Serpent 710
Old 06-10-2004 | 12:39 AM
  #12361
Pyramid's Avatar
Registered User
Default Re: Re: Re: Re: Re: Re: what could be wrong?
Originally posted by Pyramid
I found the name as funny as Fukuyama
If you imaginelooking at in under the rain.. somehow that thing looks like NovaMax engine... does it
Pyramid is offline
Old 06-10-2004 | 12:48 AM
  #12362
rjl's Avatar
rjl
That wear is accellerated by having the diff set too stiff. It's because the diff pulley becomes fixed to the left outdrive when you tighten the adjuster.
rjl is offline
Old 06-10-2004 | 12:52 AM
  #12363
InitialD's Avatar
Default Re: Re: Re: Re: Re: what could be wrong?
Originally posted by GoldFinger
Use Dremel with diamond bit.
When you grind to remove the "dimple" it is not precision already
Ah, removing the dimple? Yes. Done that before but like what you say, you can only use it for one or two days and then the dimple comes back even worse than before. I guess the more "play" the dogbones have in the outdrive because you grind out the dimple, the easier the dogbone pins form more dimples. So you ultimately need to change them.
InitialD is offline
Old 06-10-2004 | 12:56 AM
  #12364
InitialD's Avatar
Right you are.
But what use is the diff when you cannot set it stiff?
InitialD is offline
Old 06-10-2004 | 01:11 AM
  #12365
Pyramid's Avatar
Registered User
Good one!! looks like xray diff is the one that is truly externally adjustable and working flawesly. Slip externally adjustable on Serpent.. no comment on this one
Pyramid is offline
Old 06-10-2004 | 01:13 AM
  #12366
Arun's Avatar
Default Re: Re: Re: Re: what could be wrong?
Originally posted by InitialD
You mean like what Hudy does on the PRO wheel adaptors?
Sorry. Don't have that kind of precision machining tool to do that.
I actually just added a new set of "slots" to my rear diff. It was very easy...I only used a dremel with a cutting disc. It turned out very well.
I also exchanged the pins in my dogbones with a longer ones that become flush with the outside of the cups on the diff. I am expecting them to wear (dimple) much less.
I have not track tested these changes yet, however.
I wish they would just make some spring steel diff halves..
I also wish serpent-usa would finally get in some 801214 pro wheel axles.
Arun is offline
Old 06-10-2004 | 01:17 AM
  #12367
Pyramid's Avatar
Registered User
Oh yes, you remind me of Goldfinger 808220 (new black color) shaft that has its pin loosen itself on use.
But someone here mentioned that Serpent is coming back to source from Hudy. That`s a good thing
Pyramid is offline
Old 06-10-2004 | 01:22 AM
  #12368
Pyramid's Avatar
Registered User
The Lord always got the Point!!! nice one D
Pyramid is offline
Old 06-10-2004 | 01:26 AM
  #12369
InitialD's Avatar
Ok, I'll try and recycle mine...
Excellent idea. I had thought of doing the same. Well, credit to you, Arun. You always have the wildest of ideas !
BTW, do you know how long the pins should be to get it to flush with the outdrive? I believe the pin is 2.5 mm diameter if I'm not wrong...
InitialD is offline
Old 06-10-2004 | 01:33 AM
  #12370
Pay more attention if you are using the new 808220 (new black color). The pins is tends to loose itself.
GoldFinger is offline
Old 06-10-2004 | 05:21 AM
  #12371
Default Re: Re: Re: Some testings...
Good question ! Well, there's one 2.5 mm hole already int he flyweight. I just take the dremel and drill out another 2.5 mm hole on the other opposite side as what is posted by Pyramid. I would agree that it's not dead accurate but it works...
So this is the original flyweight mod , but you are just adding the extra hole and two set screws? What were the differences you noted between the original, unweighted flywheel mod and weighted flywheel mod. Honestly I have never really had a problem with my clutch setup. Not once has it hung or not engage, but I would like to experiment with this modification.
kreidel is offline
Old 06-10-2004 | 05:43 AM
  #12372
InitialD's Avatar
Default Re: Re: Re: Re: Some testings...
Yes. One M3x4 set screw on each of the 2 holes per flyweight. Total 6 set screws used as per Pyramid's picture.
Well, for those looking for every inch of performance benefit, you may want to try it. Some times, you would not realise what you're missing until you try it. It may or may not work for you.
In my case, I noted that the clutch grab even harder. Noticeable 15 to 20 feet after launch.
InitialD is offline
Old 06-10-2004 | 06:04 AM
  #12373
rwisejr's Avatar
Lightbulb RED CLUTCH SHOES ?
Hi gang didn't someone post that they made some red clutch shoes for the 710 ? I would love to try some of those out. have used the reds in my impulse pros with great effect.
rwisejr is offline
Old 06-10-2004 | 07:23 AM
  #12374
Default Re: Re: Re: Re: Re: Some testings...
Thanks InitialD, I will give it a try.
kreidel is offline
Old 06-10-2004 | 09:46 AM
  #12375
BIBOY's Avatar
Post RE what could be wrong
thanks guys big help im fixing the car tonight while out on the track... il give you updates on what i found ... thanks again!!!
BIBOY is offline
