Old 04-28-2004, 01:47 AM   #9046
Default Radio
Hey guys i am thinking of getting a new 3PK but i dont know which one do i want 40mhz HR or PCM whats the difference?
Brett.w is offline   Reply With Quote
Old 04-28-2004, 01:47 AM   #9047
InitialD's Avatar
Default Re: Congratulations
Originally posted by Voodo_Magic
You should all give yourselves a pat on the back!
Ouch ouch ouch !
Ummm, does this mean that the new kits will have this FAQ printed is glossy paper?
Old 04-28-2004, 01:50 AM   #9048
InitialD's Avatar
Default Re: Radio
Apparently, HRS is faster than PCM. Whether you feel it or not is another question !
If you plan to use HRS receiver, then make sure ALL your servos are digital. PCM receiver gives you the flexibility of allowing you to run analog servos as well as digital servos.
Other than that, everything else is the same !
Old 04-28-2004, 01:51 AM   #9049
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Re: Congratulations
Originally posted by InitialD
Ouch ouch ouch !
I'd have to buy a new kit - I've heard a lot of good things about this FAQ
markp27 is offline   Reply With Quote
Old 04-28-2004, 01:52 AM   #9050
InitialD's Avatar
Default Re: Re: Re: Congratulations
That's one of the best excuses to get a new kit !
Old 04-28-2004, 01:53 AM   #9051
Make sure you lot get royalties or at least a free t-shirt!
Old 04-28-2004, 01:54 AM   #9052
Default Re: Re: Radio
I am using an OLD M8 at the moment which is despratly ineed of an upgrade do you guys recommend this radio?
Old 04-28-2004, 01:55 AM   #9053
Default Re: Re: Re: Radio
I am using an OLD M8 at the moment which is desperately ineed of an upgrade do you guys recommend this radio?
Whoops i pressed quote instead of edit sorry
Old 04-28-2004, 01:57 AM   #9054
InitialD's Avatar
What do you mean old M8? It's still one of the better radios out there. The top old dawgs arte still using them. Only lacking is a fail safe which you can get one externally.
If you wanted to upgrade something, I suggest getting better servos.
Old 04-28-2004, 02:00 AM   #9055
Default Re: Re: Re: Re: Radio
Its old and keeps turning itself off for somereason and there are no airtronic dealers around so by the time i have sent it overseas to get repaired i probably could have bought a new one and i would look at the new M8 but i thought this (3PK) might be better?
Old 04-28-2004, 02:04 AM   #9056
InitialD's Avatar
Default Re: Re: Re: Re: Re: Radio
I thought I heard that problem before and it was a very simple solution. Can't remember what it is. Perhaps somebody else can give some input on this...
Anyway, if the M8 is really toast, you may want to consider the KO Helios. I hear somebody got it and is singing praises ! Smallest receiver I've come across. The features are cool too. But the only downside is no built in fail safe.
Old 04-28-2004, 02:08 AM   #9057
Default Re: Re: Re: Re: Re: Re: Radio
OK i might do a search before i throw in the towel
Thanks for the advise "D"
Old 04-28-2004, 02:11 AM   #9058
Hurricane Sonic's Avatar
Default Serpent 710 FAQ
Hi all ~
I think the most important thing in the FAQ is in the last 2 pages ~ haha
my question is ... on page 25 , about engine ... what's WOT stand for ?
thanks ~
Hurricane Sonic is offline   Reply With Quote
Old 04-28-2004, 02:19 AM   #9059
InitialD's Avatar
Default Re: Serpent 710 FAQ
Wide Open Throttle
Old 04-28-2004, 02:35 AM   #9060
BaxterC's Avatar
Default Re: Re: Serpent 710 FAQ
Wide Open Throttle
I am going to do this when my kit arrives, I have a heat gun bought specifically for engine start up... and an engine run in bench... ONLY SERPENT for me thanks... and an engine asking to be started and run... only thing is I need to wait for my 710, for two reasons, I need the mounting screws, and the pipe is with the order.
BaxterC is offline   Reply With Quote
