Serpent 710
Originally posted by Diesel Racer
Does anyone know if the slightly longer lower rear wishbones are available yet?
Cheers
Mark
Cheers
Mark
Cheers
Mark
Cheers
Mark
they should turn relatively easily.you have to watch when you tighten down the huge silver grubscrew onto the pivot balls to make sure its not so tight that it binds and not to loose that it lets the steering knucle wiggle. i tighten the screw just to the point where as much lateral movement of the knuckle is gone. since the parts are new some wear-in will loosen things up too.
Originally posted by jag
Thanks, I will take a look at it. I purchased a rolling chassis and now I will probably end up taking it apart and rebuilding it just so I know it's right.
It will help you understand the car better.
Originally posted by markp27
Once I influence the AMCC club to switch to TC shells in Oct
he will learn his lesson
Its now foam and touring!
802208 Bumperplate upper LM-type S710
http://www.mytsn.com/products/product.asp?prid=3334
where shoult front body mount goes?
Originally posted by Car Breaker
How did you use that?
Originally posted by Sow&Steady
This is meant for use with the Lola bumper which already has an integrated body posts on it.
