Old 09-28-2005, 01:52 PM   #22396
markp27's Avatar
Send a message via ICQ to markp27
Originally Posted by JustRace
Mark...where did you get the gear diff from? Are you going to write a FAQ on convert to gear diff? BTW...I ran at Fort this weekend and the traction was over the top. Traction rolled about 10 times during my heat.
Sow...with the gear diff Mark will be in Saturday's heat
Jag...(pit monkey) didn't you ask enough questions over the weekend? LOL
I think the gear diff was a modified Kyosho diff.
Francis, I couldn't actually tell you how to build this diff - it was a one off and isn't easy to build - you really need special equipment for that.
Oh wow - the Fort has lots of grip still, then!!! Which chassis were you using. I've not had one problem with traction rolling here this year - but it has been quite wet.
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 09-28-2005, 02:11 PM   #22397
Sow&Steady's Avatar
Originally Posted by markp27
*spit* *spit* *spit* Bro - how can you compare this work of art with 3racing!!! You bring shame on our Family again!!!
If it was in my own bare hands, I'm sure I would be making a far more realistic comparison!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 09-28-2005, 02:17 PM   #22398
markp27's Avatar
So stupid am I not
Old 09-28-2005, 04:46 PM   #22399
JustRace's Avatar
Cheers, Mark.
I was using the original chassis. Guys with the new chassis still had traction roll issues. Part of the reason was that the entire A-main got caught off guard.
JustRace is offline   Reply With Quote
Old 09-28-2005, 04:48 PM   #22400
JustRace's Avatar
The other mod is definitely needed if what you say about the traction is true but he's too lazy to do it. I'll write up about it one of these days ... just hope I get round to it before the new car is released!
Sow...what mod? And I'm assuming it has to do with the traction roll.
Old 09-28-2005, 08:33 PM   #22401
Pyramid's Avatar
I do not have traction roll issues anymore, but here some of what I have seen/know.
There are a lot of thing you could do to compensate traction roll. As for setup, basically go to the understeer side/lazy car or the other way around, lose the rear traction. As for construction, lower CG always desired in any car manufacturer. Low CG chassis would help but not guarantee. We have our own version by lowering the whole top deck which put a lot of weight lower. Others may have modified the rear uprights (shorten it) and tough it works while it does not make any different on someone elses car. `Some` may also lower the whole rear assy (where the diff is) which in my opinions only give more rear on throttle traction (take a look at Xray T1FK05 rear diff adjustment) which make the front side hunger for more steering.
Pyramid is offline   Reply With Quote
Old 09-29-2005, 02:21 AM   #22402
Send a message via ICQ to _cyclops_
How did they mod the rear uprights? any pics?
_cyclops_ is offline   Reply With Quote
Old 09-29-2005, 03:44 AM   #22403
Pyramid's Avatar
Sorry, no pics.. maybe brother Mark can find one with his fully charged camera
Rear upright, the top part in which you use to adjust camber. The distance between top pillow ball and botom > shorten it. How, just cut to make it lower and use epoxy glue to joint them back. I dont really understand what it does. But if it means to change the Roll Center either the height or the speed it behave when rolling, I would simply prefer straight rear upper arm link just like on S960.
Old 09-29-2005, 06:45 AM   #22404
DS Motorsport's Avatar
They already have the new rear uprights, Rene cornella had them on his car for about a month or sow. Dont know if they are going into production.
But it really works great i hearded. I heard from a other driver that's it makes the rear a lot more stable. The pivot point was lowered about 5 mm.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 09-29-2005, 07:39 AM   #22405
Guest what Jordy Blok was using at the Nitro Tour the netherlands? Serpent is testing a 'lower' upright....
Does the epoxy glue hold? i tough you would cut them up, but i was worried about the stiffness and if it stays together...
Old 09-29-2005, 07:40 AM   #22406
You beat me to it :P
Old 09-29-2005, 10:32 AM   #22407
markp27's Avatar
I've seen a driver with some modified ones, but my feeling is that with the rear gear diff, the rear end is in any case really planted and I don't really think it needs any further improvement.
Old 09-30-2005, 06:05 PM   #22408
rfy
Hi guys,
Just wondering what thoughts you have on gear diffs.. specifically, how to tune your diff (oil viscosity) given the track conditions e.g. low traction = what oil viscosity, high traction = lower or higher than low traction?
rfy is offline   Reply With Quote
Old 09-30-2005, 08:12 PM   #22409
I think once you have the right oil for the track and set-up, it will be nice and consistent like the Impulse ones but I'm struggling to decide.
Wow, I don't even have the option of a struggle. Unless Serpent comes out with a gear diff, most of us are living with the ball (and chain). It's actually not too bad. Using the adjuster is great but you're right about consistency. With a gear and oil diff, it stays the same and doesn't come loose. With a ball, you need to tweak it as required and keep an eye on it to watch for slip.
Someone mentioned the V-one-RRR rear diff. Is it possible just to buy one and slap it on the 710. No? It can't be that easy? Can it?
going4#1 is offline   Reply With Quote
Old 09-30-2005, 08:23 PM   #22410
Originally Posted by Julius
First of all, use the stock weights and yellow shoe. 0.7mm gap and the spring set so the clutch will engage at high rpm but not so tight the clutch slips for more than half a meter when accelerating out of slow corners.
The clutch I made for Slow is a cut yellow shoe for flyweights. The reason I cut a shoe is that I wanted the flyweights to hing the other way round. If you look at the stock weights they "trail" the rotation. I cut the shoe so the weights oppose the rotation. The reasoning is that opposing the rotation the weights will open more easily when the engine accelerates. that makes the clutch snap a bit more when you run a late engagement.
I like the feel of the "opposing weights" and make all my clutches that way. But Meister Salven uses stock weights and a yellow shoe as he likes that better and it is a lot less work!
Well, I finally got a chance where there was no rain AND I could take a day off. First I just tried yellow shoes as flyweights with normal rotation. Not a big difference. I then cut another set and tried the opposing rotation idea. Well, it does do what Julius says it does. There is snap but I also noticed it takes the clutch a little longer to disengage. Changing my driving style slightly can adjust for this. I may try using the idea in a qual at my next race. One set with regular one set with opposing weights. I also bumped the clutch gap to 0.8mm and set the 1.8 spring to 1.5mm. The car definitely can can cover a short distance in a short time. Whether there is any negative effect, I haven't discovered one yet.
Anyway, thanks for the idea. Definitely worth a try out during my next meet.
