Serpent 710
#7247
Originally posted by r/c news rep
Just read an article on the associated press ,about the rumors of Hara testing for Serpent ? Will post more as more news develop.
He was seen testing the 710 and the 950 1/8 scale (f-1),with great results. Will be posting pictures soon ,as soon as my publisher lets me. The test site at this time it's unknown but the details will be released soon.
Is there any truth behind this rumor?
This guy, "r/c news rep" started a thread here in the Nitro On-Road forums about this.
Any Serpent guys care to comment on this?
#7248
Originally posted by PSI Racing
Atsushi Hara Switching Manufactor?
This guy r/c news rep started a thread here in the Nitro On-Road forums about this.
#7249
After the first 40 min run I serviced my 710. I put all together (radio tray, motor, clutch and gear) but now the clutch slips
It was working perfectly!
I checked 5 times the clutch gap and the end play as in the manual. I loose the clutch spring more than one turn but the problem is still there.
I am not able to understand if I made a mistake or the clutch shoe is burn out...
It was working perfectly!I checked 5 times the clutch gap and the end play as in the manual. I loose the clutch spring more than one turn but the problem is still there.
#7250
Atsushi Hara Switching Manufacturers?
As I recall , he ended up having to buy an out of the Box NS3 from the hobby shop and tuned it to perform as well as possible given the time he had with it.
(I purchased the next one with a serial # close to his !!!!)
In any event, it appears that if the rumors were to be true he could be a great addition to the Serpent Team for the Future !!
#7252
All I have to say is that Goldfinger is a great guy!!
He hooked me up with some shims for the shocks and for the front wheel axles and shipped them to me all the way from Indonesia!
Thanks alot Goldfinger, I really appreciate it.
#7253
I'd have to disagree with you guys on that Nitro doesn't make more power. I build drag race engines for a living and I have customers that run methanol and Nitro methane. Put it this way, guys running methanol only, with better superchargers, more boost and better cylinder heads make about 3000-3500 Horespower. Guys running Nitro about 90%, with less boost are making about 8000 HORESPOWER!!!!
There is alot of power to be had with Nitro. The extra power that comes from Nitro is because it is actually quite explosive.
Nitro actual explodes in the combustion chamber. On the engines that are running Nitro in Drag Racing, it is so explosive and there is soo much cylinder pressure that after every pass all the bearings in the engine have been completely pounded flat! Now thats power! Just my two cents.
#7255
Originally posted by Marcos.S710
BaxterC check out the mugen mtx3 vs. hpi r40 forum , "fastharry" is already bashing the serpent there ( he always does that!!)
I think he was really pissed when he asked what bbntc3 from the NTC3 forum thought about the 710 and he replied to say that the R40 was no match and that the 710 was a different story as it is almost enough to make a man switch cars !
#7259
Originally posted by GlennCauley
However, with too small a clutch gap, the shoe may engage too soon and at not high enough speed, resulting in engine bogging. It might wear out the shoe prematurely.
Smaller clutch gap requires harder Centax pre-tension nut setting to get enough RPMs without engine bogging !
#7260
Guys wish me luck i have a race at Lakeland Florida this weekend hope my serpent does very well i did some changes on it that InitialD recommended so we will see , there alot of mugens at that track , so i hope that serpent comes out on top again!!
Blast them out of the water Marcos !
