Serpent 710
#961
Originally posted by GoldFinger
I think you should try it.
We been using it with no problem even for rear suspension ( with 4.5 - 5 deg camber), means only 3/4 (threaded part) part is threaded to arm.
I believe if you use use -4 to -5 camber, your trackwidth exceed beyond 200 mm a lot with the stock upper rear arms. What I do is I modify the rear upper arms to shorten it so that I can still use -3 camber under 200 mm (198 mm actually).
The rear pivot ball threading also need not be exposed too much.
Just once i ever seen it popes out from the fc blocks(in front) after hard slamming in brick wall, but its still hold up well in the both arms.
#962
#963
Originally posted by InitialD
Yes I am. Front and rear.
Any idea to solve this?
#964
FPS
Will the FPS, fit in the 710??,, Just curious, cuz i like the way it handled right now,, BTW, Julius I follow all the instructions to built the FPS diff. that you wrote a little while ago in MYTSN, and it works Great!!
Ciao!!
Ciao!!
#965
I must try this..Actually I did the 5deg. camber with optional 8mm wheel hub.
Only works in touring post, track width is almost 200mm
Doesnt work in lola style, coz the wheel is scrubbing the mounting arm.
#967
Seen it?
There is an ad of 710 on RC Car Action - Jan 2004 issue.....
Page 241
http://www.myTSN.com/Serpent710
Page 241
#970
The other thing that I do not like about narrower hex wheel adapters is that it makes the thread of the drivecup where the wheel nut goes in to be exposed a lot. Very susceptible to breakage if you happen to hit it directly. Happened once to me.
#971
Mine, bleeding slowly through the shaft when I put it in the stand overnight. So I must use the old red ones instead the low-friction purple Oring. But this purple is doing very fine job in the composite body.
Perhaps your aluminum shock body where the shock shaft hole is located is loose due to wear... Does this happen to all your aluminum shock bodies?
#972
#973
Fuel Tank??
Hey guys,,
Did anybody now about the fuel tank,, remenber that the filter inside that tank where not made from the same quality like the old tank, so we have to use externals fuel filters to solve some engine tunings problems!!,, Any body from Serpent Guys like to coment in this??
Ciao!!
Ciao!!
#974
First time I'm hearing this... What about putting some AE green slime in the o ring?
But when I try it myself for 2 RR alu body with TRY#90 shock oil, yes ! it bleeds trough the shaft in the morning. Then I replace it with the red ones and it was doing fine till now.
And trully I have not try do it again.
#975
[I believe if you use use -4 to -5 camber, your trackwidth exceed beyond 200 mm a lot with the stock upper rear arms. What I do is I modify the rear upper arms to shorten it so that I can still use -3 camber under 200 mm (198 mm actually).
probably see many aluminium options parts over the next couple of months.....
