Old 04-13-2004, 02:01 AM   #8146
InitialD's Avatar
Originally posted by NitroHead
Next time you feel yourself losing concentration, come in for a pit stop and do a little stretching to knock off the cob-webs!!! You would've won the race if you had!!!
That's a good tip ! Only if you know that you got a huge lead.
Old 04-13-2004, 02:02 AM   #8147
InitialD's Avatar
Originally posted by Sow&Steady
Or better still, come in for a pit stop and ask your pit man to clean your car's windshield!
Cool. And have coffee too?
Old 04-13-2004, 02:03 AM   #8148
InitialD's Avatar
Oh yes, still waiting for the damn shipment to arrive.
Can't wait to complete the rimmings on it!
What shipment are you waiting for? Christmas trimmings?
Hey, don't forget to shoot us a pic when you're done !
Old 04-13-2004, 02:04 AM   #8149
Sow&Steady's Avatar
Oh yes, coffee does help me with my concentration at this time in the morning!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 04-13-2004, 02:06 AM   #8150
Sow&Steady's Avatar
Oh, when I came to the UK I can only
"hide" so much in the suitcase (a 710 and an the old orange Loletta). The rest had to shipped by sea.
Will do for sure.
Old 04-13-2004, 02:11 AM   #8151
InitialD's Avatar
Oh yes. I forgot. But that was already sometime back right? Is the shipment including the rest of the loot? You could open an RC shop with all that stuff !
Old 04-13-2004, 03:31 AM   #8152
Diesel Racer's Avatar
Default Re: Re: 2nd Round Summer Series
Well done Diesel Racer, and I thought you said you're not that good!
I'm improving but still a long way to go.
Did you go to the last Nationals? You should with that kind of performance. Apparently Mark Green got 2nd.
At the moment there is not a huge depth of talent at the club, but like me they are improving
I raced two weekends ago too at AMCC (no race over the Easter weekend). Qualified 8th in the foam class but had to leave the race before the final started!
We had a great meeting and the weather was excellent, your going to have to come down S&S and show us how it's done.
Diesel Racer is offline   Reply With Quote
Old 04-13-2004, 06:15 AM   #8153
Schrijver99's Avatar
At the moment there is not a huge depth of talent at the club, but like me they are improving.
Racing at a club where there are alot of factory and importers-sponserd drivers isn't always fun.
At a clubrace you are lucky here to get in the B-final (more than 40 drivers in 1/10 200mm class).
On the other hand there is great support if someone has an problem or question (like me).
Schrijver99 is offline   Reply With Quote
Old 04-13-2004, 06:15 AM   #8154
whoops dubbel post.
Old 04-13-2004, 06:21 AM   #8155
Send a message via AIM to Profoxcg
Very nice body !!
I have a question,
I read that the lighter the flyweights, the later they will engage?
did I read right?
so if this true, I would want heavier flyweights (not modded sitting on the pins) so that my clutch engages at a lower RPM?
I have moded the weights, I have .5mm on the spring and .5mm of housing endplay. But my clutch slips now and then and I want to get it responsive so the car moves as soon as I touch the throttle. Should I buy a new clutch shoe?
Profoxcg is offline   Reply With Quote
Old 04-13-2004, 06:35 AM   #8156
Julius's Avatar
Originally posted by Profoxcg
Very nice body !!
I have a question,
did I read right?
The engagement RPM is influenced by:
- the clutchgap (between shoe and bell) Larger gap = later engagement
- The spring stiffness (stiffer = later engagement)
- The spring preload (more preload = later engagement)
- The flyweight weight (lighter = later engagement)
- The flyweight position (on pin gives later engagement then between pis for a same weight)
If you want the clutch to engage earlier the simplest way is loosening the spring preload.
If you modded the weights so they fit between the pins you may get an inconsitent clutch. This is because the angled portion of the weights is quite small and this makes the stick a bit when they move outward (only when cut and put between the pins). I currently am experimenting with a cut clutch shoe (I cut the holes out so I have three weights). They have a larger angled part which makes the clutch more consistent.
Be aware that you will lose bottom end when the clutch engages too soon.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 04-13-2004, 06:44 AM   #8157
thanks,
Old 04-13-2004, 07:31 AM   #8158
InitialD's Avatar
I'm actually interested to know how did you know your clutch slipped?
For me, I will classify my clutch slipping when the clutch engages but it will seem that the clutch does not grab the car and launch out of the corners fast as it should.
If you want a responsive clutch, you need to lower the clutch gap to 0.4 or even 0.3 mm.
.5mm on the spring and .5mm of housing endplay should give you a pretty responsive clutch with the flyweight mods unless like what Julius mentioned, the flyweights do not retract and get push out smoothly... I also suspect that it could be a problem of your engine. Sirio engines are known to be softer on the bottom end with very good high end.
Old 04-13-2004, 08:37 AM   #8159
cyba888's Avatar
I know this depends on what tracks you run on but when does your 2 speed clutch engage? I think mine engages a bit too early, at around 30% throttle. Is that too early? I just like the 2 speed to kick in right when it hits the straight but it seems to kick in too fast as well in the turns which makes it a bit difficult to drive.
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 04-13-2004, 08:54 AM   #8160
Sow&Steady's Avatar
Default Re: Re: Re: 2nd Round Summer Series
I haven't even improved enough and am already going downhill!
Hmmm, not sure about that. Although there wasn't a race on yesterday, I went to practise ayway and was surprised to see this blonde lady driving.
Needless to say, she promptly caught me up within 2 laps and smoked past me. I think she'll do a better job at showing you folks how its done. She was definitely using a 1-way and I think that's the best way to go at AMCC.
My car is set for LRCC at the moment. Time to change over I think!
