Serpent 710
Old 07-25-2004 | 02:39 PM
  #14386
Sow&Steady's Avatar
Default Re: hey d
Originally posted by impalabob64
the serpent is called the snake charmer right in makes u want to learn more.the g4 was an is i think might be close to being up there with the 710 but it has things that has to be done.to reach the snake charmer thats the name i gave it at my club track ,mugens cant touch it ,.kyosho want to beat it.s r40 cant even taste it but they feel the strike of the reptile dont they can i get a what,what
I luuuuvvv your summary!
Sow&Steady is offline
Old 07-25-2004 | 02:40 PM
  #14387
Sow&Steady's Avatar
Originally posted by InitialD
How could Onkel Sow resist a JP engine?
I can't but the three port still puts me off a bit unless I decide to enter the rubber races. But painful memories of collecting boxes of inserts, wheels and tyres just wore me down.
  #14388
Sow&Steady's Avatar
Ah you old guys with their childish antics again...
It was Mark's idea ... honest.
Old 07-25-2004 | 02:43 PM
  #14389
Sow&Steady's Avatar
Strange that Michael, Julius, Rene and the rest of Team Serpent use a LOT of rear sway bar (set to hard position) to dial their car. Yeah, this combined WITHOUT the front sway bar !
D, it depends on the track. If you have decent grip and there's a flat sweeper or two then I'd definitely be using it. Helps with max power through a flat sweeper without the worry of traction rolling.
Old 07-25-2004 | 02:46 PM
  #14390
Sow&Steady's Avatar
Default Re: Re: Re: Clutch.... help...
Originally posted by ttso
If car is fully stop, everything is good. Throttle on will make the clutch engage correctly, good punch. But when I leaving corner and put the throttle back on from free-roll, it won't engage. And in straight line, if I release the throttle in middle and put it back on right away. I can heard my engine running into higer RPM, but car speed gradually reduced, just like free-roll. The only way to make it re-engage is keep click on thrttole until lucky happen.
Nope, 2nd speed didn't kick in.
Really a strange problem. It feels like the spring push the shoe back in high RPM, makes it dis-engage even the RPM still remain the same high.
I was about to say the same thing as D mentioned. Check your 1-way or the rear-diff. Most likely your rear diff is slipping.
  #14391
Default OS max 12 tr
anyone looking for a good engine check out my for sale post.
Raul Garcia is offline
Old 07-25-2004 | 02:48 PM
  #14392
rcpanama's Avatar
Smile
Hi I will like to get some advice in reference to my Set Up. I has been raising in a large Parking loot Track with the 710, the set up I have works very good in that Track (med low traction) , I will show the set up.
We will start as of Sunday running in an other Track which is smaller (High Traction), one Fast Sweeper coming in the straight one slow one coming out, four hair pings and one chicane.
This track is very small compare to the other, we change track during our 14 raising in the year, depending on the sponsor.
The Set Up I have is the following:
Engine Nova Rossi NSR12 S3, with two ceramic Boca Bearing, Nova Mega crankshaft 11.5 Outlaw MS for Novarossi, yellow shoes, with 1.8 spring.
Fuel 20% Nitro 12% oil with Nitro Blast Additive.
Glowplug C6TF Novarossi
Pipe Nova Mega 5P out low
Tires Ellegi 40 front & rear
Shocks Red front & rear, 35 / 3 holes front, 40 / 3 holes rear
Shock Mounting front 2 & rear 1 (Default)
Transmition Spur 61 / 57 Pinion 16 / 21
Drive Train Rear Ball Diff Med hard / Front One way
Roll Center Rear UTI / LT Front 0mm under
Down Stop Front 0mm Rear 7mm
Camber Front 1.5 Left & Right Rear 3.0 Left & Right
Toe Front 1 out rear 2 in
Caster 2mm front
Ride Height Front 6mm Rear 7mm
Body Alpha Prot.
Car Weight without Body & Fuel (includes transponder & temperature gauge) 1665g
With Body 1785g
Bearing Complete Boca Bearings set and Ceramic bearing in rear Ball Diff.
The car has the three latest Aluminum option from Serpent, Hudy Dog Bones front & Rear, Hudy Drive shafts front & Rear, Ventilated Disk Brake, Hudy drive shaft in One-way.
What will be a good change from this Set Up to move to a smaller track (more technical & higher traction?
rcpanama is offline
Old 07-25-2004 | 06:50 PM
  #14393
InitialD's Avatar
Default Re: Re: Re: Re: Clutch.... help...
Originally posted by Julius
99% says it's the one way in the 1st gear slipping. Clean it with some brake cleaner and re-lube with one-way oil. It is not possible to check a one way just by feeling. The forces on it are completely different when the car is running.
Yeah, that was what I was thinking as well. Anyway, I think you should not use any type of brake cleaner. The ones I've seen are very caustic on plastics. Using the wrong one could melt and deform the plastic cage where the oneway bearing needles roll.
InitialD is offline
Old 07-25-2004 | 06:51 PM
  #14394
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Flight plan!
Originally posted by Sow&Steady
What do you expect D?
Paying more than double for JP FX when you can just buy an ordinary 5 port engine for the same performance? Does not make any sense.
InitialD is offline
Old 07-25-2004 | 06:52 PM
  #14395
InitialD's Avatar
Hey, he's got titanium everything you know ... not to mention that blue-11-finned screamer!
Apparently you don't seem to think much about the blue 11 fin screamer...
InitialD is offline
Old 07-25-2004 | 06:53 PM
  #14396
InitialD's Avatar
JP website mentioned that the engine with the new 3 port sleeve (IDM style type porting) is about the same performance of their 5 port engines.
Ah, with a JP FX 3 port, why should you need to be relegated to join the rubber tire class? I'm sure the 3 port kicks in every bit of butt in the outlaw 5 port engine class.
InitialD is offline
Old 07-25-2004 | 06:55 PM
  #14397
InitialD's Avatar
Like I mentioned, it takes two (old) people to tango.
InitialD is offline
Old 07-25-2004 | 07:01 PM
  #14398
impalabob64's Avatar
Default motors
hey you guys think the jpfx is fast i seen 1 get its a$$ handed to it by a murnanmodified mugen x12.repeatly oh for a tech or short track i highly suggest solid axle in front.
impalabob64 is offline
Old 07-25-2004 | 07:42 PM
  #14399
cyba888's Avatar
Thanks for everyone helping my question regarding the setup and yellow spring shoe part number I hate Mondays!
cyba888 is offline
Old 07-25-2004 | 07:49 PM
  #14400
ttso's Avatar
Default Re: Re: Re: Re: Re: Clutch.... help...
The real strange part is: if I lift the car and put throttle on (about 15% of throttle). I can see clutch engage and than slip away after a while (under the same RPM) That why I say it feels like spring push the shoe back in.
Anyway, I gonna try the rebuilded clutch first this weekend, than new spring, than new flyweight, than.... I don't know...
ttso is offline
