Old 09-21-2004, 09:29 PM   #15961
packetdreamer's Avatar
Send a message via AIM to packetdreamer
Default Re: New 2.5/3mm rear bar
Originally posted by TitaniumR
Wow, this thread moves fast!
this is the serpent 710 thread, my man. if you wanted something that moved at a more casual pace, you should try the __________* thread.
pd.
*be nice
packetdreamer is offline   Reply With Quote
Old 09-21-2004, 09:32 PM   #15962
InitialD's Avatar
Default Re: Re: New 2.5/3mm rear bar
Originally posted by Sow&Steady
They feel that with their particular set-up and the high grip track, they needed to prevent the rear part of the chassis from rolling in order to reduce front grip. Strange but that is what I heard.
I think the sway bar settings in general has got a lot to do with relative settings. How hard is the front / rear sway bar compared to the other.
I found that if I set the rear sway bar harder, I would get more on power steering. The rear of the car squares up better and faster in the chicanes.
My sway bar setting with the oneway front;
Hardest (90 degree) in front
Approx 12 mm from edge of the stock 2 mm sway bar and with the sway bar connected to the inner mount on the lower rear arm (not outer as per stock)
Yellow front spring (3rd position on front shock tower)
Red rear spring (3rd position on rear shock tower)
40 wt Serpent Oil with 4x1.2 mm holes all around
Rear diff is medium hard with 40 shore tires all around.
As for you test. If you're looking for on-power steering, the first thing to try is to increase caster.
Yeah that's a quick way but I would look into the rear toe in. Less rear toe in = more on power steering not to mention higher top speed.
Old 09-21-2004, 09:34 PM   #15963
InitialD's Avatar
I can definitely feel that the yellow shoe is softer than the black one. Maybe my black shoe is old stock and the yellow ones are "fresh".
I find the black ones flake easier. The yellow ones are more wear resistant.
Anyway, next experiment ... JP RED shoes.
Old 09-21-2004, 09:36 PM   #15964
InitialD's Avatar
Originally posted by packetdreamer
is the melt down generally caused to the nut setting being too loose or too tight in the clutch?
More often when it's set too tight causing the clutch to slip a lot.
Old 09-21-2004, 09:37 PM   #15965
Sow&Steady's Avatar
Default Re: Re: Re: New 2.5/3mm rear bar
I would be testing this setup of yours too.
That's what I love about this car ... it allows me to mess around with the setting and still be able to drive it ... unlike the older brother the 705!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 09-21-2004, 09:58 PM   #15966
redsand's Avatar
Send a message via Yahoo to redsand
Originally posted by Pyramid
Clearer pics (I hope ) of what recent new hop ups available for S710,
Peter, are those new 710 stuff avail in Jkt yet ? If so, I will call Suryanto to order for myself and other 710 drivers in Bdg. We need part support from you bro !!
Speaking of the new servo saver, I dont see the difference with the stock one. Tell me what the new one has to offer.
redsand is offline   Reply With Quote
Old 09-21-2004, 10:55 PM   #15967
markp27's Avatar
Send a message via ICQ to markp27
Originally posted by sn4il
Hehe. No way. Ive never driven rc car before.
Can I do the brake-in on the starter box?
Thank You all for replies and helpful tips.
Max
Not as bad as it sounds Seriously, once you've richened the engine a good amount, then the car won't be going anywhere fast Maybe best would be for you to do it in a parking lot, where you could drive in a large oval.
Doing the break-in on a starterbox wouldn't provide any load on the engine and maybe there is a danger of reving too high.
markp27 is offline   Reply With Quote
Old 09-21-2004, 10:59 PM   #15968
markp27's Avatar
Yes, that's what a lot of guys here are saying but that's the trade-off one would need to evaluate hence why I wanted to test them.
It seems they last a good 2 full races (3-4 heats and mains), so it they're truly low-friction, I'm willing to try just to beat Mark.
Well I never!!! Your are a cad and a bounder, sir!
Old 09-21-2004, 11:02 PM   #15969
markp27's Avatar
Yellow clutch shoes soft? Their material is harder than the stock black one.
I have actually not replaced the clutch shoes yet since I got the car this year. Black or yellow.
What about Crashed_1? He wears everything out
Old 09-21-2004, 11:04 PM   #15970
markp27's Avatar
Getting desperate?
I think Mark is preparing some special stickers at the rear end of his bodyshell which should read "Eat my (tire) dust" or "Catch me if you can".
I've actually fabricated a large square lexan plate which I'm mounting on the rear of the car, "There can only be one!" in very large letters (therefore the large lexan plate), so even Sow can see it. Not sure what'll do to the Aerodynamics yet
Old 09-21-2004, 11:06 PM   #15971
markp27's Avatar
Getting desperate?
Just look at all that new stuff he's been buying Not to mention customising the car with tips from top Serpent Driver Mark Green Wait a minute! Rene, can you please help me to kick Sow's arse!!! Any tips and new bits you guys have for the worlds would be nice......but don't tell Sow about them
Old 09-21-2004, 11:08 PM   #15972
markp27's Avatar
Default Re: Re: hey SOW & STEADY
See someone still hangs around those German forums!!!
Old 09-21-2004, 11:11 PM   #15973
markp27's Avatar
Default Re: Re: Re: Monoblock
New chassis?
Agreed. I found that on hard frontal impact, the chassis bends at the engine area as well as the part where the receiver pack sits. I think the aluminum X bar support and the monoblock would be better to resist bending at this area.
Looks nice on my car
Anyway, talking about the worlds in Brazil, I believe from Team Serpent Holland, only Michael is going?
Seems Julius is AWOL Flying too much I reckon!
Old 09-21-2004, 11:14 PM   #15974
markp27's Avatar
Definitely getting desperate, he's going to be at the track before me!
PAH! I've never seen the track in my life - ehm and I wasn't that hooded figure there last week, honest!
Onkel Sow has spun a yarn about flying off to America this week, just so he can go to the track (which just happens to be his LOCAL track) and practice each day
Old 09-21-2004, 11:19 PM   #15975
markp27's Avatar
Default Re: Re: Re: Re: New 2.5/3mm rear bar
Man he'll try anything, won't he!
