Serpent 710
Old 03-05-2004 | 10:47 AM
  #5341
I don't know this is a better solution for those who cannot get in touch with the Serpent shock tower as a replacement........you can buy 2 3racings shock towers from EBAY/DINBALL.........I think for the price of 2, is a little bit less then one stock tower from Serpent (I believed they are $40 from Serpent each)....
On top of that..........you can pick the SSG version for ALL SHOW and NO GO route. I usually won't recomment 3rd market parts for Serpent, but shock towers is not something that important, also, the price of 2 to 1, it is a bargain.
What is odd is....they have only 2 shock positions....why? and what happened to the rest?
Solara is offline
Old 03-05-2004 | 10:51 AM
  #5342
markp27's Avatar
Originally posted by crashed_1
But he has revealed himself to the forum...just give a wild guess...
*clue #2*
the person close to a serpent.
Hmm, sneaky.... Now let me just recap:
This is a woman, who dresses up as a man, but only in polka dots, has hairy legs, a moustache, a big beer belly and likes messing about with snakes..... Well, if I met a woman like that
markp27 is offline
Old 03-05-2004 | 11:08 AM
  #5343
markp27's Avatar
Originally posted by rayhuang
HOw has the tire wear been on the 710 on prepared and unprepared asphalt tracks?
also what shore has been working fr and rr?
Also-more specifically-has it been wearing front or rear pretty evenly-or all front or all back. And this is in 5 minute qualifers and 20 minute mains.
Thanks for the answers guys,
Ray
Here's Julius' answer on the question about tyre hardness:
http://www.rctech.net/forum/showthre...231#post739231
Cheers, Mark.
markp27 is offline
Old 03-05-2004 | 12:09 PM
  #5344
markp27's Avatar
Default 710 FAQ
Weekly update. WOW! You guys have been writing too much this week - maybe I was involved in there, too
Took a little longer to compile due to me dedicating time to building my 710
Here you go - please give comments if you feel something should be imporved.
Cheers, Mark.
File Type: pdf
markp27 is offline
Old 03-05-2004 | 12:12 PM
  #5345
Diesel Racer's Avatar
Originally posted by Rookie Solara
As much as I like that...(because I have one) that setup station are NO LONGER working with the 710 because the rear uprights (the top pivot ball area that you will adjust your rear camber)of the 710 sit up HIGH and the Integy setup block DOES NOT have the opening for you to adjust the upper pivot balls thru the setup block...so you can only use the L-shape stock allen wrentch to setup your camber or you setup the camber with the setup block.
And somehow....HUDY one has a circle opening for you to adjust the 710 even thought that HUDY setup station is out almost 5 years already....
I bet Serpent designed the 710 rear uprights for some reason that only HUDY setup will work.
Rookie your'll probably find those top openings were for the Yokomo cars which have the same style of rear bearing block.
Sorry Rookie, I see Proficar has already answered this.
Diesel Racer is offline
Old 03-05-2004 | 12:38 PM
  #5346
clmbia45's Avatar
Lightbulb
I adjust my camber without removing anything, using a Hudy 2.5 mm ball-tipped driver. So if Serpent and Hudy conspired to prevent the Integy set-up station from being used, they're not only sneaky, they're incompetent.
clmbia45 is offline
Old 03-05-2004 | 12:40 PM
  #5347
Sow&Steady's Avatar
Default Re: 710 FAQ
Wow, you are right on that. I've given up on trying to re-read the past pages.
Sow&Steady is offline
Old 03-05-2004 | 01:01 PM
  #5348
my hudy station does not work with the 710 rear uprights. I bought the universal one, did I get the wrong one? someone please tell me the right part number.
Profoxcg is offline
Old 03-05-2004 | 01:08 PM
  #5349
Herbie's Avatar
I think Julius mentioned it an o so many posts ago. but to use the hudy setupsystem you'll need to make extra holes for the rear upright to align to make the adjustments for camber.
Herbie is offline
Old 03-05-2004 | 01:15 PM
  #5350
that sux. what if I mess up, do you think i can order replacement for the rear panels only?
Profoxcg is offline
Old 03-05-2004 | 01:17 PM
  #5351
Wait.........are you saying that the HUDY one (that hole) is not even high enough for the S710? I didn't try it yet, but I saw there is a hole on on the HUDY one and assumed that will work.....
Hmmm, that mean another update from HUDY just for S710 is coming?
Solara is offline
Old 03-05-2004 | 01:20 PM
  #5352
So you are saying you can adjust the camber by using HUDY setup system without remove or rotate anything.....? Well, that is what HUDY system suppose to be......unless you are talking about using Integy system, then I would like to know how.....
Solara is offline
  #5353
Herbie's Avatar
Don't think Hudy has them allready. Just read the following thread on mytsn for some more info.
http://www.mytsn.com/forums/forum.as...56&sm=0&fi=126
Herbie is offline
Old 03-05-2004 | 01:26 PM
  #5354
Hudy only made one....108250 for 200mm TC, there are only 2 package, 1 is everything including ride height block and this and that, the other is setup station only............they are exactly the same thing.
I think drilling a big enough hole will clear the problem, at least HUDY is plastic compare to Integy (alum )...
Solara is offline
Old 03-05-2004 | 01:29 PM
  #5355
That will clear up everything..........thanks.
Solara is offline
