Serpent 710
Old 11-19-2003 | 09:51 PM
  #1081
Motorman's Avatar
all I can say is the front end width can make the difference between lifting in a high speed sweeper and being able to grind the paint off the inside board if you feel like it. Especially on an 8th scale
On sedans you should really try to stick with the wheel offset the car was designed for. running an oddball offset on the rims can make for a really screwed up setup on the chassis not to mention other things.
About a 5MM split on the front to rear on track width is what I usually run on my sedan
Motorman is offline
Old 11-19-2003 | 09:52 PM
  #1082
markp27's Avatar
What about the downstops for smaller tracks? Is there any basic rule here?
Cheers, Mark.
markp27 is offline
Old 11-19-2003 | 10:04 PM
  #1083
Motorman's Avatar
Mark I use front down stops all the time now to eliminate traction roll. put a credit card under the front of the chassis and compress it down onto the card. adjust the front downstops so they just touch. your car will be almost impossible to traction roll. you will need to reset it every round to compensate for tire wear and adjust accordingly for a main
no need I have found to use them in the rear
Motorman is offline
  #1084
Originally posted by InitialD
More rear toe-in will not give you on power steering. Off power steering and braking would be better with more rear toe-in.
.. Im not clear enough about that
Can I put it simply like this :
- Rear toe-in affect the off throttle steering
- Front toe-in affect the on throttle steering
Is this the condition you mean ? I know thats not as simple
as i wrote, but can I use that as a guideline, D ?
GoldFinger is offline
  #1085
Default Re: Re: Re: Re: Re: Re: Re: Basic question for v.small tracks.
Yes correct. I run that too on my Impulse PRO. If you look at the 705 thread, I had a pic of the wheels with these narrow wheel hex adaptors.
But like what Goldfinger mentioned, the wheels will rub on the floating rear mount adaptor which I also use on my TC setup. I believe when I use a 2 degree offset wheel in the rear, somehow it clears up (touches only little when cornering). I need to use the 8 mm adaptors, 2 degree offset wheels with -4 camber and the trackwidth will still be under 200 mm. That's what I use on my Impulse PRO which I have not modified the rear upper arms.
On my 705 with the modded upper rear arms, I use the stock 11 mm aluminum wheel hex adaptor, 0 offset wheels, -4 camber and still under 200 mm (198 mm exactly).
Are there offset wheels available for the front? The inside rim and tyre rubs against the steering block arm and joint even after adding hex ring (the hex lexan cut out method by MasterD)
To me this is what frustrate me the most of the 705!!
lawndoggie is offline
Old 11-19-2003 | 10:09 PM
  #1086
InitialD's Avatar
That's a good question Mark. I don't know how the gurus in Holland would approach it but this is what I do on my 705.
I forgot to mention that on top of all the things I do like caster, sway bar settings, tires, I play around with the rear downstops to get better steering on smaller tight tracks.
If I cannot get enough turn in on the the tight corners, I'll change the droop on the fly on the side track itself. No, I don't put it on the setting board. I guess I'm too lazy. This method proves to be quick and successful for me. Usually, I'll take my Hudy 2 mm allen on the trackside, pick up the car and from the bottomside, I give the downstop screws like half a turn clockwise on each side. Make sure they are equal turns on each left and right. I run my car again to see the difference. Not enough? I pull the car aside and do the same to get more rear droop so that more weight transfers to the front. I usually will do this trick first before attempting to change the caster as I like to keep the caster angle big in order to have as much on power steering as possible. Also, I like how more caster gives stability down the straights if required.
So the general setting I end up for smaller tight tracks is more rear droop (approx +4 or +5 thereabouts). Perhaps this is because like the caster setting, I like to stay with a slightly tighter rear diff to give me good on power steering out of the corners whenever I like it. Small or large tracks alike. I have never played with the front droop. It always stays at 0. My 2 cents.
InitialD is offline
Old 11-19-2003 | 10:11 PM
  #1087
For what reason did I cut up and show the modded upper rear arms?
That's what it is for ! To make the rear narrower.
Old 11-19-2003 | 10:13 PM
  #1088
Pyramid's Avatar
Registered User
Originally posted by lawndoggie
I checked with the local distributor and retailers here, all told me 359USD. Which is the same as 705... what a deal! If only the parts can be cheaper... especially N00B like me...
That should be the fair street price around the world. Should not lower than $375, in case you wonder...
Pyramid is offline
Old 11-19-2003 | 10:14 PM
  #1089
InitialD's Avatar
I'm amaze to find that we do things opposite !
Well on my tracks, it is almost next to impossible to traction roll with my 705 ! Perhaps it's due to the smaller front tires that I usually run or that our local tracks here simply sucks !
Anyway, that's a cool method to set front droop. But on a small track, do you need to play around with front droop seeing that you can never traction roll in the first place?
InitialD is offline
Old 11-19-2003 | 10:17 PM
  #1090
Pyramid's Avatar
Registered User
Sorry, I misread it as $395... you really get a good deal then..
Pyramid is offline
  #1091
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Basic question for v.small tracks.
lawndoggie, are you using the FC steering blocks? It's one of the better hop ups for the 705.
I find that I can use a wider selection of tires with the FC steering blocks. Plus, they last longer and are tougher than the stock steering blocks. I'm still using the same 1st pair when the FC steering blocks came out.
InitialD is offline
  #1092
My basic rule is not to make the car too sensitive to handle. Some people like it can but others might be different. If you like the car to be responsive (in my case, too sensitive) then increase the rear downstops BUT !!! the car stability is poor,especially out of corner punch. Becareful of over punch coz the car might be out of controlled !. :-)
TQ
MorShah is offline
Old 11-19-2003 | 10:19 PM
  #1093
Motorman's Avatar
hey D need your opinion because here we go again
Terms
Downstops: suspension (physical chassis)down travel limiters
Upstops: suspension up travel limiters=Droop screws however referred to by many as downstops.
More caster: King pin tilted more rearward=more on power steering
Less caster: King pin stood more upright=more turn in steering
More rear toe =more turn in stability but less on power steering=push
Less rear toe=less turn stability but more on power steering=oversteer
do you agree?
This guy a few posts up seems to be getting confused some. and for some reason few people agree on terms.
Motorman is offline
Old 11-19-2003 | 10:21 PM
  #1094
InitialD's Avatar
Oh, you sound exactly like the Dutch ! They always think the other way around. 359 to 395 !
InitialD is offline
Old 11-19-2003 | 10:28 PM
  #1095
Motorman's Avatar
As far as droop heights go I usually set the rear of the car to have 2 mm of up travel under the chassis in the rear when the car is adjusted and sitting at the desired ride height. It gets tweeked all day. the front I usually set at 4MM up travel at ride height. wherever the drrop ends up is where it ends up. occasionally I will remove the wheels to make sure droop is balanced side to side once I tweek it at ride height.
Motorman is offline
