Old 07-29-2005, 07:43 AM   #21916
jag
jag's Avatar
Default Receiver Mounting
How are you guys mounting your receivers and do you use an on/off switch? I am redoing my electronics and I don't really like the way I have it. My receiver faces in with a switch mounted next to the pipe. The receiver is hard to access and I have to replace the switch on a regular basis.
Thanks,
jag
jag is offline   Reply With Quote
Old 07-29-2005, 10:15 AM   #21917
rccobra705's Avatar
Default 710 Rear solid axle
In the 710 set-up booklet @ page 31 are a picture of a optional solid rear axle.
Anyone know the part # for that unit?
Exist at all?
Regards
rccobra705
rccobra705 is offline   Reply With Quote
Old 07-29-2005, 04:41 PM   #21918
B4
B4's Avatar
Reciever is mounted as per the manual and pointed inward. If you run the Spektrum you could have it encased in a ballon all the time as you don't need access to the xtal.
Thanks,
jag
I was using the KO Propo on/off switch for a while, but didn't like the fact it draws power even when in the off position. I have now gone to using no switch and just plug the connectors together when required. The connectors I use are Deans mini plugs (made for 1/18) these are perfect as they are quite small and much better than Futaba connectors.
B4 is offline   Reply With Quote
Old 07-29-2005, 04:55 PM   #21919
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Exist at all?
Regards
rccobra705
Hi !!, Im Patricio Concha !!! ... how are you Claus !? ...
Why you are interested on a rear solid axle ?, are you running with front solid or front one way ? ... i used to use front and rear solid but that setup eats belts and kills transmission as hell !! ...
If you just want to "try" it, start putting Ofna's Difflock 120.000 silicone fluid to your diffs (unless they are ball diffs) ...
Try to look at : Parts List on MyTSN
Cya !!!
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 07-29-2005, 08:25 PM   #21920
rccobra705's Avatar
Cya !!!
Hi Pato,
I'm fine. I want to run Lola body with solid rear and front one-way as 1/8 scale. I have check all the Serpent pages up and down, but it look likes 710 solid rear unit does'nt exist.
Any comment from Julius or MarkP?
Pato, how it is going with the new track project in Santiago?
Rccobra705
Old 08-01-2005, 12:36 AM   #21921
InitialD's Avatar
The diff on the 710 are ball diffs...
But why would you want to mess with silicone fluids when you can just tighten the clap down and mimic the 120000 silicone fluid? I believe this is what most of us do with the front ball diff anyways.
Old 08-01-2005, 12:39 AM   #21922
InitialD's Avatar
Yup. I think not yet. If it comes out, it should be 802390.
But if you really want to try one, try locking the inner screws as well as the clamp down. Be careful not to overdo it on the clamp.
Or else, take out the inner balls and plates and drill dimples (3 or 4 would suffice) using dremel on the plates in equal and opposite directions so that you could put the balls in and they would lock and sit in the dimples on the plates. Of course, do that on those plates and balls that you already want to throw away...
Old 08-01-2005, 12:40 AM   #21923
Greg M's Avatar
My old CD3 ran gear diffs, never again, ball diffs are so easy to maintain and adjust.
Greg M is offline   Reply With Quote
Old 08-01-2005, 09:31 AM   #21924
Send a message via ICQ to _cyclops_
Default Dogbone pin removal
Hi All,
i was cleaning my car and i noticed my dogbones being 2.5mm thick (the pins) in stead of 3mm
Now i also noticed that they damaged the parts they fit into... i know i can remove the pins and change them for new ones but the hudy tool to do that isn't available anymore... are any other toolmakers selling such a tool?
I also know that Julius posted a discription on how to build the tool youself, but i don't want to damage the dogbones... so how is this done correctly?
_cyclops_ is offline   Reply With Quote
Old 08-01-2005, 11:02 AM   #21925
Julius's Avatar
The "tool" I use is an old engine mount. Basicly what you need to achieve is a good base for the ball to rest on. Any alu block that is thick enough so the pin can come out fully without hitting the surface your support rests on is ok.
I use the m4 hole of an old alu motor mount and place the mount on a large vice. Then using a heavy hammer hit the pin till it's flush with the ball. Then take a driver (the things to embed nails in wood with) and tap it out.
Be carefull when replacing the pins in the new cvd's. They're a smaller dia and need to be replaced with pins designed for the cvd's I saw them today in the Serpent warehouse (the number is one higher than the m3X3 screws)
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 08-01-2005, 02:05 PM   #21926
Thanks julius.. i still have an old motor mount, that will work fine..
I also tought about getting a alu block and drilling a 4mm hole through the block, and then drill a 6 (or 7)mm hole on that 4mm hole (about 3mm deep).. That would secure dogbone then....
btw, julius, now that you are stopping your R/C racing, are you going to do some red-bull air racing?
Old 08-02-2005, 02:13 AM   #21927
Julius's Avatar
Probably more like red-bull and vodka racing
Old 08-02-2005, 02:50 AM   #21928
hmm, i wonder how that new A380 will perform with those great vodka skills
Old 08-02-2005, 04:41 AM   #21929
InitialD's Avatar
You mean like this?
Old 08-02-2005, 06:45 AM   #21930
jag
jag's Avatar
I accidentally mounted my body about 1/8" - 3/16" too far forward compared to the wheel openings in the body. How bad did I screw this up?
Thanks,
jag
