Old 11-30-2003, 10:46 AM   #1396
InitialD's Avatar
Default Re: Re: Re: Re: Re: lola style?
Originally posted by Fernando_M
Here is the front GTP body mount from my Impulse. It is an Impact front body mount. I reduced the width and it fitted perfectly. However, I could not make the downstops holes, as it would weaken the part too much. The bumper is also a shortened Impact one.
I found this approach to work very well. However, the best result was when I adapted a Serpent Excel front body mount. Though, it is hard to get.
BTW, this was done when the Serpent front bumper for the Impulse/705 was not available.
Fernando, that is cool. Thanks for the pic !
Old 11-30-2003, 10:52 AM   #1397
markp27's Avatar
Send a message via ICQ to markp27
Originally posted by InitialD
That I have a German baby?
There could be trouble ahead....
markp27 is offline   Reply With Quote
Old 11-30-2003, 11:04 AM   #1398
Send a message via ICQ to lawndoggie Send a message via Yahoo to lawndoggie
Default Narrower front tires
Hey!
Someone people at the track told me about using tire truer to trim the front wheels from 26mm to 24mm.. they said it makes the car turn better...
Basically while the truer is turning the wheel, use an xacto knife to cut 2 mm of the rim...
Have anyone tried this??
I thought its a good idea because it gives better clearance between tire and steering block/steering ball joint...
lawndoggie is offline   Reply With Quote
Old 11-30-2003, 11:12 AM   #1399
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
less tire turn better... no it will allow less front traction and turn less, if they feel it turns better they need to take some front bite out and are probably oversteering the car and hooking...
ammdrew is offline   Reply With Quote
Old 11-30-2003, 11:22 AM   #1400
Lifting off the ground? How do you mean by that? How do you know that the wheels are lifting? Are you using front one way?
Uhhh.. my car flips at sharp turns...
And yes I am running oneway front..
Old 11-30-2003, 11:57 AM   #1401
oh I have another quick question.
I have been told that my tires should have even wear, but if there is chamber how can they have even wear?
Old 11-30-2003, 12:48 PM   #1402
ammdrew's Avatar
best thing you can do is true your tires down to a 60mm or so ht,, and run a 4 or 5mm rd ht, that will minimise traction roll... and a harder tire would help too..
Old 11-30-2003, 01:46 PM   #1403
fmolzer's Avatar
With the correct camber setting you will have even wear. As the car rolls through a corner, due to suspension and centrifugal force, the tire will have more pressure on the outside side of the corner. With camber, you allow the tire with more traction (outside tire) to be upright as it goes through the corner voila- even wear....
fmolzer is offline   Reply With Quote
Old 11-30-2003, 02:13 PM   #1404
Default Re: Narrower front tires
Hey!
I do this all the time, but not for steering reasons. I gues that less front rubber means less steering...
I do it to have better clearance with the ball joint. Normaly, I reduce my Ellegis (disk wheel) front tires to around 25.5mm using the procedure you menioned. However, this will depend on the tires used. You gotta be careful when doing this.
BTW, this problem (clearance between tires and ball joints) seems to remain in the 710, as all steering block parts come from the 705 (FCs, wheelaxle, hex-adapter).
Fernando_M is offline   Reply With Quote
Old 11-30-2003, 02:21 PM   #1405
S710_Nut's Avatar
Sorry for the late reply. Here is a pic of what I meant...
Thank you InitialD...
S710_Nut is offline   Reply With Quote
Old 11-30-2003, 02:24 PM   #1406
S710_Nut's Avatar
Default 710 & Lola!
Guys,
All this talk on Lola bodies... Whats the go on Lola Bodies and 710? I read on the FAQ page you could do it, but will it be an aftermarket option or an option in the kit?
Old 11-30-2003, 03:42 PM   #1407
ammdrew's Avatar
okay if you want to make your tires smaller do it with a file from the side.. I have seen many xacto knife grab and go for a flight I would hate to see one of you most carefull rc racers lose sight in one eye because you were trueing a mm of tire width off.. yes you may have done it a hundred times but that one grab were the blade flies out of a 5000 rpm motor and hits you in the eye is the only one that matter, a rough grit file will quickly bing in the sides of your tires... with no ill effects to you your buddy or anyone...
Old 11-30-2003, 04:18 PM   #1408
FAST1's Avatar
Sheeezz!
This thread is moving like Michael Jackson on a young boy!!
710 bandwagon......com'on a board!!
FAST1 is offline   Reply With Quote
Old 11-30-2003, 05:51 PM   #1409
JA5ON's Avatar
Default Re: Re: Re: lola style?
The rear tower 808138 in not optional. It is needed as it holds the pin that keep the rear body support in place. I don't know the 808139, it is not in mytsn.
oh ya, thx for the reminder. actually i got all the stuffs needed but lazy to get it up, coz to do another body shell
JA5ON is offline   Reply With Quote
Old 11-30-2003, 10:57 PM   #1410
Hmm so the amount of chamber angle is highly in related to the amount of corners then!? Because say if the track is dead straight 90% of the time, there won't be even turns to give the outside of the tire pressure, and the wear won't be even....?
i.e the more turns, the more chamber angle??
