Old 06-10-2004, 12:25 AM   #12346
InitialD's Avatar
Originally posted by FW05R
which is the m3 screw
Additional M3x4 set / grub screws that you thread onto the flyweights to give it more weight = more punch !
Old 06-10-2004, 12:28 AM   #12347
InitialD's Avatar
Default Re: Re: Some testings...
Originally posted by kreidel
How do you determine where to insert the two m3x4 set screws?
Good question ! Well, there's one 2.5 mm hole already int he flyweight. I just take the dremel and drill out another 2.5 mm hole on the other opposite side as what is posted by Pyramid. I would agree that it's not dead accurate but it works...
Old 06-10-2004, 12:29 AM   #12348
InitialD's Avatar
Originally posted by Pyramid
If using screws to pre thread as per manual, I still find difficulties having the plastic end all the way until you could not see the shaft thread.
Be careful threading using the M3 screw. Just guestimate before hand how much the M3 screw threading will go in before really threading the M3 screw into the ball joint. I cracked one because I threaded it too deep in.
Old 06-10-2004, 12:30 AM   #12349
Pyramid's Avatar
I might have to go out and buy a kyosho evolva for my collection
As of now, roll center is unchangable. Rear might have an option to do it but not yet release
Pyramid is offline   Reply With Quote
Old 06-10-2004, 12:34 AM   #12350
Pyramid's Avatar
What is the deal with other brand having 3 flyweights (even 4 maybe) and most of them have 3 holes on each. Wouldn`t that make it lighter? thus less punch? but seems they have no complain about it
Old 06-10-2004, 12:46 AM   #12351
InitialD's Avatar
Default Re: what could be wrong?
Originally posted by BIBOY
so i just wanna find out what would be the best things to check on this?
I don't know if you understood my earlier reply but this is what I meant by the dogbones making a "dimple" in the outdrives. Check the wheel axle adaptor too on the opposite side in the knuckles.
The "dimple" in the outdrive makes the dogbone bind in the sideway movement and this causes the rear suspension to bind and the rear of the car hooking.
Just thought you should check this out first... You may or may not find this on your car.
Old 06-10-2004, 12:51 AM   #12352
InitialD's Avatar
I guess there's a certain limit where less or more punch will be attained when you lighten or make the flyweights heavier. Remember that the Centax 3 is pretty small compared to the other clutches. A classic one is the Centax clutch for the NTC3. I guess many people could not get the clutch to work properly on the NTC3 due to it being very small. Centax II did not have this problem and I remember lightening the internal parts some more to get more punch !
Old 06-10-2004, 12:59 AM   #12353
Pyramid's Avatar
and also my right turning radius was smaller so i tried adjusting the servo throw but still it did the same thing... so i just wanna find out what would be the best things to check on this?
Consider the following as last option you will check to remedy the problem after you making sure both front and rear upper bearing block are screwed firmly to its bottom part and holding all the eccentric bearing housing firmly as well,
Steering Linkage
In case you found out that turning radius for left and right is different while the steering linkage (from servo saver to knuckles) are both already in the same length, what you need to do is to adjust the servo linkage (from servo horn to servo saver). Do not follow the manual length measurement, different brand of servo will sit differently. Just make sure when looking at the car (front of car facing you), the servo saver is in its center of chassis, then adjust the servo linkage until you get same maximum steering throw for both left and right (remember, steering linkage measurement must be the same). The use of around 3x15mm droop screw style is very useful for this matter to get shorter length without the need of cutting those plastic ball cups shorter.
Old 06-10-2004, 01:15 AM   #12354
Default Re: Re: what could be wrong?
Make another cross cut, can save you about 2 more races.
GoldFinger is offline   Reply With Quote
Old 06-10-2004, 01:19 AM   #12355
Pyramid's Avatar
Default Re: Re: Re: what could be wrong?
Not a springsteel. Must use Makino before breaking on the process or in use
Old 06-10-2004, 01:19 AM   #12356
InitialD's Avatar
You mean like what Hudy does on the PRO wheel adaptors?
Sorry. Don't have that kind of precision machining tool to do that.
Old 06-10-2004, 01:25 AM   #12357
Default Re: Re: Re: Re: what could be wrong?
Use Dremel with diamond bit.
When you grind to remove the "dimple" it is not precision already
Old 06-10-2004, 01:29 AM   #12358
Pyramid's Avatar
Default Re: Re: Re: Re: Re: what could be wrong?
U make selling a new one harder
Old 06-10-2004, 01:30 AM   #12359
Makino ?? new tools?
Old 06-10-2004, 01:36 AM   #12360
Pyramid's Avatar
I found the name as funny as Fukuyama
