Serpent 710
#4876
Originally posted by rayhuang
Cannot decide on motor, cannot decide on chassis-aaarrgghhh!!
#4877
Re: Re: 710 FAQ
Originally posted by Julius
First the "setup ride height" is no longer used. So my article about it is no longer valid. The ride height figure in the setup sheet now refers to actual ride height with the car on the tire size as per setup sheet.
Anyway, there are many setups already posted on mytsn. So which setups posted are measuring the real ride height and which are with the setup ride height?
#4878
Originally posted by maximummt
Here is my 710 powered by R&B V12T
#4879
Originally posted by cyba888
What kind of tool box do most of you guys use?
For the other stuff like starter box and the car, you could use the Serpent 1980 bag.
#4880
Re: DRS
Originally posted by Marcos.S710
How much does the car toe-out when the car accelerates?
Does it make a difference on how much ride height you have?
But as to how fast or how much it toes in or out in relation to the fixed chassis ride height, I would not have a clue. Need to check it out.
I guess when the rear part of the chassis is lowered due to tire wear, the rear wheels toe out more when the DRS arm in set in the above position...
#4881
Originally posted by Rookie Solara
Serpent recommand 0.70mm difference, and they gave an example saying if my different is GREATER then 0.7mm then use this formula A - B - 0.70mm = whatever and add the whatever MM thickness shims outside the thrustbearing............but me, my final number is LESS then 0.70mm......am I suppose to TAKE OUT something..? But I have nothing to take out...so what is next?
In any case, I would not worry too much. I prefer to set the clutch shoe and clutch bell gap as close as possible (about 0.4 mm) and set the clutch nut spring tight down to 1 mm of the thread showing. If you changed and cut the flyweights to fit in between the post, you get very excellent punch out of the clutch with this setting.
I would suggest to run the car with the 0.4 mm spacing and mount the rest of the clutch as is. If the clutch is not engaging, loosen the centax pre-tension nut. After running it, check the clutch gap spacing. On mine, I noticed that the gap went bigger than what I measured earlier. Perhaps the parts inside did not "settle" down.
See how it goes. If you're not getting satisfactory performance, then do the mod.
#4882
Super Moderator
Re: Re: DRS
Originally posted by InitialD
When the DRS arm is set to the above level, the rear wheel toes out. I have not checked with the gauges but I'm guessing it toes out somewhere about 0.5 to 1 on each side of the rear wheel.
The ride height will affect the toe in or out of the rear wheels when you set the DRS arm to above position (i.e. low ride height = less toe in, high ride height = more toe in). Of course after you set your ride height, you'll go on to set your camber and toe in / out.
#4883
Re: Re: Hop ups
If I'm not mistaken, ceramic bearings are not allowed if you run ROAR sanctioned races. IRMAR allows it though. I may be wrong.
Regarding Titanium pivot balls, there was actually some around which is for the 705 / Impulse as these pivot balls were slightly longer. I think you can find them at www.serpent.at or originally at the japanese site at www.centralrc.co.jp
#4884
Anybody know how to decode the Serpent language? I haven't recieved my 710yet but I want to order a bunchof spare parts for it from RC-Mushroom but I don't understand what the descriptions mean. There are no pictures. And Serpent doesn't have parts listed on there site of all the 710 parts with a descrpition? I'm used to calling stuff, knuckles, pillowballs, control arms, hingepins and etc... I think I have figured out some of the descriptions but I don't want to go and order a bunch of parts and not get what I thought I was ordering! If anybody could help me out with the Serpent language that would be great because I'd like to start ordeing spare parst soon. Thanks for your time.
Later...Richard
Later...Richard
#4885
Originally posted by SupermaxxRich
Anybody know how to decode the Serpent language?:blush
Anyway, you can download the Reference Guide from mytsn. You need to be registered first before being able to download the PDF file. There are 3D diagrams of the parts that belong to the car, their respective part numbers and where it goes into the car. At the back of the page, there is a complete list of 710 parts. That should help you a lot.
#4886
SWEET Thanks "D"!!!!! You just saved me a ton of headaches.
#4887
Hey, Lord D, got your Mazda finished yet? More races this weekend?
I've ordered myself an Alfa and a Mazda from Protofrom for my Surikarn - the guys I've spoken too about the Mazda reckon it is the best thing out there now!!!
#4888
Hi there Guys,
I am wandering about bodies on the 710, I am looking for a decent body for racing, something that looks good, and plays good, and even fits good. I saw a really nice one on the protoform site, it is the MG, but it has a drawback... it is only in 190mm. This is probably one of the better looking ones but doesn't help me coz it is so narrow. It seems like you favour the protoform bodies, why? What is the difference, I found the (Dare I say) hpi bodies have better detail, I have not had much experience with protoform, but I didnt like the shape of their bodies so much on their site.
Thanks guys I really appreciate the help the forum has provided so far.
#4889
Originally posted by BaxterC
Hi there Guys,
Hi there Guys,
I think you are new to this hobby. For those 190mm width body, they are used for electric TC. For 710 or other GP TC, rules required it to be under 200mm.
For why people like Protoform over HPI, you may compare their price, their performance from guys on track.
#4890
Hi there Guys,
Hi there Guys,
Apparently the Mazda 6 has all the stability characteristics but also has more steering.
If I was you, I would go first for the Stratus 2.1 and then get a Mazda 6 to see if you like it better, once you are used with the Stratus.
The HPIs may have all the bells-and-whistles in terms of looks, but they are not as good in terms of performance as the Protoform bodies.
Cheers, Mark.
