Serpent 710
Old 07-26-2004 | 07:47 PM
  #14416
Sow&Steady's Avatar
Default Re: Re: pics
Originally posted by markp27
There are loads of 710 pics here
There are also some nice pit girls
You're a true Ambassador my friend!
packetdreamer, try also clicking on the topics menu there or the topics icon. There's a series of articles of the 710 rebuild. Pleanty of pics.
Sow&Steady is offline
Old 07-26-2004 | 07:49 PM
  #14417
Suspended
Default SERPENT BASIC MAINTENCE KIT
DOES THIS SEEM LIKE A GOOD DEAL ON THESE TOOLS AND CLEANING GUM?
SERPENTFREAK69 is offline
Old 07-26-2004 | 07:54 PM
  #14418
Sow&Steady's Avatar
Originally posted by packetdreamer
i read the tips and tricks pertaining to steering on the dalton shop page, but if i could get some clarification/assistance, it would be appreicated.
right now i have the servo set so that when it is in nuetral the horn is at 90degs (pointing straight up). the link from the servo horn to the servosaver is the right length so that when the servo is in the nuetrual position, the servosaver is pointing straight toward the front of the car. the links from the servosaver to the knuckles are equal and the car tracks straight.
now my question/problem is this: when i steer to the left (servosaver spins clockwise) the servosaver moves all the way until it hits the plastic part that holds the hingepins (good)
when i steer to the right (servosaver spins counter clockwise) the servosaver moves and just before it is about to hit the part that holds the hingepins on the left side fo the car the movement gets all "mushy". this is because the servo horn is pulling the linkage towards teh back of the car and this causes he plastic ball cup to press against the servo horn. (bad)
is anyone else experiencing this, or know to to resolve it. i thought about tilting the servo horn toward the front while the servo is in nuetral, but i was nto sure if this would effect the rate of steering in one direction over the other.
if you have any suggestions, please, lay 'em down. thanks.
packetdreamer, there has been a lot of discussions on this in the past and since D is stubborn and refuse to write an article to post it somewhere (3hobby.com or myTSN.com) so people can refer, you'll have to surf back hundreds of pages to find it!
Even if you search using the "InitialD" criteria you'll be going through hundreds of pages ... he's a prolific poster and with nearly 14,000. No offence D, you're generous with knowledge in this thread, we appreciate it!
Anyway, since you're so nice to join 3hobby.com, here's my tip. The original length as given in the manual is for exactly the set-up you mentioned ... servo horn straight up. You then get the problems you've experienced.
I have 2 710's, one with a Futaba 9550 and the other with a Sanwa WRX. For the Futaba I found that you needed to but the turnbuckle of the link so as to allow you to get 39mm tip to tip. For the WRX servo, 40mm tip-to-tip. You then need to set the servo horn slanting towards the front slightly at neutral point.
Doing this I get equal 38 degrees left and right with the Futaba and about 40 degrees left and right with the WRX.
Another good thing to do is to download the 710 FAQ ... look for the link under MarkP's signature in this thread.
Old 07-26-2004 | 07:57 PM
  #14419
Pyramid's Avatar
Registered User
We all should have experience the same. Place 0.5 or such shims between servo horn and plastic ball cups to have some space on the servo horn lingkage. Next, shave some parts on the ball cup to clear whatever get in the way that lead to binding.
Pyramid is offline
Old 07-26-2004 | 07:59 PM
  #14420
Sow&Steady's Avatar
Default Re: running rubber tires
Originally posted by doki_doki
is the serpent 710 any good with rubber tires???
From what I saw in the last British Nationals rubber race, the 710 is very good on rubbers.
Old 07-26-2004 | 08:02 PM
  #14421
Sow&Steady's Avatar
Originally posted by Finken
Hi all
What is supposed to be better with the soft rubber caps and the foam inserts in dampers?
When i installed it, i couldnt move the piston all the way up, it kept coming back? I had to remove some oil to get rebound right, is that the way to do it?
What is the proper rebound? And what good/bad does it do?
In my humble opinion there is no such thing as a proper rebound. I think what needs to happen is that:-
1- you CAN push the rod all the way in,
2- there is no air in the shocks,
3- rebounds a little bit, say 1/3rd or 1/2 way back once you've pushed the piston all the way in.
4- both left and right shocks are of equal length,
5- both left and right shocks rebound back to the same place.
6- drive the car and see!
Old 07-26-2004 | 08:04 PM
  #14422
Pyramid's Avatar
Registered User
and yet another forum - ah the price i will pay. after looking i have a question, is the ssg carbon fiber stronger? lighter? or just for looks? is it thicker then the standard pieces?
Left and Right engine brace is thicker by a layer. The rest is the same but rear shock tower is actually thinner (ssg) than the new updated serpent one. They are not stronger, they are the same with the black one but top layer is coated in silver as supposed to refuse heat.
Pyramid is offline
Old 07-26-2004 | 08:11 PM
  #14423
Pyramid's Avatar
Registered User
Hi all
Proper rebound is 5mm in general, less is even better.
Best caps and foam to use is PITZ-PS0902 Silicon Soft Diagfram + Sponge Set
Pyramid is offline
Old 07-26-2004 | 08:13 PM
  #14424
Pyramid's Avatar
Registered User
I will now leave to uncle Sow as looks like we both has nothing to do
Pyramid is offline
Old 07-26-2004 | 09:03 PM
  #14425
doki_doki's Avatar
From: Cebu City, Philippines and Ocala, Florida, USA
Default Re: Re: running rubber tires
i see... i'm planning to get the kit. the tracks we have here in Cebu, Philippines is cement with moderate traction. we don't run on foams. all of us use rubber tires. does the kit come with front differentials or with one-ways??? thanks...
doki_doki is offline
Old 07-26-2004 | 09:29 PM
  #14426
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Flight plan!
Originally posted by InitialD
Paying more than double for JP FX when you can just buy an ordinary 5 port engine for the same performance? Does not make any sense.
when all you can run is 3-port and when a 5-porter asks which 5-port motor you have
markp27 is offline
Old 07-26-2004 | 09:30 PM
  #14427
markp27's Avatar
Apparently you don't seem to think much about the blue 11 fin screamer...
Once I influence the AMCC club to switch to TC shells in Oct he will learn his lesson
markp27 is offline
Old 07-26-2004 | 09:32 PM
  #14428
markp27's Avatar
Default Re: Re: Re: pics
I do my best
markp27 is offline
Old 07-26-2004 | 09:33 PM
  #14429
markp27's Avatar
I think the old man has gone to bed
markp27 is offline
Old 07-27-2004 | 03:47 AM
  #14430
Diesel Racer's Avatar
Default Stripped wishbone
Does anyone know if the slightly longer lower rear wishbones are available yet?
Cheers
Mark
Diesel Racer is offline
