Old 10-24-2005, 05:01 AM   #1591
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by burito
I realised I had a small error in my original excel-chart (copy/paste errors are horrible...), I did revise it now in my original post from October 15th and everything is correct now.
I almost have my car done, looks pretty good.
Only small concerns are, but these are all mentioned already:
- engine area is very tight...
- front dogbones...
I was wondering what the overdrive (23t) is supposed to be good for when a 5mm split between front and rears is required! Seems like a too massive step to me and the "normal" ratio (with the 24t, which is big overdrive already) does require a 2.5mm split.
Does anyone know the reasons why they did that with the 23t?
Btw, the car can easily be equipped with +0mm off-set tyres as far as I can see, shouldn't be forced to get the new +1mm tyres...
Anyone checked the wheelbase? Seems quite long to me.
Reto,
I was told that the 23t pulley is for the guys who want to run Lola bodies on their cars.
Btw, no more R40 for you?
stefan is offline   Reply With Quote
Old 10-24-2005, 05:20 AM   #1592
Chaya's Avatar
hi Mr Wing,
nice car there, loh.
George
Xray Nt1 l Xray T3'12 l F104PRO
Chaya is offline   Reply With Quote
Old 10-24-2005, 05:24 AM   #1593
burito's Avatar
@stefan: yep, I'm using the MTX-4 now and joined the Mugen team. I'm of course still using LRP-Power...
@wing: what tyre size did you run with the 23t? And what difference did you feel when changing from 24t to 23t (I assume you did adapt tyre size when you made this change!)?
Reto Koenig
burito is offline   Reply With Quote
Old 10-24-2005, 07:28 AM   #1594
sohlman's Avatar
Trader Rating: 89 (100%+)
Originally Posted by Jamie Corrado
I see you peeking Sohl.
Don't worry we'll have our 4's soon enough.
Just soaking in some of the initial feedback and building tips. We got time. I've got 1/8th on the mind right now.
Steve Sohl
sohlman is offline   Reply With Quote
Old 10-24-2005, 07:46 AM   #1595
wing's Avatar
Originally Posted by Chaya
hi Mr Wing,
George
thanks...this car is really good...the car quality, performance is really high...
burito
I used a 24 t at the beginning...but the rear is moving too fast, when we change to 23t..front and rear speed is getting close, more easy to drive.for 23t..the tire is F61/R63
but we found out the most signifcant improvement is take off the 2mm shim from the rear arm...it make the camber won't change too match when it ener the corners...just my 2 cents....
will try to put the siro III to this car this weekend, but need to change the carbarator to JP (or nova) first,because the siro cab is too fatty..the brake disk will block the cabarator....
just small complaint about this car...when we want to change the engine, we need take off the side belt graphic
wing
wing is offline   Reply With Quote
Old 10-24-2005, 09:48 AM   #1596
rcracerdude's Avatar
Send a message via Yahoo to rcracerdude
Has anybody had a problem getting the front suspension to have full travel? When I push the suspension down the shocks bottom out and the chassis is still 2mm away from the ground
it could also be the up-stop setscrew
Ken Gutierrez
derbybrosracing.com
rcracerdude is offline   Reply With Quote
Old 10-24-2005, 11:12 AM   #1597
hi wing,
if you use the 23 pulley with 2 mm split,front to rear, you use a car with more frontdrive.
dieter
4racer is offline   Reply With Quote
Old 10-24-2005, 11:15 AM   #1598
asw7576's Avatar
Originally Posted by JPFX
Has anybody had a problem getting the front suspension to have full travel? When I push the suspension down the shocks bottom out and the chassis is still 2mm away from the ground,also my side belt is very loose even when using the belt in the seperate bag and the 24T pulley. I have had a problem mounting the protoform mazda 6, what do you recommend?
1. check up stop screws
2. check the piston shaft, longer shaft rear, shorter shaft front
3. check the length of front and rear dogbones, longer rear, shorter front.
Loose Belt ? adjust belt tensioner until the belt doesnt touch the manifold.
Old 10-24-2005, 11:22 AM   #1599
asw7576's Avatar
exactly 26mm, measure from front wheel screw to rear wheel screw.
Old 10-24-2005, 11:29 AM   #1600
asw7576's Avatar
Originally Posted by 4racer
hi,
1.000 front and rear drive is equal
1.001 more front drive
0.999 more rear drive
dieter
Thx dieter,
btw, which is true statement ?
More front drive is easier to drive ? *** i pick this one ***
OR more rear drive is easier to drive ?
OR front and rear are equal ?
Old 10-24-2005, 11:43 AM   #1601
26mm wheelbase? is this 1/50th scale MTX4?
Ken Gutierrez
derbybrosracing.com
Old 10-24-2005, 11:44 AM   #1602
asw7576's Avatar
Hahahaha 26 centimeter
Old 10-24-2005, 01:27 PM   #1603
The bump-stop screws are not touching the plastic and the shock shafts and axles are all correct but it still doesnt reach the ground. The problem is that the plasic bit on the end of the shock that you thread on bottoms out on the shock body therefore stopping suspension movement. Also do mugen intend you to run the car at 1:1, that is why they give you a overdrive ratio chart that can be used to set overdrive to whatever you like by changing tyre size.
JPFX is offline   Reply With Quote
Old 10-24-2005, 02:02 PM   #1604
Slotmachine's Avatar
Send a message via MSN to Slotmachine
The bump-stop screws are not touching the plastic and the shock shafts and axles are all correct but it still doesn't reach the ground. The problem is that the plastic bit on the end of the shock that you thread on bottoms out on the shock body therefore stopping suspension movement. Also do mugen intend you to run the car at 1:1, that is why they give you a overdrive ratio chart that can be used to set overdrive to whatever you like by changing tyre size.
How large of a tire are you using when you say the car wont hit the ground? Remember most racers don't use full sized tires when racing. Did you build the shocks to book Specs, (length)?
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 10-24-2005, 02:06 PM   #1605
chookgb's Avatar
Trader Rating: 26 (100%+)
- front dogbones...
the car's wheelbase is 2mm shorter than the mtx-3
chookgb is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
