Serpent 710
Old 04-20-2004 | 10:55 PM
  #8551
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Last pieces of the 710 Jigsaw!
Originally posted by InitialD
Sounds like a marriage proposal !
I should stop using that line could be dangerous with girlfriend - she could get the wrong idea!
markp27 is offline
Old 04-20-2004 | 11:12 PM
  #8552
BaxterC's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Last pieces of the 710 Jigsaw!
Originally posted by markp27
With the cold it is really weird - I don't wear very thick clothing, I only have a "Windstopper" jacket and a couple of normal longsleved cycling jackets, but somehow I don't really notice the cold. And even though it is now relatively warm on a morning (i.e. 5 Deg C) I'm wearing the same clothing, just one long sleved jacket less Works for me
Motivation isn't a problem for me - it comes down to self pride: I never give up. I can forget about wining these races, as quite a few of the professional riders take part - I've got no chance against these guys. Me best result so far is 120th place from 5500 starters - good enough for me!
It is a good thing you have the power to go on... I need a little help when it comes to physical torture... 120th out of 5500... WELL DONE!!!
BaxterC is offline
Old 04-20-2004 | 11:16 PM
  #8553
PSI Racing's Avatar
Default Re: Re: Josh Cyrul's servo of choice
I was looking through the G4 thread and noticed that the G4 had a steering lock out problem... Perhaps Josh's choice of the KO 2344 high torque servos instead of the faster KO 2343 had something to do with it... Just a thought.
Well, Josh said he used the 2344's on all his nitro cars.
Is he still running the G4?
PSI Racing is offline
Old 04-20-2004 | 11:29 PM
  #8554
InitialD's Avatar
Default Re: Re: Re: Josh Cyrul's servo of choice
Don't think so but after the split, he has yet to run the FW05R I'm told. I guess it's much easier for him to run all 2344 servos throughout.
InitialD is offline
Old 04-21-2004 | 12:43 AM
  #8555
Blue Sky's Avatar
Default Optional front drive shaft 808220
What is the difference between the stock drive shafts that come with the kit and this 808220 drive shaft? I thought the 808220 is made of spring steel, and is brown in color? I got a pair and it's black. What's with that? Thanks.
Ron
Blue Sky is offline
Old 04-21-2004 | 01:29 AM
  #8556
InitialD's Avatar
Default Re: Optional front drive shaft 808220
Blue Sky, any pics? The 808220 should be spring steel stuff and should be brown in colour. They are actually 1 mm shorter than the original steel dogbones.
InitialD is offline
Old 04-21-2004 | 03:57 AM
  #8557
KevinS's Avatar
I think both the Impact and 835 4WD cars came stock with the Hudy spring steel driveshafts. Look at the productinfo of both cars on MyTSN; with the 835 it's mentioned that the Hudy driveshafts are stock, in the pics of the Impact 4WD you can see the brown shafts.
Look for 808220 at MyTSN and you will find brown-ish shafts too. Look on the Impact 4WD parts lists page at front suspension & wheelaxles and they are mentioned as 'spare' not 'optional'. The way I get it, there are no regular dogbones for the Impact/835, only the Hudy ones. My guess is the black ones just have a different finish?
KevinS is offline
Old 04-21-2004 | 06:11 AM
  #8558
Wap
Default Re: Re: Re: Re: Diff.
The silicone grease should be fine. The Mugen Super Grease is better in my opinion.
You could also smear just a little of silicone grease or silicone oil from the shocks on the main 2 speed shaft and the mid shaft where the bearings are on. That would avoid pre-mature wear and deep groove marks on the shafts.
For me, I also clean all the bearings from their original grease (except the small ones in the Centax clutch and the ones that go in the steering linkage) and relube them again.
thanks again; this thread is great
Wap is offline
Old 04-21-2004 | 07:32 AM
  #8559
BaxterC's Avatar
Default Re: Re: Re: Re: Re: Diff.
that it sure is... it helps when you have the guys that run serpents sharing there wealth of knowledge
BaxterC is offline
Old 04-21-2004 | 07:56 AM
  #8560
Pyramid's Avatar
Registered User
Ron
I think you just got a bad batch... just bring them back and have them exchange..
Pyramid is offline
Old 04-21-2004 | 08:08 AM
  #8561
Arent the 835 shafts longer...?
Profoxcg is offline
Old 04-21-2004 | 08:12 AM
  #8562
Default tire truer
I got a true, actually it is in layway for a few weeks, but...
I wanted to know what is the "camber" 1 and 2 deg way of cutting rear tyres is for?
the truer has and adjustment there to cut at an angle...
BTW i got the 3racing 1mm ofset wheels a few minutes ago and they fit perfectly and help the rubbing some. Also they seem much nicer and well crafted compared to the serpent ones.
maybe 3 racing is not that bad after all.
I want to buy their alum pulleys, has anyone tried them yet?
Profoxcg is offline
Old 04-21-2004 | 08:17 AM
  #8563
BaxterC's Avatar
As far as I remember, thay are the same as the 710, but I dont know for sure.
BaxterC is offline
Old 04-21-2004 | 08:20 AM
  #8564
Default rear roll center
I just want to confirm what initial D told me the other day to see if I understood.
both inner and outer inserts should have the same possition in order to change the roll center correctly ? - whatever changes i make to the inserts on the rear shock tower side, i make to the oposite end.
thanks
Profoxcg is offline
Old 04-21-2004 | 08:29 AM
  #8565
Default Re: rear roll center
I am not sure what you mean by "inner and outer" inserts.
To change roll center properly, both inserts at the end of the same pin must have the same orientation. And the inserts must be the same on the left and right sides. (For the rear upper inserts, the left and right inserts will be mirror images.)
Hope this helps... or does it only confuse things more?
GlennCauley is offline
