Serpent 710
Old 04-25-2004 | 07:41 PM
  #8896
InitialD's Avatar
Default Re: I would just like to make it clear to everyone....
Originally posted by markp27
There's a race on at my circuit this weekend - I can't test/tune my 710
I feel for you ! But why not make a trip down Heemstede track this weekend?
InitialD is offline
Old 04-25-2004 | 07:42 PM
  #8897
InitialD's Avatar
Default Re: Re: Re: One Way
Originally posted by Wap
thanks punisher, also i have the lock set for the one-way. My question is should i install the collar that came with the lock set and keep the collar on all the time if i want to try the solid axle all i have to do is insert the pins.
Yes. I believe Glenn Cauley suggested to use it even though you use oneway. This is to keep dirt and dust out of the oneway bearings.
InitialD is offline
Old 04-25-2004 | 07:44 PM
  #8898
InitialD's Avatar
Default Re: Setting throttle max travel.
Does this method set the max travel accurately, i.e. give max possible throttle?
As long as you can open the throttle fully and everytime you WOT, then it should be OK. Of course, the servos should not strain so much when the throttle slide is fully open.
InitialD is offline
Old 04-25-2004 | 07:45 PM
  #8899
InitialD's Avatar
Default Re: rebuilding diff
Originally posted by Profoxcg
Can i put the serpent 50wt silicine diff. lube on the truss bearing (please correct my spelling) instead of the graphice grease?
The Serpent 50wt shock oil is still to thin for the thrust bearing. You need sticky grease.
InitialD is offline
Old 04-25-2004 | 07:50 PM
  #8900
InitialD's Avatar
Originally posted by cox049
Hey Pit where can I buy that bumper brace. It looks good! So with the rest of your car buddy
For your info, 3 Racing also has them. Not as big as the one on Punisher's car though.
Front
Rear
InitialD is offline
Old 04-25-2004 | 07:51 PM
  #8901
InitialD's Avatar
Default Re: Re: rebuilding diff
I mixed the graphite powder with 7000 diff lube and got a good sticky grey thing for thrust bearings
I believe dry graphite powder lube is expensive for the small amount you get. Why do you mix with diff lube? I believe you can get the wet type of graphite grease very easily and cheaply.
BTW, if you already have the Mugen Super grease, use that on the thrust bearings.
InitialD is offline
Old 04-25-2004 | 08:17 PM
  #8902
Are those 3 racing swing shafts any good?
kreidel is offline
Old 04-25-2004 | 08:54 PM
  #8903
Pit-racer's Avatar
Originally posted by InitialD
Nice ! How does it compare to NS12 and Punisher's Colari Mod Sirio engine?
I leave Punisher's mod colari behind with my ns12s3. I haven't compare side by side but it feels about the same at the throttle w/ the ns12.
Pit-racer is offline
Old 04-25-2004 | 08:58 PM
  #8904
Pit-racer's Avatar
As for the bumber brace....I needed strength and not just bling-bling. That picture was taken after the head on crash, but with a new shock tower only replaced!
Old 04-25-2004 | 09:02 PM
  #8905
Default Pit racers exhaust pipe
I am trying to learn to determine what shape of pipes denote a low end or high end or good overall pipe.
from looking at Pits races pipe, i would say that is more of a high end pipe / overall.
correct?
thanks
Profoxcg is offline
Old 04-25-2004 | 09:27 PM
  #8906
Registered User
hey uys i was wondering where the best price on a 710 is and for parts to thanks Jesse
J FAST is offline
Old 04-25-2004 | 10:03 PM
  #8907
FAST1's Avatar
Do you speak english??
FAST1 is offline
Old 04-25-2004 | 10:16 PM
  #8908
markp27's Avatar
Default Re: Re: Setting throttle max travel.
I feel for me, too as for Heemstede, i have two words for you: Girlfriend & Birthday And maybe it'd be a bit excessive just to run my engine in
This is where my question came from. The servo starts to strain and flexes the carbon plate when it pulls the last little bit on the throttle linkage. But once I took the air filter off and looked at the throttle movement within the throttle barrel, I could see that before the linkage had reached the end of its travel, the throttle had already cleared the throttle barrel, i.e. no longer visibile.
Also, at this point, the servo isn't straining.
Cheers, Mark.
markp27 is offline
Old 04-25-2004 | 11:22 PM
  #8909
markp27's Avatar
Default 710 FAQ
A small update to the FAQ - this time including tips on Engine tuning/break-in - useful for me
The next big overhaul is planned, but time is short at the moment, so it'll probably take a while before I can do this.
Cheers, Mark.
File Type: pdf
markp27 is offline
Old 04-25-2004 | 11:45 PM
  #8910
Thumbs up Re: 710 FAQ
Cheers, Mark.
Thats cool mark thanks for all the new tips and to everyone else that has contributed for this faq.
I, as i suspect everyone, in here appreciates what you have done here to help people
Thanks again
Brett
Brett.w is offline
