Old 10-22-2005, 12:21 AM   #1531
stefan's Avatar
Send a message via AIM to stefan
I don't wanna open another can of worms, but seeing that the engine compartment is pretty tight, how about gearing options?
Are there different pinions available and is there enough room to adjust the engine?
stefan is offline   Reply With Quote
Old 10-22-2005, 12:21 AM   #1532
Derby Bros Racing's Avatar
my memory says it's 1725g to be ROAR legal.... i think or should i say if my brain is working right
Derby Bros Racing is offline   Reply With Quote
Old 10-22-2005, 12:25 AM   #1533
the engine didn't have to be moved when changing gearing options with my mtx-3 unless of course you were putting a really worn out pinions and spurs -- then you may have to tighten it a bit. but as far as moving the motor every time you change the gearing... it's not needed at all. the mtx-4 should be the same way because it's the same gearing (0.8)
Old 10-22-2005, 01:29 AM   #1534
Hi Jo and Stefan,
First gear, 16-18 58-60
Second 21-24 52-54
monotuning is offline   Reply With Quote
Old 10-22-2005, 02:05 AM   #1535
rcracerdude's Avatar
Send a message via Yahoo to rcracerdude
what's the stock gearing on the mtx-4?
Ken Gutierrez
derbybrosracing.com
rcracerdude is offline   Reply With Quote
Old 10-22-2005, 02:10 AM   #1536
23/53
Old 10-22-2005, 02:42 AM   #1537
asw7576's Avatar
Originally Posted by monotuning
17/59
23/53
Is it bad gearing ratio for mtx4 ?
21/59
27/53
( these number actually mtx3 stock gearing )
Old 10-22-2005, 02:49 AM   #1538
Send a message via ICQ to _cyclops_
21/59
27/53
The pulleys on the diff also changed, so you need to check what's right and what's nog on the mtx4...
_cyclops_ is offline   Reply With Quote
Old 10-22-2005, 03:00 AM   #1539
Sow&Steady's Avatar
I want to drop the same engine for mtx3 and mtx4.
Currently I can't switch the same engine easily because the clutch system are different thickness ( see front and rear section ). Eg. mtx4 flywheel only matched to mtx4 pinion gear adaptor.
Right, I can't say that I've tried to swapt engines but all the parts look very similar except the pinion-bell housing. If you are using 0.8 modules for both then it should be a close match between the 3 abd 4.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 10-22-2005, 03:02 AM   #1540
asw7576,
The internal ratio of MTX-3 is 2.53, for MTX-4 is 2.16.
If you use, 21/59 27/53, your first gear final will be (59/21)*2.16=6.07, your second will be (53/27)*2.16=4.24 which will probably be too tall for most track. The tallest ratio in first gear for MTX-4 is 18/58 which is 6.953 and second is 24/52 which is 4.675 which are still shorter than the stock gearing of MTX-3.
Old 10-22-2005, 03:48 AM   #1541
asw7576's Avatar
asw7576,
Thanks, mono !!
What is the effect of too tall gearing for engine ? Isn't that good considering top speed and less spin out of corner ?
Old 10-22-2005, 04:02 AM   #1542
Taller gearing means the engine will run at a higher rpm, so you get the idea.
You are right about the top speed and less spin out, but the gearing you provided is just too tall for most application other than speed run.
Old 10-22-2005, 04:25 AM   #1543
Default MTX 4 Assembly
Hi Guys,
Just assembling my MTX 4 now and I have a couple of questions:
1. Is anyone using Futaba servos? If so, what steering and throttle servo horns are you using?
2. Does anyone else notice how far the pivot ball retaining devices pretrude out from the rear hub carrier?
3. What offset tires are you guys using with standard pivot balls, driveshafts and 200mm track width? I heard the car requires 1 degree offset rims?
Thanks in advance, your help is much appreciated.
Cheers
SNACKPACK is offline   Reply With Quote
Old 10-22-2005, 07:48 AM   #1544
Regional Moderator
daniz24's Avatar
Engine will run at higher RPM with taller gearing? How come?
daniz24 is offline   Reply With Quote
Old 10-22-2005, 09:05 AM   #1545
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
I think its the other way... Shorter gearing means the engine needs less power to move the car using more RPM. Taller gearing means the engine will not spin so fast because its using all of his power to move the car. Think of what happens when you car gets stuck in first or second gear. If it gets stuck on second gear, means your engines's rpm will be much less meaning the fuel consumption will go down. If it gets stuck on the first gear, means the engine's rpm will be much higher meaning the fuel consumption will go up.
Riketsu is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
