Serpent 710
Originally posted by InitialD
Yes. One M3x4 set screw on each of the 2 holes per flyweight. Total 6 set screws used as per Pyramid's picture.
Well, for those looking for every inch of performance benefit, you may want to try it. Some times, you would not realise what you're missing until you try it. It may or may not work for you.
In my case, I noted that the clutch grab even harder. Noticeable 15 to 20 feet after launch.
BTW, do you know how long the pins should be to get it to flush with the outdrive? I believe the pin is 2.5 mm diameter if I'm not wrong...
). I cut the new pins from an old screwdriver. I would take pictures...but my digital camera is far too crappy to give a good close up shot.If I had the black wheel axles in the front, I would probably do the same to all the dogbones. Even in the wheel axles, there is too much space between the end of the pin and the end of the axle cup. I have seen some nasty worn axles at my track. The fact that we are running locked front axles probably dosen't help much. The spring steel ones, on the other hand, simply do not wear.
If anyone knows a better way to get the pins out, my thumb would appreciate it.
Originally posted by Proficar403
I don't remember, but I think it was 11mm for the diff. The pins are 3mm, not 2.5, that's for sure, and they are also a pain to pound out (especially to my thumb
Part: 106000
It might be hard to find, because it has been discontinued.
http://www.mytsn.com/products/desc.asp?prid=1752
You might still be able to find it.
Sorry guys, I know this is off topic. I started a thread, but I can't seem to get a response
I'm just curious to know what kind of power supply you guys use to power your tire truers. I'm interested in the Eagle Racing 28A. What do you guys think?
I'm open to suggestions so feel free to recommend other brands.
Thanks in advance.
Thanks in advance.
Originally posted by Julius
I have taken out all clutch modifications with the yellow shoe. I am using the stock flyweights in their normal way wit a 0.5 to 0.6 mm gap. Works excellent.
Thanks in advance.
Thanks in advance.
good luck!http://teamnovak.com/products/power_...er/N-Power.htm
http://www.balakracing.com/rivergate30.htm
D, Are you still running the black shoe? I have taken out all clutch modifications with the yellow shoe. I am using the stock flyweights in their normal way wit a 0.5 to 0.6 mm gap. Works excellent.
I was at the Region 4 race last weekend and Paola said he was using the standard flyweights, 1.45mm spring/nut gap, black shoes and .4 mm gap on the clutch bell. He said the .4 mm was the key. Maybe he can elaborate on this. He was definately the fastest guy on the track.
Originally posted by BIBOY
well i use the ofna truer and i use the novak n power for it ...
That Bulldog PS looks very promising though.
Originally posted by Sow&Steady
I use the Hudy Pro one and just use a normal 7mAH 12 volt GP Battery. Its small (battery) and have enough to do some truing as well as charge my receiver battery during a day's racing.
I'm also currently using a gel cel and it works fine. I just want a power supply to use at home to power some other equipment besides my truer.
It is somewhat common to see someone with a 7AH gel cell use their battery for their truer, charger, and their starter box.
Since you want something for home, I would check ebay for a cheap pyramid supply. They are big, but also very cheap.
Originally posted by JustRace
Julius...what did you end up with on the spring/nut gap?
Have you tried setting the flyweight mods with set screws in it? When I get the yellow shoes (if I get it
), I'll try stock flyweight mounting WITHOUT set screw, stock flyweight mounting WITH set screw at the one end, modded flyweights and mounted in between the post WITHOUT set screws and finally modded and mounted in between the post WITH 2 set screws.
