Serpent 710
Old 04-01-2004 | 02:21 AM
  #7396
jfc_tech's Avatar
originally posted by InitialD on other thread
I have a Shooter 4 mm chassis for my 705. I saw a Shooter aluminum middle bearing block and a hollow 2 speed main shaft option for the 950. Recently, I saw that they have a lighweight main shaft for 710 too.
cool...lightweight shaft...are ye using it already D? Is it in stock in semenanjung already?
jfc_tech is offline
Old 04-01-2004 | 03:15 AM
  #7397
sparksy's Avatar
I have the shaft. Its not a bad little bit of kit. From memory it is a 10gm weight saving over stock.
sparksy is offline
Old 04-01-2004 | 03:32 AM
  #7398
BaxterC's Avatar
what sort of a performance increase does that give you on acceleration?
BaxterC is offline
Old 04-01-2004 | 03:53 AM
  #7399
Thumbs up Nice work, Jabroni !
Jabroni, that is sure some nice work!
Wish mine looked as clean... I have wires bundled atop the steering servo, not hidden.
Curious about one thing... with the expenditure on alloy parts and SSG, why did you keep the stock plastic radiotray support?
I would think that would be the FIRST thing you would replace with an alloy part to increase torsional stiffness.
GlennCauley is offline
Old 04-01-2004 | 05:29 AM
  #7400
Marcos.J's Avatar
Super Moderator
it should accelerate faster since it has less rotating mass!
Marcos.J is offline
Old 04-01-2004 | 05:40 AM
  #7401
BaxterC's Avatar
True, but right in the beginning of the forum, I cant remember who it was, but I think it was Julius who said that the lighter shaft will make very little difference to the acceleration. However, I would think it would make a difference, as the overall weight is affected and that will make the difference. But I think the titanium shaft will be much more resilient to damage.
Can you see the difference in acceleration?
BaxterC is offline
Old 04-01-2004 | 05:41 AM
  #7402
Marcos.J's Avatar
Super Moderator
Default Re: Radio Tray Work
i will be afraid to run that car and get it dirty
Marcos.J is offline
Old 04-01-2004 | 07:37 AM
  #7403
pelos's Avatar
Default My beloved 710
Hope you enjoy it
pelos is offline
Old 04-01-2004 | 07:38 AM
  #7404
John Fontaine's Avatar
That's nice looking!
John Fontaine is offline
Old 04-01-2004 | 07:40 AM
  #7405
InitialD's Avatar
I have the 3Racing titanium shaft on the 710. So does crashed_1. Did not weight it but it is certainly lighter than the stock one.
InitialD is offline
Old 04-01-2004 | 07:51 AM
  #7406
InitialD's Avatar
Default Re: Nice work, Jabroni !
Just guessing here but I think it's because he has not have them yet?
InitialD is offline
Old 04-01-2004 | 07:52 AM
  #7407
InitialD's Avatar
You are right. Somebody mentioned about it. I believe it was Michael Salven. It was actually to give a reason why the shaft on the 710 was not hollow. The weight reduction in terms of rotational mass is insignificant considering the fact that a hollow shaft would greatly reduce strenght. Rotational mass savings would be insignificant due to the mass being centered very closely to the rotational axis.
Yes you are right. No doubt that there is some savings in rotational mass as well as static mass. Don't know about being more resilient though. I know that the 2 speed shaft on the 705 is pretty susceptible to bending upon impact.
I guess !
InitialD is offline
Old 04-01-2004 | 08:27 AM
  #7408
Marcos.J's Avatar
Super Moderator
I guess !
so for impact purposes ,leave the stock shaft for reliability!
Marcos.J is offline
Old 04-01-2004 | 08:37 AM
  #7409
InitialD's Avatar
I think the stock shaft on the 710 is much better than on the 705. Anyway, if the 3Racing shafts are indeed of good titanium grade (which I think they are), then it should hold up.
p/s: Congrats ! You've reach your 1st 1000 posts !
InitialD is offline
Old 04-01-2004 | 08:43 AM
  #7410
Marcos.J's Avatar
Super Moderator
thank you only 8,000 more to go to catch you
Marcos.J is offline
