Old 05-30-2004, 07:52 PM   #11611
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally posted by InitialD
After the download, it will start up any player associated with the .mpg or .avi extensions. Sometimes it plays and sometimes it does not. What I do is I search for that downloaded file in the hard drive and you should find it in the browser temp files. Copy it out to some other location. Manually start it up. It should work.
i will try that , thanks "D"
Old 05-30-2004, 08:16 PM   #11612
Pyramid's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Clutch
Originally posted by Sow&Steady
Yes, I sapu the 3-Racing (no choice mah) front shaft but the rear one is going to be the Shooter hollow shaft.
Just info, shoother front one way outdrive has inner part to be about 1mm thicker than standard. So it might be usefull for front diff guys loosing their bones.
Pyramid is offline   Reply With Quote
Old 05-31-2004, 04:59 AM   #11613
Sow&Steady's Avatar
Originally posted by Marcos.S710
hey Sow&Steady i cant get any of your videos to work
What OS and browser are you using?
In general clicking on the download button should work. If not right click on the Title of the vido and choose "Save as..." or "Save link as..."
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-31-2004, 05:01 AM   #11614
Sow&Steady's Avatar
Thanks D. Yes Marcos, this is another way.
Old 05-31-2004, 05:03 AM   #11615
InitialD's Avatar
Default Texas Biggie 2004
Did anybody see this posted at mytsn yet?
Brandon McNally had the fastest time in 200mm with a 15 lap 5:00 run. Unfortunately the body shell was 1mm below the minimum height and the time was disallowed. His time would have been over 3 seconds faster than his closest competitor. Brandon will start 3rd with his Serpent 710, it is powered by a Nova Mega SS-12 and grip is provided by Ellegi tires.
Looks like Team Serpent is still formidable without Ralph Burch. Go Team Serpent !
Old 05-31-2004, 05:14 AM   #11616
PSI Racing's Avatar
Default Re: Texas Biggie 2004
I just read that report.
I'm glad to see Team Serpent is still doing good here in the US.
Is Ralph Burch racing at the Texas Biggie?
I didn't see his name on the list.
Is he still racing Nitro?
What company is he racing for now?
I heard he was racing for Kyosho now, but I don't think that's been confirmed.
PSI Racing is offline   Reply With Quote
Old 05-31-2004, 05:15 AM   #11617
Sow&Steady's Avatar
Nope ... where was it posted?
Old 05-31-2004, 05:16 AM   #11618
PSI Racing's Avatar
Default Re: Re: Texas Biggie 2004
http://www.mytsn.com/publ/publ.asp?pid=10193
Old 05-31-2004, 05:17 AM   #11619
Sow&Steady's Avatar
Found it ... under "USA Snake Pit ... "
Old 05-31-2004, 05:22 AM   #11620
Sow&Steady's Avatar
Default Re: Re: Re: Texas Biggie 2004
Thanks.
1 mm? Hmmm ... if I look at some of the innovative designs of the rear wings on some of our friends' bodywork, 1mm seems a slither of a hair that would not make a difference
Don't get me wrong, I'm trying to encourage all of us to stick by the rules even though we all love the outlaw class
OK, I'm off to the track ... byeeee!
Old 05-31-2004, 06:31 AM   #11621
BaxterC's Avatar
Good luck Schrijver99...
I ran my 710 for the second time this weekend, the first being a bit of a let down in the way that I could not complete half a tank due to the noise... I ran it in the street, what a monster... I had it very rich, it never got out of first gear, but wow it was fast. I then leaned it out a little, WOW. It got to second and really flew!!! I got such a fright, I misjudged the kerb and hit it flat out. My glass car must be made out of that industrial heat treated stuff. The car bounced off, with small cracks in the body but not even a mark on the car. I hit it flat on. Titanium glass is good...
BaxterC is offline   Reply With Quote
Old 05-31-2004, 07:19 AM   #11622
Hi all,
I need some help figuring out an engine issue.
Serpent 710
new 2106 NovaMega SX12 3P-SS
#5 glowplug
Standard head shim included with engine
Sidewinder Fuel 20% nitro, 12% oil (old fuel from last season)
H2503 HARD .12 Adjustable Inline Shark Pipe Set
Engine has only had 4~5 tanks of fuel through it before my first race weekend, so I think it is probably not fully broken in.
Engine temp was high during the raceday, and fluctuated a fair bit during runs. Temp was anywhere in the range of 240~290C.
Engine was very sensitive to high-speed needle (HSN) changes.
We had to richen the HSN nearly 2 turns to get the temp down.
I could not make 5 minutes runtime. Even during a day of racing, the engine would occassionally seize up with the piston at TDC (due to pinch I think). I tried different plugs... no major changes.
I tried different LSN settings and idle screw settings... worked out fairly well.
The major problem I was having was during my main.
Every single time I pitted for fuel, I would go around 3 corners, and then the engine would flame out in the same spot.
I tried to rev the engine higher to stop this from happening, but it kept happening.
Some gave a tentative answer, but I want to ask around to see it if makes sense. Since the engine is still very tight and running hot, after fueling when the cold fuel reached the carb (at approximately the same spot on the track), the cylinder would contract a bit due to the sudden temp change and stall the engine.
Does this make sense?
Can anyone offer any suggestions why temp is so high, runtime is so low, and engine keeps stalling a few corners after fueling?
Please help...
GlennCauley is offline   Reply With Quote
Old 05-31-2004, 08:30 AM   #11623
rodrigo1508's Avatar
well I am not so sure but may be your MSN its too lean. Also I had that pipe and just changed it for a novarossi I found out that my temps are now lower and and have more top end speed
rodrigo1508 is offline   Reply With Quote
Old 05-31-2004, 08:53 AM   #11624
afm
afm's Avatar
Originally posted by GlennCauley
Hi all,
I need some help figuring out an engine issue.......................
Engine has only had 4~5 tanks of fuel through it before my first race weekend, so I think it is probably not fully broken in.............
Engine temp was high during the raceday.................Even during a day of racing, the engine would occassionally seize up with the piston at TDC (due to pinch I think)...................
Please help...
I think the answer is pretty clear to me......... You haven't properly finished the break-in process............. I would suggest you go to the Break- In engines thread, in the engines forum, and start all over again with the factory settings, using RB's method (WOT).
AFM
afm is offline   Reply With Quote
Old 05-31-2004, 09:16 AM   #11625
BaxterC's Avatar
Hi all,
Serpent 710
#5 glowplug
Please help...
I know the shark pipe runs LEAN... Very much so. this may be the problem.??
