Old 05-10-2004, 08:28 PM   #10051
InitialD's Avatar
Originally posted by Pyramid
I believe I need to cut my alum post that hold lower and upper plate by 1.25mm if not mistaken (might want to ask D, he remember everything ) in order to have the PERFECT fit.
Don't worry ! I'm not so meticulous ! I installed mine just like that. I noticed that the front upper bumper plate sits a little higher but I left it just like that and screwed everything in. Still good after a few direct bumps.
Ok.. got to go to Airport now.. dont post too much D, I find it hard to catch up this threads..
As they say, it takes two (or more in this case) to tango !
Old 05-10-2004, 08:28 PM   #10052
Send a message via AIM to Profoxcg
D is the 3 racing bumper a perfect fit?
- I need to go look at my car for the roll bar thing..
brb
Profoxcg is offline   Reply With Quote
Old 05-10-2004, 08:29 PM   #10053
InitialD's Avatar
Originally posted by GoldFinger
Blame it on mark, uncle so and D
It's them !
Old 05-10-2004, 08:30 PM   #10054
InitialD's Avatar
Originally posted by markp27
Yep, it's now 10:45 pm here - D is probably just getting up now - really international here
Here's the pic I promised.
I used to do that. I think some team drivers from Germany also do that. But I found that it makes the front body post and bumper a little weak and lack support. The bodypost is more flexible. Now I use the SSG 3 Racing front upper bumper brace. Still strong and makes the front part very sturdy with a slight addition in weight.
Old 05-10-2004, 08:32 PM   #10055
InitialD's Avatar
Not exactly a perfect fit but it fits fine for me.
Just slot a 2mm allen just in front of the front tire into the slot where you will find the rear side of the sway bar.
Old 05-10-2004, 08:35 PM   #10056
Default Initial D
Smaller gives you smaller top speed !
what did you mean by that? I posted something a few mins ago , can you help me, or just send me a piece of your brain haha
Old 05-10-2004, 08:38 PM   #10057
InitialD's Avatar
uh? what do you mean lol ur confusing me now,
Smaller tire rollout in mm per engine revolution gives you smaller top speed. Larger tire rollout gives larger top speed.
Top Speed = (Tire Rollout x Engine RPM) x 60 / 1000000
a car with a larger number for tire rollout will move more down a line with one revolution of the engine... right?
Yup.
so therefore, larger values are better? or not?
Not necessarily better... Much be just nice. Too much and you'll overshoot the end of the track ! What you want is just nice for a particular track so that you can use the complete range of powerband from the engine. If you keep overshooting at the end of the track or in the infields, that would make your car very difficult to drive.
One of the reasons why your car although having better gearing in terms of top speed cannot be faster than a car that has gearing for less top speed is because your gearing on the car could not take advantage of the engine's higher end power band with the length of the track being the limiting factor.
Old 05-10-2004, 08:52 PM   #10058
for this reasom I need to gear down a little my 2nd speed for instance to accel to a high speed that will fit down the straight way. That is why you sugested the 23/55 combo to be able to face the mugens.
Old 05-10-2004, 08:54 PM   #10059
InitialD's Avatar
No. I suggested using 21/57 (5.09 FDR) gearing and a smaller tire than the Mugen, with all things like engine being equal !
If the Mugen is using stock gearing for your track, then using 23/55 (4.48 FDR) will make your car overshoot out of the track !
Old 05-10-2004, 08:59 PM   #10060
Send a message via AIM to kreidel
Need some setups
InitialD,
Friday night I ran the 710 and found I needed more steering. I disconnected the front sway bars and that helped alittle. It was getting close to race time and ended up racing the Mugen instead. I was hoping you might have some better setups for smaller technical tracks that I would use the solid axle for. I am not really in the "find the perfect setup" phase and was hoping to cheap out and come across a pre-exisiting setup.
kreidel is offline   Reply With Quote
Old 05-10-2004, 09:05 PM   #10061
rwisejr's Avatar
Send a message via AIM to rwisejr
Thumbs up
brb
Yes it is !!!
rwisejr is offline   Reply With Quote
Old 05-10-2004, 09:07 PM   #10062
InitialD's Avatar
Default Re: Need some setups
kreidal, the front solid axle setup takes away a lot of steering. You could try my setup...
Suspension geometry Front:
Downstops: 1mm
Set-up ride height: 6mm (Actual ride height !)
Camber Left: -1.5 degree
Camber Right: -1.5 degree
Track-width: 199mm
Toe-in: -2.0 degree (Toe-out)
Caster setting (mm in front): 1mm
Roll-center position upper arm (mm): 4mm under
Upstop (mm): None
Suspension geometry Rear:
Downstops: 8mm
Set-up ride height: 7mm (Actual ride height !)
Camber Left: -3.5 degree
Camber Right: -3.0 degree
Toe-in: +2.0 degree
Track-width: 197mm
Roll-center position upper: outer (UBO)
Roll-center position lower: low (LB)
DRS arm position (low-mid-up): Up
Shockabsorbers Front:
Springs: yellow
Oil: 30W
Holes: 5
Cilinder type: composite
Shock-tower position: 2nd hole
Shockabsorbers Rear:
Springs: yellow
Oil: 30W
Holes: 4
Lower shock position: outside
Anti-roll bar front:
Thickness: -
Position: No Anti Roll Bar installed
Anti-roll bar rear:
Thickness: standard
Position: 3 mm from the end of bar
Position on lower arm: outside
Tires Front:
Make: Ellegi 6 spoke (Serpent)
Hardness Left: 37 shore
Hardness Right: 37 shore
Diameter: 62mm
Wear in 5 min. Left:
Wear in 5 min. Right:
Tires Rear:
Make: SpeedMind Dishwheels
Hardness Left: 40 shore
Hardness Right: 40 shore
Diameter: 62mm
Transmission:
Pinion 1st: 16T
Pinion 2nd: 21T
Gear 1st: 61T
Gear 2nd: 57T
Front axle:
Type: Locked to solid axle
Diff. setting: Locked to solid axle
Rear axle:
Type: adjustable diff
Diff. setting: light (when hot)
Aerodynamics:
Body: Protoform Stratus 2.1
Wing: Standard
Gurney strip: -
Engine and pipe:
Engine: NovaMax 5 port
Version: P5
Head shims: 0.4mm
Glowplug: 6TF
Pipe: RDLogic (7.2 mm inline)
Header: Novarossi (short inline manifold)
Length: Approx 88 mm
Fuel: 25% Tornado
You could try 1 grade softer front and harder rear.
Old 05-10-2004, 09:15 PM   #10063
Suspended
hudy's Avatar
I think that the 710 has earned a new name "glass car" this **deleted** breaks if you blow air at it very weak plastic and parts I sold mine for 50 dollars at the track very dissapointed
Hudy...DO NOT POST THAT TYPE OF VERBAGE ON THIS SITE AGAIN. THANK YOU
mr. losi
hudy is offline   Reply With Quote
Old 05-10-2004, 09:29 PM   #10064
InitialD's Avatar
Hey Mr. Hudy, you should have sold that glass car to me. I would have bought 10 from you.
Old 05-10-2004, 09:33 PM   #10065
I think that the 710 has earned a new name "glass car" this motherfucker breaks if you blow air at it very weak plastic and parts I sold mine for 50 dollars at the track very dissapointed
you should've called me also,
I know you are mad, but dont curse man, it doen't help any and it just makes you look bad, I would edit me post man.
I was having severe problem also, but you just need to give the car a chance. i agree the car is weak, but when its set up it drives like a mother#%$^&% lol
sorry to hear you are upset. So what are you going to buy now?
