Old 02-26-2004, 02:18 PM   #4861
rayhuang's Avatar
Default ROAR motor question
For the Sedan Nationals-is the NovaMega SX12 RE 5P Turbo MS
legal-or only 3-ports with turbo plugs???
Motor
Thanks,
Ray
Old 02-26-2004, 02:21 PM   #4862
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: ROAR motor question
Motor
Thanks,
Ray
The new rules is that it can be turbo but i think that it still has to be a 3port motor
Old 02-26-2004, 02:25 PM   #4863
rayhuang's Avatar
Thanks-I havent raced Nitro sedan for only a year and I feel like I forgot everything already.
Cannot decide on motor, cannot decide on chassis-aaarrgghhh!!
Ray
Old 02-26-2004, 02:29 PM   #4864
Originally posted by markp27
Very nice maximummt
Have you ran the car yet?
Yes, 6 tanks for breaking
For the moment everything is OK.
Much lighter than my old R40
maximummt is offline   Reply With Quote
Old 02-26-2004, 02:34 PM   #4865
Super Moderator
Marcos.J's Avatar
Ray
a good motor is the new mugen x-12 , my friend Jorge has one in his mugen mtx-3,and his car is STUPID-FAST ,he was keeping up with the 1/8 th scale's during practice.
Old 02-26-2004, 02:47 PM   #4866
rayhuang's Avatar
yes-I have heard that Mugen engines have been riiipin in Sedan. Thanks again,
Ray
Old 02-26-2004, 03:35 PM   #4867
Trader Rating: 16 (100%+)
Originally posted by Julius
Did you take out one of the ball bearings before you measured the A (pushed to the shoe) measurement?
When I do the measurement, there were NO ball bearings inside the clutch housing....
Step 8.6 didn't show any ball bearing inside....I have only the thrustbearing inside instead.
Old 02-26-2004, 03:41 PM   #4868
Originally posted by Diesel Racer
Rookie, first things first, double check the thickness of shim that you placed between the brass collet and engine output bearing, this should be 0.5mm. When checking your A & B dimensions that should be with just the thrust bearing installed not the 2 small ball bearings.
Good luck
Mark
According from my caliper..........I had 0.47mm, 0.48mm and 0.53mm shims, no 0.50mm exact thickness SHIM......do you think Serpent can send me a exact 0.50mm shim, and do you guys think that is the different...? I used a 0.48mm thickness, should I get 2 more 0.01mm shims to form 0.50mm?
Also, I think it is my $50 cheapy EBAY Caliper....
Old 02-26-2004, 05:44 PM   #4869
clmbia45's Avatar
Hop ups
Anyone found titanium pivot balls or ceramic bearings for the 710?
clmbia45 is offline   Reply With Quote
Old 02-26-2004, 06:24 PM   #4870
SupermaxxRich's Avatar
Acer Bearings has ceramic bearings for the 710.
SupermaxxRich is offline   Reply With Quote
Old 02-26-2004, 06:39 PM   #4871
Default Re: Hop ups
Jack, I dont find the Ti pivot ball yet. But you can use the G4 Blue/Ti colour Adjusting nut (808344, serpent number)
The option part is coming from KFactory (KFC-K1448, G4 Alu Piv Ball Nut&Tefl Wsh(2))
It has Teflon Washer !
They will fit nicely on 710.
GoldFinger is offline   Reply With Quote
Old 02-26-2004, 06:49 PM   #4872
clmbia45's Avatar
Smile
Thanks guys! jack
Old 02-26-2004, 07:15 PM   #4873
cyba888's Avatar
Originally posted by maximummt
Hello all!!
Here is my 710 powered by R&B V12T
nice paint job
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 02-26-2004, 07:16 PM   #4874
InitialD's Avatar
How was the R40? Why did you switch to the 710? I guess you cannot make comparisons yet since you have not driven the 710. Give us brief details with regards to the comparison !
Old 02-26-2004, 07:19 PM   #4875
InitialD's Avatar
Default Re: Hop ups
If I'm not mistaken, ceramic bearings are not allowed if you run ROAR sanctioned races. IRMAR allows it though. I may be wrong.
Regarding Titanium pivot balls, there was actually some around which is for the 705 / Impulse as these pivot balls were slightly longer. I think you can find them at www.serpent.at or originally at the japanese site at www.centralrc.co.jp
