Serpent 710
Old 05-10-2004 | 08:37 PM
  #10066
hey initial D
how do you know how many shims to add to the head of an engine if you want to run higher nitro %?
Profoxcg is offline
Old 05-10-2004 | 08:38 PM
  #10067
kreidal, the front solid axle setup takes away a lot of steering. You could try my setup...
I actually agained some steering in my technical infield
Profoxcg is offline
Old 05-10-2004 | 08:40 PM
  #10068
Originally posted by InitialD
Hey Mr. Hudy, you should have sold that glass car to me. I would have bought 10 from you.
Bro.. Im lost this time.
I know what is mothership, but I could not find "DELETED" in the dictionary..
GoldFinger is offline
Old 05-10-2004 | 08:53 PM
  #10069
InitialD's Avatar
I believe Novarossi has a guideline somewhere on their website. I know the little "manual" that is included with the engine has this info.
Else, check with Motorman. He has a website here.
InitialD is offline
Old 05-10-2004 | 08:56 PM
  #10070
InitialD's Avatar
On power or off power? On power steering increases.
InitialD is offline
Old 05-10-2004 | 08:57 PM
  #10071
InitialD's Avatar
Have you tried the internet? Google?
InitialD is offline
Old 05-10-2004 | 08:59 PM
  #10072
Default Re: Re: Need some setups
Thanks D, I will set it up and try it your way. This is your tight track setup I take it? So running 37 front and 40 rear did you notice the car being loose in the rear?
And look at Hudy's previous posts, he has never had anything good to say in all his 57 posts. I am sure he is hust a sucky driver that finds problems with everything anyways.
kreidel is offline
Old 05-10-2004 | 09:01 PM
  #10073
um... I dont remember, maybe so,
i just know I drove so good this sunday !!! and I LOVE MY CAR !
... actually the only time i had little steering was at the end of the stratway into a sweeper, this was off power or the brakes a little, i thought this way because both front wheel were spining ver fast compared to the rears that have the dif action
Profoxcg is offline
  #10074
I run my MTX3 with a solid and have loads of on power steering but can't stand that off power push. Is this pretty much common....taking the good with the bad?
kreidel is offline
Old 05-10-2004 | 09:12 PM
  #10075
quick tips:
Add your front camber.
  #10076
InitialD's Avatar
Default Re: Re: Re: Need some setups
Yup. I used to use front solid before I installed the front ball diff. I used it on very tight track as well as reasonably large tracks.
The rear end is very planted even though with softer front and harder rear tires. You will notice another thing which is equal front and rear wear rate which is what I like best ! The steering is also excellent on and off power.
InitialD is offline
Old 05-10-2004 | 09:14 PM
  #10077
true
Old 05-10-2004 | 09:15 PM
  #10078
Default Re: Re: Re: Re: Need some setups
Do you like using the front ball diff more than the solid axle?
kreidel is offline
  #10079
InitialD's Avatar
You increase the off power steering with the softer front tires,, less caster, loosening the rear diff a little and playing around with the shocks a little. If I wanted more turn in, the rear shocks would go one hole up higher on the shock tower.
InitialD is offline
Old 05-10-2004 | 09:16 PM
  #10080
InitialD's Avatar
quick tips:
InitialD is offline
