Old 03-14-2004, 11:15 PM   #5896
InitialD's Avatar
Originally posted by SupermaxxRich
I measured the depth of the groove that is machined into the aluminum wheel hex adapter and both are the same depth. So there must be something else off? I'll try and measure both knuckles to see if they are the same thickness??
Try to make sure that the pin sits properly into the groove of the aluminum hex adaptor properly. Make sure you tighten the wheel nut.
Old 03-14-2004, 11:23 PM   #5897
cyba888's Avatar
Originally posted by InitialD
How much off are you getting? If it's a lot, then it could be that your shocks need to be refilled and rebuilt.
The shocks should settle nicely when you compress it a little or a lot to the bottom.
Its off just by .5mm or so, maybe 1mm max
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 03-14-2004, 11:29 PM   #5898
SupermaxxRich's Avatar
I'm stumped. Can't figure it out! I gone and measured everything. It all measures out ok. I've even taken the axle drive cup thing. Put the pin through it and then installed the aluminum wheel hex on both front ones and all the measurements are within 0.01mm. I've measured the knuckles and they are the same thickness as well. Don't have a clue. I'm going to reloook at everything again. I doubt I'll find anything new? Thanks. Talk to you later.
SupermaxxRich is offline   Reply With Quote
Old 03-14-2004, 11:30 PM   #5899
Hey Goldfinger, did you say you had to use shims on where thr wheel hex adapter goes? If so, what size?
Old 03-14-2004, 11:31 PM   #5900
InitialD's Avatar
You need not compress your shocks fully down to take a reading. You'll probably destroy the shocks even before playing !
Perhaps the reason why you're getting off numbers is because you did not compress the shocks nicely. Sufficient compress on the chassis a few times should do the trick to get a good number.
Old 03-14-2004, 11:39 PM   #5901
markp27's Avatar
Send a message via ICQ to markp27
Oh great master D! How did the front/rear wear on the tyres of the 705 compare to the 710? i.e. with your normal split, does the 705 wear its tyres equally?
markp27 is offline   Reply With Quote
Old 03-14-2004, 11:39 PM   #5902
No... that .6mm play is without wheel. When you tighten the wheel nut is will down to max .3mm.
What Pyramid and I do is put shims between axle and inner bearing.
Dont worry, I put the shims already.
GoldFinger is offline   Reply With Quote
Old 03-14-2004, 11:42 PM   #5903
markp27's Avatar
D - BTW: Ordered my Ti screws Did you get some of the tapping screws, too? i.e. the 2.5mm one for the chassis?
Old 03-14-2004, 11:44 PM   #5904
InitialD's Avatar
It does. I started with a split of about 4 mm and ended with 3.5 mm on the 705.
But even then, I used 40 shore in front and 42 shore in the rear. Perhaps the rear end was sliding a little more than I wanted with the harder shore and oneway front.
I notice that running front diffs or a solid axle really conserves the tires and make them wear equally as you can slow down before taking a turn.
Old 03-14-2004, 11:45 PM   #5905
Thanks alot Goldfinger, your the man! I owe you.
Just double checked everything and its both front axle drive cups that have 0.6mm play. I didn't notice the other because it fits a little tighter in the bearings. I checked the rear knuckles and they have virtually no plat at all? I guess I'll just have to wait for the shims from Goldfinger. Thanks again. Can't wait to get them! Let me know. Later...
Old 03-14-2004, 11:47 PM   #5906
where are you ordering your Titanium screws from Markp27?
Old 03-14-2004, 11:47 PM   #5907
InitialD's Avatar
Tamiya?
I use back the same steel self tapping screws. I think the size is weird as it is not 2.5 mm or 3 mm but it's 3.5 mm and some even at 2.9 mm !
Old 03-14-2004, 11:48 PM   #5908
Im dying for that too Mark..
Tobee is have the aluminium ones, but havent trying yet.
Old 03-14-2004, 11:50 PM   #5909
markp27's Avatar
Got them from www.rccarinternational.com simply the Tamiya ones. Bloody expensive though!!!
Old 03-14-2004, 11:52 PM   #5910
markp27's Avatar
Tamiya?
Well, you know I need to replace the ones from my Surikarn, since you Jedi mind-tricked them away
Ach, yes, 3.5mm I new the size was pretty weird - perhaps I can get some Alu ones - the Alu ones are just as light, I think.
