishing touches on the Titanium front sway bar blocks and 3mm shock towers. Stock is 2.5mm. I like the kit so far, its has a nice setup for the front roll center, fit and finish of everything exceeded my expectations! Built the car to almost a prospec, only if I had a 4mm chassis The rear sway bar, 2.1mm, I like the way that the adjustability of the rear lower hing pins, very cool idea, and also the steering ackerman too. Total time of build so far: 4 hours and only need to install servo's. I am however curious about the side belt, has anybody else noticed the looseness?
If you had used the 24T front side pulley for the side belt.. it is not a problem. I have ran the car and it is not a problem.
#1412
Originally Posted by asw7576
Is this transferable to the 4 ?
#1413
Originally Posted by Vinyard
If that is for the MTX3 then it will not fit.. coz the 4's is shorter.
#1414
Originally Posted by cdelong
makes no sense what so ever that the 1/10th is $70 more than the 1/8 list price??
Anyway folks, finnally finished the car and written up the build over 4 short articles on 3Hobby if you are interested. There may be a thing or two you can learn before building yours.
This is going to be a hot car.
#1415
Buying local has its advantage, mine comes with a shock tower and top tray with holes that are in the wrong places... It was replaced within 2 days from the local importor.
As for the price between different brand of kits, you are not just buying a bag of screws/plastic parts with a chassis. Part of the kit cost is to pay for the R&D, tooling, molds...etc. They won't make money on the kit until they sold some numbers on them. In this case I think Mugen has made their bag of screw/plastic works better on the track. Therefore it is reasonable to put up a higher price tag. Is our choice as a consumer to buy it or not, no use to complain about it. Just don't buy one if you think is over price.
#1416
Originally Posted by Sow&Steady
Supply over demand?
Great write-up!!!
#1417
Originally Posted by Chaya
Hi Guyz,
any building tip for the MTX-4. . .
What kind of engine and manifold would best fit this new beast! ! !
Cheers!!!
Cheers!!!
As for engine and manifold, get any decent engine and pipe ... like I said, the car is going to be fast. Just needs something else that all the money in the world can't buy off the shelf ... great driving skills.
#1418
Originally Posted by tnbigdawg
Great write-up!!!
#1419
Wanna hear good news boyz ??
My MTX4 is finally here !!! I'm flying to the shop now
nonono...... I send my courier riding motorbike is even faster !!
#1420
#1421
#1422
Just wondering does the kit have standard dogbones or does it come with universals?
#1424
dogbone
dieter
dieter
#1425
Originally Posted by Scott Fisher
It comes with dogbones... The MTX3 front universals will fit on the front of the MTX4.
what about the rear? is it available already?
